    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 28.4k Views 12 Watching
      Physicsguy1
      BTW,(this may be a stupid question), but is there a way around the camera 'bending' situation where the camera eye overshots to some other point3D? I cant get any reliable camera systems...
      • W Offline
        Wacov
        @cphillips said:
        @wacov said:
        It works for me, just not in any events.
        Not sure I understand. Can you post a model that fails and I will take a look.
        In Jun 27, putting your code inside a normal event (ontick{...}) crashes. It seems to work in the SVN version, though ๐Ÿ˜•
        • mariochaM Offline
          mariocha
          Hi, just to share 2 small animations done with SkPh-3.
          One is quite amusing, showing Emitter, Thruster and magnet
          http://www.youtube.com/watch?v=ea5KeZ7Turg
          the other shows pseudo-virus
          http://www.youtube.com/watch?v=Yb_D__3m_0w
          %(#008000)[Mario C.
          • mariochaM Offline
            mariocha
            @wacov said:
            Got cloth smoothing working, and made it easier to change the scripting (everything's in the floor).
            Ok I give up. Wacov, I just cannot see how this works. I have tried a few times. Refreshed my SkPh knowledge. Had fun with the new features.
            But your cloths are a vast mystery to me.
            The SkPh UI shows nothing.
            Is it PC only ? Scripting only ?
            %(#008000)[Mario C.
            • W Offline
              Wacov
              Basically, there's a physics object at the vertices of each panel of cloth. What you see in the simulation is Sketch Up geometry, which is created at the beginning of the sim, and modified in real-time; the main script is in the floor's scripted field, which creates a command used in the hidden physics objects.
                JeremyGBertin
                Hello Everyone, new member here.
                Can anyone point me to a working example using the 'UnTouch' script functionality? I've played around with it, but can't quite seem to get it to work. I apologize if this has long since been covered somewhere, but I can't seem to find any examples. Thanks.
                  Davidfi1
                  Did you mean OnTouch?
                  http://forums.sketchucation.com/download/file.php?mode=view&id=38286&sid=dd6f1c8a118406fd16177924a97f2a1a
                  OnTouch
                    JeremyGBertin
                    No, I was not referring to the onTouch which is in the UI, but rather the opposite signal for when two objects stop touching.
                    Looking through the ruby code there seem to be events for onTouch, onTouching, and onUnTouch and I would like to know whether these are accessible for use. I am specifically looking for an example making use of an event which can fire code when two objects stop touching.
                    The effect I am trying to achieve it to set a variable when two objects come into contact, and clear the variable only when the objects move apart. Thanks!
                    • W Offline
                      Wacov
                      Basically, you use:
                      ontouch{
                         #your code here
                         #code
                         #code
                         #more code
                         #etc
                      In the scripted field. The code you put between the brackets will be executed, in the case of ontouch, upon every collision with another object. ontick{...}, onuntouch{...}, and ontouching{...} work in basically the same way, with ontick executed every frame, onuntouch whenever the object stops colliding, and ontouching every frame the object is colliding with another. With any of the the touch events, you can also access the object being collided with, the exact point3d of the collision, and the impact speed of the collision, using:
                      ontouch{|toucher,speed,pos|
                         #code
                      You can then use them as variables in your event code.
                        JeremyGBertin
                        Thanks Wacov. Much appreciated.
                        • H Offline
                          hpnisse
                          Hello!
                          When I try the "ontouch" in script-field event it will not work:S
                          Ex. I have a "button" (box), and when I push that button it touch another box with the script (easy one, see below) the physics engine freeze and I need to restart the physics-simulator.
                          Here is the simple code I use:
                          ontouch{
                             setVar("var1",1)
                          Why does the physics-simulator freeze?
                          And will this script set the "var1" to "0" (zero) when I relase the button?
                          Thankยดs for help.
                          /hpnisse
                          ` /hpnisse`
                          ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
                          • W Offline
                            Wacov
                            The commands from RC1 no longer work in the scripted field, inluding get/setVar. The new variables are:
                            @var = 1
                            For a local (this group only) variable, retrieve it with:
                            @var
                            And:
                            @@var = 1
                            For a global (acessible from all groups) variable. Retrieve with:
                            @@var
                              JeremyGBertin
                              Does anyone know of a way to allow for a Servo joint to rotate multiple revolutions?
                              It seems like the maximum workable range for the Servo joints are 360 Degrees (2*pi radians) symmetrical about the starting angle, and when exceeded the joint starts to endlessly spin around. I am looking to achieve multiple revolutions while still maintaining angular position control. Any ideas would be welcome. Thanks!
                              • W Offline
                                Wacov
                                The only way I know is to use multiple, stacked servos (i.e. one group ontop of the other, with the same controller for both joints)
                                  JeremyGBertin
                                  I've still been working to find a way to create exact position control over multiple revolutions. I've been experimenting with an alternative method involving linking a Gyro to a Hinge and specifying gyro X-Y vector coordinates (for the plane orthogonal to the hinge axis) to set the angle of my object attached to the hinge.
                                  This method works fine for setting the angle of the hinge initially, but for some reason it seems like the Gyro is not able to be dynamically controlled while the simulation is running...? In the Controller field I have tried using variables, the 'slider' control, and key presses, but I can not figure out how to force the Gyro to be updated.
                                  Any ideas? Thanks.
                                    Swatpup93
                                    Is there any scripts to put sound in SP 3X?
                                    • H Offline
                                      hpnisse
                                      I can use the "@var" and "@@var" insted of "getVar..." and "setVar...", but I can't use the "onTouch{????}" funcion in the "Scripted" field.
                                      But the "@var" is pretty good, its shorter than "getVar". ๐Ÿ˜„
                                      /hpnisse
                                      ` /hpnisse`
                                        Physicsguy1
                                        Hey Chris:
                                        I am having problems with the Linear Damping on objects. Some C++ Sketchup script is terminating Sketchup after a number of frames whenever I have it running. It has something to do with Runtime. Do you know what might be happening? Thanks in advance, Chris
                                        EDIT: It only happens when I set Linear Damping before altering gravity.
                                        • 5 / 5
