    What's your beginners tip?
    305 Posts 169 Posters 442.1k Views 169 Watching
    • P
      Physicsguy1
      You'll want to become familiar with the functions of all the tools. Things are much easier if you understand what you are doing. You should also group any object you create, so you don't run into problems where two faces have the same edge. Save your works frequently.
        Make shortcuts of frequently used tools/operations... it will make life so much easier.
        Get used to using them you will quickly speed up considerably...
        Some obvious ones are built-in like...
        <Spacebar>=Select
        M=ove
        L=ine
        A=rc
        C=ircle
        P=ushpull
        F=ollowme
        S=cale
        T=apemeasue [*actually I swap this to T=extTool and D=istanceTool(i.e.tapemeasure) + alt+D=imensions]
        R=otate
        E=raser
        Z=oom
        However, some extra ones speed things up even more, like... [here's what I use but you should choose your own]
        Q = Quick reverse faces - you have to have a face selected for Reverse to show in the Preferences Shortcut filter...
        H =Hide - again you have to have a selection for Hide to show in the Preferences Shortcut filter...
        shift+H = unHide - again you have to have a selection for Hide to show in the Preferences Shortcut filter...
        ctrl+H = Hide rest of model during an edit - toggle
        ctrl+alt+H = Hide similar components during an edit - toggle
        U = Un-select everything - ctrl+T is also built-in... but I think that just pressing U is quicker...
        shift+X = eXplode
        alt+S = Smooth
        alt+E= Entity-Info
        alt+M = Material browser
        alt+B = Component Browser
        alt+X = Xray mode toggle
        alt+G = hidden Geometry toggle
        alt+V = show Axes toggle
        \ = Delete all Guides
        F2 = open Ruby-Console
        etc etc
        I also swap G to 'Make Group' and make B 'Make Component' [as B=Block in ACAD]; however, if you want to keep G as your 'Make Component' shortcut, try adding shift+G for 'Make Group' - making groups is a vital way of keeping your geometry separated and tidy - shortcut key is very useful...
        The well known...
        ctrl+Z = Undo
        ctrl+X = Cut
        ctrl+C = Copy
        ctrl+V = Paste
        _Can be added to with this...
        ctrl+shift+V = Paste in Place - p[art of a quick way to cut something from one group and paste it into another in the same place...
        • G
          GreenToaster
          Draw something that has an amorphic shape - sketch it out by hand, then create it with S/U. This may be more challenging than you think - pick something "easy" to begin with. Human body parts - head, hand, foot - are really very challenging to reproduce with accurate proportions and details.
          Start with something simple and fun - it's a great way to learn more about S/U.
          If you really want something you won't ever stop pursuing it.
          • G
            Gloryboy
            Use the forum like it's your best friend...ask for help when you are in trouble. No sense stumbling in the dark when someone is more than willing to shed some light on your problem.
            Gboy
              arklandesign
              As a month old sketchup user the things that have assisted me most recently, are the following:
              1. When working on a model and making changes always save with the same name but add version 2 or 3 or 13... This way, if you make a mistake you can always go back to a previously saved version.
              2. Locking groups assists in keeping ones sanity, it's only one extra click to do or undo, but can save one a lot of anguish.
              3. Sometimes orbiting with the eraser or the move tool active, is akin to running around with a virtual pair of scissors.
              I think the most important rule to remember is always... always.... group... It took me some time to get into the habit, but it makes all the difference. Also, always check components downloaded from 3DWH for extra layers and mistakes and purge them to the default layer, B4 introducing them into ones own model. Don't take it for granted that the model one has downloaded is safe to use... they sometimes simply aren't. Ever since I picked up this tip from Gaeius in this forum, life has been a lot more stress free.
              • GaieusG
                @arklandesign said:
                ...Sometimes orbiting with the eraser or the move tool active, is akin to running around with a virtual pair of scissors...
                Haha. How true. And how much I recognise my girlfriend (who is NOT using "virtual" weapons only)
                πŸ˜„
                • B
                  BTM
                  β€’ If you ever want to select an object enclosed in faces, instead of zooming into it, delete an enclosing face, select the object, then undo. The object will stay selected.
                  β€’ If you ever wish you had a tool for doing something specific, such as push/pull on curved surfaces, making tapers, creating bezier curves, sculpting, flattening geometry, painting materials randomly on faces, rounding corners, or something else, you might find what you're looking for in the plugins forum.
                  β€’ Look for free textures on the internet. The ones that come with sketchup aren't usually that good.
                  β€’ Figure out the keyboard shortcuts for all the tools. If you don't know one, just guess. ( L = line, R = rectangle, C = circle, O = orbit, etc.)
                  • takesh hT
                    takesh h
                    Use Outliner to select groups and components.
                    If you have comprehensive naming convention for them, selecting deeply nested components within others is a piece of cake.
                    It will drastically reduce the need of zooming in + out and orbiting around the space because it will grant you access even to components outside of your screen... or no matter how small they appear on the screen.
                    So... Let's start grouping and naming them!
                    • C
                      Cyberdactyl
                      Didn't see this mentioned in the thread, however, I may have missed it.
                      If you're working in tight and especially inside detailed areas, create a scene saving that perspective and position. If you get turned around and disoriented, you can quickly return to the view.
                      • B
                        bakbek
                        Hi all,
                        I keep watching this forum, but never did post much... but I've just posted a new article on my blog at http://www.ronenbekerman.com called 9 SketchUP Tips for better 3d modeling workflow that sums up my tips for a SketchUP beginner users or even more experienced ones.
                        Do check it out.
                        πŸ˜„
                        • G
                          GoldenFrog
                          The axes tool is a nice one. you can line up your axes with the perhaps not sraight face that you are working on. I think its in the "Large tool set" Hope I help someone with this. πŸ€“
                          Remember, great minds think alike, and fools never differ.
                          • aadbuildA
                            aadbuild
                            1. do these tutorials http://sketchup.google.com/intl/en/gsu7/videos.html
                              2.get a 3 button mouse
                              3.ctrl Z will undo last action
                              4.stay away from the move tool (like an X with arrows on the endes)to start with.
                            2. print the keyboard short cuts and put them in a place you can see until you get used to them
                              6.get the book "Sketchup for dummies" big help.
                            3. learn about components Short cut is "G"
                              Happy sketchuping.
                            Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                            https://www.plusspec.com
                              Rafa
                              I'm a complete begginner, so here is my tip. πŸ’š
                              Sooner or later you will be using some plugins or ruby scripts.
                              Try one at a time, know what it does, and if it works for you, save a copy in an ordered folder.
                              You can always re-install the main aplication, but find again a usefull plugin may take time.
                              • honoluludesktopH
                                honoluludesktop
                                I too am still a beginner, but have come to understand that its not always necessary to look for a plugin to do what you want. Often there are ways to do things by SU commands that are not obvious to us beginners. "Move" not only moves, but copies, creates arrays, rotates, etc. So my tip is, at first as a beginner, try hard to find a way to do it without a plugin, because that forces you to understand the program better.
                                Also read this page everytime a tip is posted:-)
                                • AnssiA
                                  Anssi
                                  And tho learn these tricks, look at Johnny Lemire's cool tutorials (many of them to be found in these pages, in .SKP format), even if you think you know how to do what the tut is about. They still make my jaw drop.
                                  Anssi
                                  • GaieusG
                                    Indeed. Jean (Johnny) performs these tuts in a way you will always understand why and how SU (or in fact, YOU) is/are doing things like they can be done in a certain way.
                                    Native SU - native learners of it...
                                    • B
                                      bmscmoreira
                                      Well, here is my tip (hope someone hasn't said this yet, if so... its never enough to repeat)
                                      Since Sketchup works with front and back faces (a plane has both) be sure that front faces are always facing you and the camera. Having a mixture of front/back faces makes applying materials harder in Sketchup and a lot of other problems when, later on, you will export sketchup scenes to be rendered in an external renderer software.
                                      By default, back faces display in a blue/gray shade which sometimes is confusing with the front faces (which display white). So, I always work with red back-faces: the switch can be done in the styles/edit panel of Sketchup.
                                      Make those back faces visible!
                                      http://www.brunomoreira.net
                                      • boofredlayB
                                        boofredlay
                                        If this was mentioned before sorry. However, here is something I use all the time. Use the X, Y & Z axis to create construction lines with the Tape Measure tool . There is no need to have a face already drawn.
                                        • K
                                          kambing300
                                          DON'T bring your old CAD preconceptions to SketchUp! Groups, components, guides, and accuracy are just fine, but FIRST, discover what's DIFFERENT about SU: the 'sticky' geometry! Get comfortable with 'Move' and 'toggle autofold'; these two tools are all you need to create amazing objects from elementary geometry. Forget everything you know about CAD and discover what is possible! Have fun!
                                          • pmolsonP
                                            pmolson
                                            First open beer, then open sketchup!
                                            pmo
                                            • 15
                                            • 16
                                            • 6 / 16
