    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 211.3k Views 51 Watching
    • I Offline
      ideas_arte
      Thank you very much, in fact your plugin is very useful tools..!
      • plot-parisP Offline
        plot-paris
        fantastic tool, Chris. I like it a lot! 😍
        (how about an additional 'move' function? for offsetting each group/component...)
        • N Offline
          numerobis
          WOW! Very cool! Thank You!
          3ds max feeling in sketchup...
          • PixeroP Offline
            Pixero
            Great script, but may I suggest a few enhancements:
            I'd like to be able to rotate and/or scale randomly within a min to max value, a selection of components by a chooseable local axis. (I.E. each components axis.)
            This script only works on the global/world Z axis, right?
            Preferably the user should be able to choose X, Y or Z or any combination of them. And choose between Local or World axis.
            "Why would you want that?" you may ask.
            Well I've spent some time making trees and this would speed it up considerably.
            I can think of other uses as well... πŸ˜„
            Let me know if I need to explain better what I want.
            • Chris FullmerC Offline
              I think it might exist already, so correct me if you are thinking something more. If you select "axis" it will scale and rotate on each component's local axis.
              Does that do the trick?
              • PixeroP Offline
                Pixero
                Do you have the name of that plugin? Or do you mean you think its already in your script?
                Thats right but your script only rotates around the Z axis?
                I would like to be able to select x, y, z axis or any combination of them. Like three checkboxes one for each axis. Or a drop down menu.
                (It should still have Z axis as default.)
                And a checkbox for scale and one for rotation so you can have the script do just one of them or both in a easy to use way.
                If you want I could make a image explaining what I want.
                  Ahh, yes. That makes sense now. Correct. the script only rotates on the z axis.
                  Part of the problem with the checkboxes is that I would need to use web dialogs to make that work, and at this point, I have no clue how to do that. I could probably get all the options implemented using the default SU inputbox (expanding the current one), but that inputbox is very clunky and I don't love it. But I'll think about it and see if I can think of an easy way to get it all into the inputbox and not make it too overcrowded and difficult to understand.
                  If you'd like to mock up an image, that would be fine with me too! Thanks Jan, you've been a great help on this script,
                  • PixeroP Offline
                    Pixero
                    Here is a mockup of a possible interface without a fancy web dialog.
                    "Scale about" is same as current version.
                    Should maybe change name to something like: "Origin"
                      jsrocha
                      Hi! first of all, great plugin!!
                      i have a suggestion: is it possible to have an "aplly" button in the plugin interface? i mean, sometimes is good to play around with the settings, and when you hit "ok", if you want to play a little more, you have to go all the way down again and set everything again.....so, i think an aplly button will help a lot, because it wont close the plugin window, so you can change the settings and aplly them again in the same window!
                      anyway, this is a very useful script, thanks a lot!
                      regards from brasil,
                      Jsrocha
                        accabrera
                        Thanks a lot Chris, amazing plugin!!!
                          Muito obrigado amigos!
                          @jsrocha I am learning how to use web dialogs, so once I get that down, I would be interested in trying to update some of these scripts to use them. One of the biggest benefits is the abilty to have an easier ability to implement things like you requested. I suppose I could do it without a webdialog, but it seems like it would be easier to control in a web dialog.
                          @accabrera - Thanks, glad you like it!
                          • utilerU Offline
                            utiler
                            [attachment=0:1zxmxinr]<!-- ia0 -->MockUp.jpg<!-- ia0 -->[/attachment:1zxmxinr]
                            Great idea, Jan!!! Chris do you see this being implemented....?
                            Cheers,
                            Just Curious...
                              plot-paris
                              great things to come then... I can't wait to see what you are going to come up with πŸŽ‰
                                That's some good pressure πŸ˜„
                                Andrew, yeah if I can ever get around to these updates I dream of, that is something I would like to add.
                                • utilerU Offline
                                  utiler
                                  Cool, appreciated all you have done for SU workflow.... πŸŽ‰
                                  Just Curious...
                                  • X Offline
                                    xrok1
                                    now where's that bump button ❓
                                      MartinRinehart
                                      Chris, is it HTML, JavaScript or the linkage between these and Ruby (or all three)? I'm planning a frontal assault on the latter (rewrite Lininger but going much slower) which I could kick up to the front of the line. I've done HTML (http://www.easyHTMLtutorial.com) and am mulling on JS.
                                      Martin
                                        Hi Martin, I'm not even sure what it is that is holding me up. I don't know HTML at all. I don't JS at all. And I have no clue how they interact. So reading through JS tutorials leaves me confused because I don't understand what its doing tot he HTML. Reading through HTML tutorials seems to help the most currently. So I will gladly look over your HTML tutorial.
                                          plot-paris
                                          just a big THANK YOU!!! again, Chris.
                                          you saved me about 15 minutes rotating and scaling a whole bunch of trees... 😍
                                            DIEGO-RODRIGUEZ
                                            hi Chris
                                            I proposed an idea on the forum.
                                            viewtopic.php?f=180&t=22569
                                            If you have not seen her.
                                            I think your plugins, could adapt well to the idea
                                            interested? is possible?
                                            greetings
                                            • 2 / 7
