    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 68.9k Views 15 Watching
      markozeta
      @martinrinehart said:
      The current version now supports about 12k layer/scene intersections.
      Buggy still, but the problem is in ruby! Here's the console dump on "send to model":
      (eval);259; warning; invalid character syntax; use ?\s
      (eval);259; warning; string literal in condition
      Error; #<LocalJumpError; return from proc-closure>
      (eval);259;in `call'
      BSME - Cal Poly Pomona
      Sketchup Pipe Maniac
        MartinRinehart
        @markozeta said:
        Buggy still, but ...
        Thanks for the dump. Line 259 is my EOF comment, so I'm not sure what to make of it.
        Are you PC or Mac?
        If it's PC, can you UL or send me a model? (MartinRinehart at Google's mail service).
        Martin
          MartinRinehart
          Actually, it's in Ruby, but not the Ruby I wrote. See this:
          Error 404 (Not Found)!!1
          (groups.google.com)
          Google search is one of the wonders of the world. That said, how to find a workaround?
            MartinRinehart
            Thank you, markozeta, for your pipes! (A big model w/lots of scenes and layers, most helpful for finding the Ruby bug workaround.)
            A new version is up. Tested on the PC. Monty, my pet Python, thinks it might work on the Mac, too. Let me know.
            http://www.martinrinehart.com/models/rubies/vismapdoc.html
              jsteacy
              Just a heads up, I downloaded the most recent version and got an error hitting the button 'get data from model'
              line 157, char 2, error expected '}', code 0
              which causes nothing to happen after I continue to run the script on the page.
              I haven't read all the posts before this so maybe someone brought it up already but I figured since this was a new version, its a new problem.
                markozeta
                New to add to documentation:
                Only update Vismap with sketchup closed. Updating with sketchup open is bad.
                Mark
                  markozeta
                  New version works, even on my bigger model!
                  Now about that alphabetical layer sorting I asked for... πŸ˜„ πŸ˜„ πŸ˜„ πŸ’š πŸŽ‰
                  It helps when I can check vismap with a nice straight diagonal for these large maps, since I can just make sure that it works perfect.
                  xooo
                  oxoo
                  ooxo
                  ooox
                  vs.
                  xooo
                  ooxo
                  oxoo
                  ooox
                  It helps.
                    MartinRinehart
                    Can you UL a model? I can't reproduce this. Thanks.
                      MartinRinehart
                      Pat yourself on back. You had a major hand in that. Or at least your pipes did.
                      Hmmm. Sorting is trivial, of course. Takes a single line to sort an array. Problem is, if you check a box, how do I know which layer that is in the model? Requires some sort of mapping from unsorted to sorted order.
                      As names are unique, I could do a brute force mapping, I suppose. Hmmm.
                      • EdsonE
                        Edson
                        martin,
                        good news! it works on mac now!
                        although it must be a pain for you to have us always asking for more features, i second bob's request for a scroll bar: in a model with many layers there will be no way to reach the ones at the bottom.
                        THANKS!
                        http://www.mahfuz.arq.br
                          markozeta
                          Scroll bars pop up on the PC, but not on the Mac...
                          Interesting. That's pretty - ubergeek. πŸ€“
                          Mark
                          • Bob JamesB
                            Bob James
                            Martin,
                            In addition to sorting, can you put in a scroll bar: I have more layers than can fit in the VisMap dialog box fully extended top to bottom. [MacPro]
                            This is an awesomely useful plugin, but, in addition to the above, I cannot load my large model: there doesn't seem to be a problem with the number of layers, but, apparently, with a large number of layers (as shown in the VisMap for another model) and a large number of scenes (in this case 15: reduced from 20 to see if that would help).
                            Super-super stuff 😍
                            Shows that VisMap can handle many layers, but needs a scroll bar
                              markozeta
                              As names are unique
                              Only for Layers! Scenes can have same names...
                              *Hopes his cry of despair reaches the target before ... πŸ‘Š *
                              • Bob JamesB
                                Bob James
                                Thought I'd give it a try on my PC: when I clicked on "Load Model Data" I received the attached error dialog 😞
                                  MartinRinehart
                                  Bob, that error reporting is exemplary. It is with some regret that I must inform you that MSIE's error reporting is near useless. Can you UL or email (MartinRinehart at Google's mail service) a model that generates this error?
                                  Mac folks:
                                  Attached is a replacement for .../Plugins/vismap/vismap.rb. It may give you the scrollbars we PC folks have. Let me know.
                                  scrollbars on Mac?
                                  • Bob JamesB
                                    Bob James
                                    Mac folks:
                                    It works! πŸ‘
                                    • chrisglasierC
                                      chrisglasier
                                      Anyone who has read any of my posts will know that I am very keen on promoting the use of web dialogs and as I see Vismaps a part of this I hope the following critique will be seen in that light:
                                      Sketchup windows generally seem pretty tightly designed as small as possible to minimise obstructing the display of the geometry. I think you could beneficially lose the rubies and title in the body.
                                      The idea of the table and scene code numbers is an awkward solution. At least the table should follow the scroll.
                                      I think the option to have layers and scenes in alphabetical/sequential order is important.
                                      In the screenshot you see I have used full screen and yet only display about half of the layers. I usually want to see the effect of turning layers on and off in the current scene using the scene tabs for example to check others. Maybe it is just my intuition and others are better able to visualise the outcome. If you consider making Vismap into a machine would be beneficial I would be happy to help with that.
                                      • fredo6F
                                        Chris,
                                        I agree with your remarks, but then, you don't need a plugin, as it should be enough to show the SU Layers dialog, and click on the scene Tabs to see which layers are visible in the current scene. The Layers SU Window is small, redimensionable, fully interactive and has a table scrolling. Furthermore, it allows to add / remove layers and configure them dynamically. You will miss however the Sorting into alphabetical order!
                                        Alternatively, it is feasible to make Martin's Vismap plugin fully interactive (i.e. no need for Get data / Send data), sorted by alpha order and scrolling horizontally and vertically with freeze panes for first column and table header (which can be displayed vertically). But at the end, it would give the same result as the native solution above.
                                        • EdsonE
                                          Edson
                                          martin,
                                          i have the scroll bars now. thanks!
                                            MartinRinehart
                                            Hey, that Ruby was a lot of work! Seriously, next rebuild I'll put the title stuff into a frame so you can drag it into oblivion if you need the space. The worse problem is that MSIE web dialogs don't respond to the normal Ctrl/+ and Ctrl/-. I've got to find a way around this.
                                            The Layers window is a better tool if you don't want to see VisMap's array.
                                            Don't be afraid to ask. This one was trivial to add.
                                            The fact that it works at all on the Mac is due to some fine old threads started by Fredo and Chris Glazier explaining the subtle, and not so subtle compatibility issues.
                                            First, Fredo, thanks for that discussion of synch PC / asynch Mac with Scott Lininger, from a couple years back. Vital info.
                                            Sorting is trivial but you need to unsort before telling the model who's visible or not. I was about half way into this in Ruby when I realized that it was really a JavaScript issue. Never used a hash in JS, but experiment suggests that a JS array IS an associative array. Haven't tested this in MSIE yet.
                                            Freeze panes have been requested for both the layer list and the scene list. This is almost possible with frames. Issue: how to synch vertical scroll in the layers list with vertical scroll in the main array. I don't know that JS has scroll listeners.
                                            That means, writing a custom scrollbar widget, a feasible project in any browser that supports <canvas>. That's every browser except MSIE, of course.
                                            • 3 / 7
