    Soap Skin & Bubble sketchup 7 keeps crashing - using Mac
    12 Posts 7 Posters 3.9k Views 7 Watching
      dylan
      Not much help I know, but your skp works ok on my Mac also.
      Is this the only Ruby you have installed?
      http://dmdarchitecture.co.uk/
        mazza
        Hi guys
        thanks for getting back to me, Im really new to the ruby scripts, specially to install them as well. But as soon as Dylan said 'Is this the only Ruby you have installed?' I remembered that i was trying to install another ruby script called 'skin' which didnt work, so I had a look at the directory of the ruby scripts folder
        Library/Application Support/Google SketchUp 7/SketchUp/tools
        I deleted the other ruby script called 'skin' than fired up sketchUp the 'Soap and Skin and Bubble' ruby script finally worked. At last its fantastic. But it seemed it had a conflict with another ruby script.
        thanks for your help
        Re: Soap Skin & Bubble sketchup 7 keeps crashing - using Mac
        by Dylan on Sat Jun 13, 2009 9:38 am
          stroek
          Hello,
          I'm new in sketchup on Mac.
          I have put the SoapSkinBubble directory and SoapSkinBubbleTools.rb in the plugin directory.
          This dos not work.
          No tools appear in Sketchup.
          (Dutch operating system)
          -HD/Programma's/Google SketchUp 7/Sketchup
          Then I have to right click on the sketchup Icon and choose "Show Package Contents"
          Now I get the contents directory
          http://www.triooo.be/screenshots/afbeelding-1.jpg
          So what thou's I'm doing wrong?
          Regards
            That's not where you place plugins on Mac. See this FAQ: http://code.google.com/intl/nb/apis/sketchup/docs/loading.html
              stroek
              Great
              Tks
              Regards
              • BurkhardB
                Burkhard
                ...and normally it goes in Tools folder not in the Plugin folder.
                http://www.ia-plus.de
                  I thought Tools was meant for Google Sketchup plugins, and Plugins for third-party tools...
                  • B
                    BTM
                    πŸ˜•
                    … Plugins you download on your mac SHOULD go to:
                    Library/Application Support/Google Sketchup 7/Sketchup/plugins
                    • BurkhardB
                      Burkhard
                      The earlier Versions are going into the Tools folder. Seems that it works now under Plugins,too.
                      You're right thomthom, but there are some tools, like Pixdim, which installs automaticly into the Tools folder by the installation routine.
                      For the Mac you'll find out that some troubles with Plugins depends on what path you choose. If HD/...is not working, I always try out the users/...path which contains also a Sketchup folder.
                      • jeff hammondJ
                        i used to say this a lot around here but i haven't been posting in a while but.... πŸ˜„
                        sketchup actually does not have a plugin folder in the users/ path.. i challenge anyone to do a clean install of sketchup and find that folder.
                        installing podium puts the folder there and that's when things start getting screwy.
