    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
      spenceju
      Could someone please tell me how to use this plugin in sketchup? I put the file in the plugins folder but I do not see a "UV tools" context menu. Please let me know.
      Thanks,
      Justin Spencer
      • W
        Whaat
        Thanks,
        Justin Spencer
        Hi spence,
        Someone else posted this issue using a Mac system. I am actually not sure if the plugin works at all on Mac. Has anyone got it to work on Mac?
          spenceju
          Hi Whaat,
          Since posting my first post I was able to find the "UV tools" context menu. But when I select cylindrical mapping it doesn't seem to be doing anything. A few times it has caused SketchUp to quit. I'm going to try this on my PC and see if it works there. If it works I'll know it's a mac issue.
          thanks,
          spenceju
          • majidM
            majid
            dear Whatt, I am still pending for improvment , maybe adding qubic mapping, or maybe adding an interface...,
            thanx again for great plugins
            • PixeroP
              Pixero
              Another great addition would be automatic unwrapping.
              You make a copy of your object.
              You select the edges where the cuts will be and the model gets flat.
              Then texture it and copy the UV info back to the original object.
              Doable?
              • majidM
                majid
                Pixero, 👍 it would be great , and I guess it would be doable using SU7
                • PixeroP
                  Pixero
                  There's a technique called Peltmapping thats kind of "automatic".
                  Take a look at the QuickTime movie here for an example what it can do.
                  (First half of the movie is mostly cutting the model.)
                  http://hydralab.com/pelting/
                  • W
                    Whaat
                    sorry guys, I am swamped with other projects. I won't be updated this one for awhile.
                      RHD
                      That is some very nifty stuff Whaat!
                      Thanks a million for this!
                        RHD
                        @whaat said:
                        Thanks,
                        Justin Spencer
                        Hi spence,
                        Yes, the trick on a Mac is finding the right ruddy plug in folder.
                        Go to Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins and stick your ruby script in there.
                        Ignore the plugins folder in the SketchUp 7 package in Applications, it's just there to confuse you.
                        I've just tried it on one object, a complicated vase that already had the texture badly applied by projection. Worked fine. Texture a little woolly looking but UV projection correct. I will experiment with the textures to see how it works.
                        Great stuff Whaat!
                        • W
                          Wizaerd
                          I downloaded this plugin today, since I had the need to map a sphere. In SU 7.1, I created a sphere (by creating a circle, deleting half of it, then using follow me to create the spehere. I select the entire sphere, right click and choose the UV Tools content sensitive menu option, and SketchUp crashes and closes down.
                          Is this plugin compatible with the free version of SU 7.1? If so, any idea what I might be doing wrong?
                          • GaieusG
                            Hi Wizaerd,
                            It crashed my SU 4 times today, too.
                            I'll have to get a better look into it but then Dale (developer of this plugin) can also see the details (I'll make sure to let him know if I found that the tool is indeed the culprit).
                            • majidM
                              majid
                              now we are on sketchup 7.1 , and no improvement on special mapping!!! 😒 so once again I am gonna ask our ruby heros for help and progressing the script 🎉
                              • E
                                Ecuadorian
                                No need to create a sphere the hard way. If you have SketchyPhysics installed, use it to easily create a sphere with the SketchySolids toolbar. UVtools will map it without problem, except for a few hurricanes in both poles.
                                -Miguel Lescano
                                • W
                                  Whaat
                                  hi,
                                  I haven't tested the plugin using SketchUp 7.1 yet. Maybe there is a conflict...
                                  • E
                                    Ecuadorian
                                    SU 7.1 here, and no conflicts at all.
                                    -Miguel Lescano
                                    • W
                                      Wizaerd
                                      I didn't necessarily think that method of creating a sphere was hard or difficult. Plus the plugin you reccommended, SketchyPhysics, seems a bit overkill just to create a sphere... I don't use Sketchup for animations, so physics aren't really necessary for what I'm using it for, unless I'm missing something...
                                      • GaieusG
                                        Hehe. True - for a couple of second job you really don't need that robust plugin (or you can even make a couple of spheres and save them as components and keep reusing them)
                                        • E
                                          Ecuadorian
                                          That's why I said: 😄
                                          -Miguel Lescano
                                          • W
                                            Wizaerd
                                            Is there something I can submit or show that'll help troubleshoot the porblem I'm having with it? Because everytime I try to use it (just choosing the menu option in the right click menu) causes my SU to crash, each and every time.
                                            • 7 / 9
