    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 32.1k Views 12 Watching
    • C
      CPhillips
      Here is another useful script. It allows scripts to print text to the screen. In this case a log of whatever touches the floor.
         #add blank text to screen at 10,50
      @@log=SketchyPhysics;;addWatermarkText(10,50,"")
         #place to store lines
      @@lines=[]
      ontouch{|t,s,p|
            #add new line
         @@lines.push(t.name+" touched "+self.name)
            #ensure only 5 lines on screen at once.
         @@lines.shift if @@lines.length>5
            #display lines
         @@log.text=@@lines.join("\n")
      onend{
         @@log.erase!
         @@lines=nil
      logging.skp
        JaViXP
        Very nice script! πŸ‘
        Can we upload with this version if we don't use the new features? πŸ˜‰
        "Giving up is way harder than trying"
        JaViXP's Rendering
        • P
          Physicsguy1
          Never really got back to this one: Are we going to be able to set an object's scripting from an external source code?(ie setting an emitted object to explode on impact.)
            JaViXP
            Nice question, what do you want it for? πŸ˜‰
            Something like this should work (this one doesn't work, just play around with it):
            ontouch{|toucher,speed,pos|
               if(toucher.name=="box"){
                  split(self,1)
            Hope this helps! πŸ˜„
            JaViXP's Rendering
            • W
              Wacov
              Any SU ruby would work, ao you might be able to load an external .rb file as an ontick func, or whatever. But you don't need that to do what you're asking, as Jav has shown; and anything that SU can detect can be acted upon.
              • C
                CPhillips
                Hi everyone. Sorry I have been quiet lately. Been taking some time off and enjoying the summer.
                I think it is possible to set events externally with this version. I know the the syntax is a bit weird and I plan to clean it up.
                Create a good sized cone and put this in its scripted field.
                b=copy
                b._setEvent("ontick",
                <<CODE
                   push([0,0,1])#go forward
                   if(frame>50)
                      destroy #die after 50.
                CODE
                The cone will copy itself and then set the "ontick" event in the copy.
                I tried to make an example that uses "ontouch" but it didnt work for some reason. I will have to debug it.
                • N
                  NorviewsVeteran
                  Sorry I don't have much to add, but there are a few things. I'm no programmer, I'm on the mechanical team.
                  1. You guys are blowing my mind. Wacov, when I opened your cloth file my jaw dropped for so long I almost drooled on my cat.
                  1. I needed an excuse to upload the Gopher.
                  Gopher Armored Car.skp
                  //This_Is_All(I)+=Know()About.Code;
                  • C
                    CPhillips
                    Nice model!
                    • N
                      NorviewsVeteran
                      Thank you, have another.
                      I figured out the scripted joints (big for me) to the point where I used universal joints for the bogies and you can copy more cars to the train, but the problem is I had to daisychain the joints under the cars so much the sag makes the cars lean in turns. Just beware of derails, they seem to be quite frequent...
                      If anyone can figure out a way around this, that would be great.
                      train.skp
                      • W
                        Wacov
                        b=copy
                        > <<CODE
                        >    if(frame>50)
                        >    end
                        > CODE
                        It totally crashes my SU when I try it in ontouch, and freezes the sim in ontick... also, I can't drag the original object. It highlights, and the drag line appears, but no movement πŸ˜•
                        • P
                          Physicsguy1
                          Err... looks like you didn't try it in the right field.
                          • W
                            Wacov
                            I mean ontick/touch as in:
                            ontick{
                            Try it, see what you get.
                            • C
                              CPhillips
                              I am not 100% sure that works in this version. It may depend on some unreleased code. Can anyone confirm it works?
                              • P
                                Physicsguy1
                                It works for me.
                                  JaViXP
                                  Same for me.
                                  JaViXP's Rendering
                                  • W
                                    Wacov
                                    It works for me, just not in any events.
                                    • C
                                      CPhillips
                                      Not sure I understand. Can you post a model that fails and I will take a look.
                                      • P
                                        Physicsguy1
                                        BTW,(this may be a stupid question), but is there a way around the camera 'bending' situation where the camera eye overshots to some other point3D? I cant get any reliable camera systems...
                                        • W
                                          Wacov
                                          In Jun 27, putting your code inside a normal event (ontick{...}) crashes. It seems to work in the SVN version, though πŸ˜•
                                          • mariochaM
                                            mariocha
                                            Hi, just to share 2 small animations done with SkPh-3.
                                            One is quite amusing, showing Emitter, Thruster and magnet
                                            http://www.youtube.com/watch?v=ea5KeZ7Turg
                                            the other shows pseudo-virus
                                            http://www.youtube.com/watch?v=Yb_D__3m_0w
                                            %(#008000)[Mario C.
                                            • 4 / 5
