    Bad News for Architects in the next ver. of Google Sketchup
    109 Posts 42 Posters 66.9k Views 42 Watching
    • K
      kwistenbiebel
      To me the 500 dollars for the Pro version is very acceptable. Anyone that uses SU in a professional surrounding will agree.
      Keeping the free version feature packed would be nice though. It is the free version that made sketchup so well known and widespread.
      One of Google's best strategies ever if you ask me.
      • K
        Khai
        I'm just questioning the choice of export option here...
        • W
          wmanning
          There is good and bad news (with work-arounds). COLLADA is not a good format for exchanging a CAD file. It doesn't recognize layers, so everything will be on layer 0. It doesn't recognize groups, blocks, or components (I'm pretty sure). And everything becomes triangulated, so a lot of architectural files will need clean-up. But if all you are doing is bringing in a floorplan to kick off a project it isn't too bad (if you have an exporter from you CAD to COLLADA).
          The good news is that you can run more than one version of SketchUp on the same PC or Mac. It doesn't force you to uninstall older versions, so you can keep 7 to open a .dwg, save the .skp, then open it in the new version. One extra step in the workflow to keep using a free product.
          But it will be interesting to see what workflows people develop here.
            d12dozr
            I think they are going after the gaming, art, and film markets which seem to be gaining share on the original architecture market:
            As it turned out, folks wanted to use Google SketchUp models in all kinds of crazy ways. Things that we could never have imagined! We decided that Google SketchUp users should be able to export their models into some easy-to-read and fundamentally hackable file format to make this easier. Your models should be yours to do with as you see fit.
            Here are some links if you care to see what other uses Sketchup is being used for:
            http://sketchup.google.com/industries/digitalentertainment.html
            http://www.youtube.com/watch?v=TlgtLXhwJSM
            http://www.conceptart.org/forums/forumdisplay.php?f=153
            http://www.go-2-school.com/blog_posts/view/7
            http://goo.gl/f7ooYh
            • L
              linea
              At the moment at least, there are a lot more architects and 3d designers in the world than there are game and film designers. But anyway, if Google want more cool new friends like Massive Black, limiting the number of file formats in the free version will limit peoples' opportunities to demo the software thoroughly. I'm happy to be a pro user but I just hope that Google do have something really new for the pro version - not just dwg and dxf import and export.
              Kwist said
              still think Blender should get a 'sketchup UI skin
              If we keep saying it, one day it might happen 😄 On the same day, I expect the hardcore Blender users will be furious...
              • K
                Khai
                then OBJ would be the format most common to all the apps. seriously, if you take a look, nearly all the apps in use by the big studios down can use OBJ. few can use Collada.
                  Aerilius
                  I did some test with kmz files: I believe Collada must support components. Otherwise, the filesize would need to multiply after multiplying the Sketchup components.
                  Obj is quite an old format. But most apps do not dare to ignore it. There is already a good obj-exporter plugin and when I needed to reimport it again, I converted it in other apps into 3ds (most apps have both). It would be good if obj was in SU by standard.
                  • K
                    kwistenbiebel
                    I think that the reason DWG will be ripped out is Autodesk.
                    Google tries to keep things open source-ish. Just like android, which is based on open source Linux code.
                    It is becoming a tradition.
                    I guess, choosing Collada over DWG adds to that strategy...
                    And off course, Google Earth is using it already so it makes the choice easier.
                    • tbdT
                      tbd
                      wrong. COLLADA has the <layer> element and you can even have an object on layer "glow" and on layer "light" at the same time
                      wrong again. they are called instances and you can do even external references (have them stored only in one place)
                      you can have polygons as well (and much more). it all depends on how the COLLADA specification is implemented. and if Google will have COLLADA as main format I bet it will be properly implemented.
                      http://plugins.ro
                        dedmin
                        I know that every change is hard, but we have to try to cut off Autodesk's monopoly! Ask your clients to send you collada files - after all it is your interest! If you want to escape from SketchUP, you will have a bunch of collada files to open easily in any other compatible application! I have jpg's since 1999 and can open them in any viewer - that's freedom!
                        • N
                          notareal
                          @dedmin said:
                          Collada support is very positive - a lot of companies are improving their support - Blender, SolidWorks, Modo etc.
                          The real problem is Autodesk's monopoly and arrogance! If dwg is a standard - make it open standard! About Blender - this hype about the difficult interface is nonsense! Actualy it is very easy if YOU READ ABUT IT! There is coming a new version with a lot of improvement in the UI side ! Read this http://www.blender3darchitect.com/
                          I would not dare to say that Blender interface is easy, all the time it feels that different types of items are just cluttered together, reading and knowing key combos wont help. For me it's simply illogical and inconsistent; try to locate all mesh editing tools..., BUT 2.5 seems to be a major change and most likely I'll then drop SU and jump to Blender wagon, but time shows how it goes. SU6 pro is still fine tool for me and if there had not been this community and generous ruby developers... I would be using some other tool.
                          Collada support sounds good and I have a feeling that many free users will welcome that. It feels a bit like strategic move to only offer dwg import in pro, but I would not complain as long as old SU stays in working condition.
                            Seeing how most people in my office doesn't know what an PNG file is - and keep asking me if everyone can view it - I doubt Collada would make it into the architectural office I work in. Never has that format been mentioned. People stick to what they know works. Asking clients for collada file will just annoy them.
                              dedmin
                              Wrong - there were times before SketchUp, before Autodesk and even before Google. Where are the pencil and the papers - changes happen all the times but usually too slow to see them ☀
                              It is always the same - the first reaction is annoyance, doubt and looking for arguments why the change won't happen 😒
                                Can't really see how the digital revolution can be compared to using different file format. Using computers instead of pencils became a requirement - not and option. DWG vs Collada is a matter of choosing flavour.
                                  dedmin
                                  Not revolution but change, not file format but open file format and yes - more choices! You still have choice to use Pro or any other program. Where is the free version of AutoCAD or 3DS Max?
                                  • daleD
                                    dale
                                    From my understanding Autodesk has been a participant in the development of collada, is that not true?
                                      Master
                                      I hope they add in 64 bit support as well as multicore support. I could care less if they remove the import export features of the free version. I know that is a massive downgrade but the program is free after all. All you would need is to find a program that can convert dwg -> collada and you would be back in business.
                                      The free version of sketchup has been too good of a deal for far too long. Put it back in it's place in the product line up and maybe they will start to get some more income from sales.
                                        dedmin
                                        SolidWorks Lab:
                                        By exporting your SolidWorks assembly in the Collada format, your design is now defined by an open standard for 3D applications. This enables you to leverage other 3D authoring applications which may not import native SolidWorks files, including applications on different operating systems. Not only is your model geometry preserved in the export, but colors, textures and motion are available as well.
                                        • soloS
                                          second, THAT'S IT? nothing else? no improvements to UI, dynamic components, rendering, sandbox etc. this is becoming a trend with google, following Autode$$$$k in offering nothing with a new version other than incompatibility with previous versions.
                                          Ummm Nik, did you not sign a NDA?
                                          • L
                                            linea
                                            I would love to see Autodesks monopoly to end but the reality is, if most of us suddenly did what you are suggesting, our client base would dwindle. I'm all for open standards but the dwg and dxf have a few years in them yet.
                                            SolidWorks Lab:
                                            By exporting your SolidWorks assembly in the Collada format.... Not only is your model geometry preserved in the export, but colors, textures and motion are available as well.
                                            Great, but a very large number of Autocad users are still just exchanging 2d plans.
                                            • 3 / 6
