    Image type
    20 Posts 6 Posters 1.7k Views 6 Watching
      avariant
      Hmm... that's promising. Maybe there's a more reliable way coming in from that direction...
        AlexMozg
        @avariant said:
        Images have definitions?! ๐Ÿ˜ฒ That actually may help a lot... I'll have to take a look. Is this an unpublished method to retrieve it, or just one I've overlooked?
        http://forums.sketchucation.com/viewtopic.php?f=180&t=21869
          avariant
          Hi Alex, thanks for the link. Looking at your code, you are doing just about the exact same thing I'm doing except your scaling by width/pixelwidth, height/pixelheight. I'm not doing that, I'm just using width and height. I'll definitely try it out!
            avariant
            Hm... it looks like using your code didn't solve my problem. Are you familiar with the trees from tomsdesk? The leaves are images, contained in a component, and that component is set to face-me. The issue is not so much getting the correct transform for an image, but getting a correct transform when the image is contained in a component.
              It doesn't work when the image inside a component?
                avariant
                That seems to be the issue. Like what I said in my first post, for some reason the point returned from the 'origin' method isn't consistent when it's inside a component, nor is the 'normal' method. Since those two, at least, are necessary to create the transform matrix of the image relative to it's container, in this case the component, then I can never get a correct transformation.
                And it doesn't always happen. With some components, it works just fine, other times not.
                  AlexMozg
                  @avariant said:
                  ... With some components, it works just fine, other times not.
                  You should take into account transformation of component!
                    avariant
                    Oh, I am, most definitely. ๐Ÿ˜„ The issue is that the transformation created for the Image is inconsistent. If I have 10 instances of the same component with the same image in it, each one might give me a different result when asked for it's origin. But it shouldn't right? Because it's inside the parent component, and because I'll be multiplying in the parent components transform, the image should have the same origin, normal, and zrotation for all the instances. But sometimes it doesn't. (And I can't figure out the difference from the times it does work and the times it doesn't)
                    And maybe related to that, as posted above, when you actually have a component open, the results are different than when you don't. I suppose there's no magic bullet until I can figure out what's different for the images that don't work...
                      RickW
                      The "magic bullet" (or as close as it currently gets) is to query the Sketchup.active_model.active_path which will return an array or nil. If it's not nil, then you're in a g/c and you'll see an array listing the hierarchy of objects and you can check all the transformations as needed.
                      RickW
                      www.smustard.com
                        model.edit_transform
                        returns the transformation of the current edit session - so use that in combination with the instances' transformations to adjust to suit...
                        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#edit_transform
                          This is apparently designed behaviour. When a group/component is open the co-ordinates are normalised to global co-ordinates.
                            avariant
                            That's definitely good info, especially the model.edit_transform command, and helps explain the weird behavior when a component is open, but that's not really the issue.
                            Assuming no components are open or selected or anything, given the above configuration of multiple instances of a component with an image in it, the image commands (origin, normal) return different information for each instance, but only with certain models. (This is using a ruby script to gather up all the image info, not done manually) I'm accumulating the transforms down through the hierarchy just fine. If the image was a face instead, it works without problem, so it's not the model hierarchy transforms. It's the last bit, the image.
                            I guess it's kind of silly to look for an answer without really understanding what all the influencing factors are. At least now I know that SU modifies the transformation when a component is open; I didn't know that before, so thanks for that! ๐Ÿ˜‰ Maybe if I can consistently create the circumstances, I'll post a scene and a ruby script to demonstrate what I'm getting at. Thanks!
                              The behaviour with open components apparently pre-dates the SU ruby API. Tyler provided that bit of info.
