    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
      Delacro
      this is amazing! Thankyou very much!
        Jackson
        It would make sense to upload it to Rapidshare or similar rather than as an SCF attachment and save the link in the first post embedded in the words
        "DOWNLOAD HERE" in BIG letters!
        Jackson
          mpowell1234567890
          I cannot get it to work, every time I try to use it, It causes a bugsplat and Sketchup terminates. Is there a way to fix it?
          • jwlyon1J Offline
            jwlyon1
            Wow. I've been using an older version for a month or so, but this one is amazing. Amazing...
            Macbook Pro/ iMac
            OSX 10.7.2 Sketchup 8
            rogue-z is here!
            • fredo6F Offline
              You need to be more accurate on how this happens.
              Which tool? Which situation?
                dondanev
                  MrPlanet
                  ๐Ÿ˜ฎ I think i've been using theone with just taper and FreeScale, but this is AMAZING! Thanks a lot, Fredo6, really helps in aircraft modelling ๐Ÿ˜„
                  I reject your reality and substitute my own.
                    bianhai
                    amazing. Amazing... ๐Ÿ‘
                    • fredo6F Offline
                      Thanks.
                      If anyone of the bbs community wishes to give a try for the chinese translation....
                      • szaniniS Offline
                        szanini
                        Thank you, thank you, thank you!!! and again thank you...
                          ccad
                          A wonderful plugin... What else... ๐Ÿ˜‰
                            RDailey
                            Fredo,
                            I can't seem to download your Fredoscale plugin in its' suppporting files. All I get where the plugin should be is:
                            You do not have the required permissions to view the files attached to this post.
                            Is there anywhere else I might be able to go to snag this plugin and its' supporting files.
                            R Dailey
                            • Jean-FrancoJ Offline
                              Jean-Franco
                              Dear R Dailey,
                              to see and download any files you must be a register member of this forum first.
                              Jean-Franco
                                Marla
                                Thank you very much Fredo for your plugin.
                                You're really a fantastic person ! ๐Ÿ˜„
                                ยฌ See Further, Never Give In. Whatever The Number Or The Task. ยฌ
                                  kenkan2
                                  i really want this plugin!! But i can't download the attachment....."You are not authorised to download this attachment"....WHY!!??
                                  • fredo6F Offline
                                    I guess you need to register and sign in to the forum.
                                      kenkan2
                                      i have already registered and sign in....otherwise i can't reply.....
                                      • fredo6F Offline
                                        Then it may be a problem with the forum itself, where unfortunately I cannot help.
                                          G DODDS
                                          where can I find a link to thecurrent FredoScale zip? (please!)
                                          • chonC Offline
                                            chon
                                            At the end of the first Fredo6's post of this thread i suppose... (2.0g version) ๐Ÿ˜‰
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 58
                                            • 59
                                            • 17 / 59
