    Soap Skin & Bubble sketchup 7 keeps crashing - using Mac
    12 Posts 7 Posters 4.0k Views 7 Watching
      mazza
      First time using soap skin & bubble, or any ruby script for that matter. I managed to put all the files in the right places to get the Soap Skin & Bubble up and running in sketchup 7 on a mac. But it keeps crashing sketchup, I get to the stage when I select the line work then press skin, it allows me to enter number of segments than when it starts to divide it crashes. I also tried it on sketchup 6 and it crashes also, and its not the particular shape Im trying to skin, its any shape.
      Let me know if anyone is having issues with this, or how to resolve it. I contacted the author, but he is on holiday at the moment so it will be 3 weeks till he gets back to me.
      It looks like a fantastic tool
      many thanks
      screen grab
      error message
      part of boat which Im trying to skin
      • jeff hammondJ
        hmm.. not sure. i can use soap skin on your skp with no problems.
        what model mac do you have?
          dylan
          Not much help I know, but your skp works ok on my Mac also.
          Is this the only Ruby you have installed?
          http://dmdarchitecture.co.uk/
            mazza
            Hi guys
            thanks for getting back to me, Im really new to the ruby scripts, specially to install them as well. But as soon as Dylan said 'Is this the only Ruby you have installed?' I remembered that i was trying to install another ruby script called 'skin' which didnt work, so I had a look at the directory of the ruby scripts folder
            Library/Application Support/Google SketchUp 7/SketchUp/tools
            I deleted the other ruby script called 'skin' than fired up sketchUp the 'Soap and Skin and Bubble' ruby script finally worked. At last its fantastic. But it seemed it had a conflict with another ruby script.
            thanks for your help
            Re: Soap Skin & Bubble sketchup 7 keeps crashing - using Mac
            by Dylan on Sat Jun 13, 2009 9:38 am
              stroek
              Hello,
              I'm new in sketchup on Mac.
              I have put the SoapSkinBubble directory and SoapSkinBubbleTools.rb in the plugin directory.
              This dos not work.
              No tools appear in Sketchup.
              (Dutch operating system)
              -HD/Programma's/Google SketchUp 7/Sketchup
              Then I have to right click on the sketchup Icon and choose "Show Package Contents"
              Now I get the contents directory
              http://www.triooo.be/screenshots/afbeelding-1.jpg
              So what thou's I'm doing wrong?
              Regards
                That's not where you place plugins on Mac. See this FAQ: http://code.google.com/intl/nb/apis/sketchup/docs/loading.html
                  stroek
                  Great
                  Tks
                  Regards
                  • BurkhardB
                    Burkhard
                    ...and normally it goes in Tools folder not in the Plugin folder.
                    http://www.ia-plus.de
                      I thought Tools was meant for Google Sketchup plugins, and Plugins for third-party tools...
                      • B
                        BTM
                        πŸ˜•
                        … Plugins you download on your mac SHOULD go to:
                        Library/Application Support/Google Sketchup 7/Sketchup/plugins
                        • BurkhardB
                          Burkhard
                          The earlier Versions are going into the Tools folder. Seems that it works now under Plugins,too.
                          You're right thomthom, but there are some tools, like Pixdim, which installs automaticly into the Tools folder by the installation routine.
                          For the Mac you'll find out that some troubles with Plugins depends on what path you choose. If HD/...is not working, I always try out the users/...path which contains also a Sketchup folder.
                          • jeff hammondJ
                            i used to say this a lot around here but i haven't been posting in a while but.... πŸ˜„
                            sketchup actually does not have a plugin folder in the users/ path.. i challenge anyone to do a clean install of sketchup and find that folder.
                            installing podium puts the folder there and that's when things start getting screwy.
