    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 186.3k Views 51 Watching
    • PixeroP Offline
      Pixero
      Here is a mockup of a possible interface without a fancy web dialog.
      "Scale about" is same as current version.
      Should maybe change name to something like: "Origin"
        jsrocha
        Hi! first of all, great plugin!!
        i have a suggestion: is it possible to have an "aplly" button in the plugin interface? i mean, sometimes is good to play around with the settings, and when you hit "ok", if you want to play a little more, you have to go all the way down again and set everything again.....so, i think an aplly button will help a lot, because it wont close the plugin window, so you can change the settings and aplly them again in the same window!
        anyway, this is a very useful script, thanks a lot!
        regards from brasil,
        Jsrocha
          accabrera
          Thanks a lot Chris, amazing plugin!!!
          • Chris FullmerC Offline
            Muito obrigado amigos!
            @jsrocha I am learning how to use web dialogs, so once I get that down, I would be interested in trying to update some of these scripts to use them. One of the biggest benefits is the abilty to have an easier ability to implement things like you requested. I suppose I could do it without a webdialog, but it seems like it would be easier to control in a web dialog.
            @accabrera - Thanks, glad you like it!
            • utilerU Offline
              utiler
              [attachment=0:1zxmxinr]<!-- ia0 -->MockUp.jpg<!-- ia0 -->[/attachment:1zxmxinr]
              Great idea, Jan!!! Chris do you see this being implemented....?
              Cheers,
              Just Curious...
              • plot-parisP Offline
                plot-paris
                great things to come then... I can't wait to see what you are going to come up with πŸŽ‰
                  That's some good pressure πŸ˜„
                  Andrew, yeah if I can ever get around to these updates I dream of, that is something I would like to add.
                  • utilerU Offline
                    utiler
                    Cool, appreciated all you have done for SU workflow.... πŸŽ‰
                    Just Curious...
                    • X Offline
                      xrok1
                      now where's that bump button ❓
                        MartinRinehart
                        Chris, is it HTML, JavaScript or the linkage between these and Ruby (or all three)? I'm planning a frontal assault on the latter (rewrite Lininger but going much slower) which I could kick up to the front of the line. I've done HTML (http://www.easyHTMLtutorial.com) and am mulling on JS.
                        Martin
                          Hi Martin, I'm not even sure what it is that is holding me up. I don't know HTML at all. I don't JS at all. And I have no clue how they interact. So reading through JS tutorials leaves me confused because I don't understand what its doing tot he HTML. Reading through HTML tutorials seems to help the most currently. So I will gladly look over your HTML tutorial.
                            plot-paris
                            just a big THANK YOU!!! again, Chris.
                            you saved me about 15 minutes rotating and scaling a whole bunch of trees... 😍
                              DIEGO-RODRIGUEZ
                              hi Chris
                              I proposed an idea on the forum.
                              viewtopic.php?f=180&t=22569
                              If you have not seen her.
                              I think your plugins, could adapt well to the idea
                              interested? is possible?
                              greetings
                              • majidM Offline
                                majid
                                recently I saw this. thank you for generousity
                                  I just got a report that this might not be working right in 7.1!
                                  So if you use it and it moves components all over th place, instead of just scaling them, please let me know. I need to look into it.
                                  But otherwise I hope you find it useful πŸ˜„
                                    Can any Mac users verify if this script is working on SU 7.1? It appears to working great on Vista, SU 7.1 but I still have a report or two of it not working.
                                    Anyone have any example files where it is not working for them?
                                      SU 7.1M1, OSX10.4
                                      AΒ΄OK!
                                        Thanks Thom!
                                        I should mention what is not working for some, just in case you just verified it loaded.
                                        I have heard 2 or 3 reports of this plugin thoring components all over the place, instead of using their axes. It seems that for some, this plugin does not scale and rotate according to the specified axes.
                                        So if anyone still feels like testing further, awesome. Otherwise, I'll write a debugging version and give that to anyone who wants to test it out, see what is broken on their system.
                                        Thanks again,
                                          I just tried the random rotate and scale. That worked as expected. But if you have specific procedures that's reported to fail, then I can try that.
                                          • PixeroP Offline
                                            Pixero
                                            Yeah, I've seen that two times recently when using axis.
                                            When I choose component base everything was o.k. though. ❓
                                            • 6 / 7
