    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 28.4k Views 12 Watching
      CPhillips
      Nice model!
      • N Offline
        NorviewsVeteran
        Thank you, have another.
        I figured out the scripted joints (big for me) to the point where I used universal joints for the bogies and you can copy more cars to the train, but the problem is I had to daisychain the joints under the cars so much the sag makes the cars lean in turns. Just beware of derails, they seem to be quite frequent...
        If anyone can figure out a way around this, that would be great.
        train.skp
        //This_Is_All(I)+=Know()About.Code;
        • W Offline
          Wacov
          @norviewsveteran said:
          1. You guys are blowing my mind. Wacov, when I opened your cloth file my jaw dropped for so long I almost drooled on my cat.
          @cphillips said:
          I think it is possible to set events externally with this version. I know the the syntax is a bit weird and I plan to clean it up.
          Create a good sized cone and put this in its scripted field.
          b=copy
          > b._setEvent("ontick",
          > <<CODE
          >    push([0,0,1])#go forward
          >    if(frame>50)
          >       destroy #die after 50.
          >    end
          > CODE
          The cone will copy itself and then set the "ontick" event in the copy.
          I tried to make an example that uses "ontouch" but it didnt work for some reason. I will have to debug it.
          It totally crashes my SU when I try it in ontouch, and freezes the sim in ontick... also, I can't drag the original object. It highlights, and the drag line appears, but no movement πŸ˜•
            Physicsguy1
            Err... looks like you didn't try it in the right field.
            • W Offline
              Wacov
              I mean ontick/touch as in:
              ontick{
              Try it, see what you get.
                CPhillips
                I am not 100% sure that works in this version. It may depend on some unreleased code. Can anyone confirm it works?
                  Physicsguy1
                  It works for me.
                    JaViXP
                    Same for me.
                    "Giving up is way harder than trying"
                    JaViXP's Rendering
                    • W Offline
                      Wacov
                      It works for me, just not in any events.
                        CPhillips
                        Not sure I understand. Can you post a model that fails and I will take a look.
                          Physicsguy1
                          BTW,(this may be a stupid question), but is there a way around the camera 'bending' situation where the camera eye overshots to some other point3D? I cant get any reliable camera systems...
                          • W Offline
                            Wacov
                            In Jun 27, putting your code inside a normal event (ontick{...}) crashes. It seems to work in the SVN version, though πŸ˜•
                            • mariochaM Offline
                              mariocha
                              Hi, just to share 2 small animations done with SkPh-3.
                              One is quite amusing, showing Emitter, Thruster and magnet
                              http://www.youtube.com/watch?v=ea5KeZ7Turg
                              the other shows pseudo-virus
                              http://www.youtube.com/watch?v=Yb_D__3m_0w
                              %(#008000)[Mario C.
                              • mariochaM Offline
                                mariocha
                                @wacov said:
                                Got cloth smoothing working, and made it easier to change the scripting (everything's in the floor).
                                Ok I give up. Wacov, I just cannot see how this works. I have tried a few times. Refreshed my SkPh knowledge. Had fun with the new features.
                                But your cloths are a vast mystery to me.
                                The SkPh UI shows nothing.
                                Is it PC only ? Scripting only ?
                                %(#008000)[Mario C.
                                • W Offline
                                  Wacov
                                  Basically, there's a physics object at the vertices of each panel of cloth. What you see in the simulation is Sketch Up geometry, which is created at the beginning of the sim, and modified in real-time; the main script is in the floor's scripted field, which creates a command used in the hidden physics objects.
                                    JeremyGBertin
                                    Hello Everyone, new member here.
                                    Can anyone point me to a working example using the 'UnTouch' script functionality? I've played around with it, but can't quite seem to get it to work. I apologize if this has long since been covered somewhere, but I can't seem to find any examples. Thanks.
                                      Davidfi1
                                      Did you mean OnTouch?
                                      http://forums.sketchucation.com/download/file.php?mode=view&id=38286&sid=dd6f1c8a118406fd16177924a97f2a1a
                                      OnTouch
                                        JeremyGBertin
                                        No, I was not referring to the onTouch which is in the UI, but rather the opposite signal for when two objects stop touching.
                                        Looking through the ruby code there seem to be events for onTouch, onTouching, and onUnTouch and I would like to know whether these are accessible for use. I am specifically looking for an example making use of an event which can fire code when two objects stop touching.
                                        The effect I am trying to achieve it to set a variable when two objects come into contact, and clear the variable only when the objects move apart. Thanks!
                                        • W Offline
                                          Wacov
                                          Basically, you use:
                                          ontouch{
                                             #your code here
                                             #code
                                             #code
                                             #more code
                                             #etc
                                          In the scripted field. The code you put between the brackets will be executed, in the case of ontouch, upon every collision with another object. ontick{...}, onuntouch{...}, and ontouching{...} work in basically the same way, with ontick executed every frame, onuntouch whenever the object stops colliding, and ontouching every frame the object is colliding with another. With any of the the touch events, you can also access the object being collided with, the exact point3d of the collision, and the impact speed of the collision, using:
                                          ontouch{|toucher,speed,pos|
                                             #code
                                          You can then use them as variables in your event code.
                                            JeremyGBertin
                                            Thanks Wacov. Much appreciated.
                                            • 4 / 5
