    [Code] ComponentInstance-add_entities v1.9
    33 Posts 5 Posters 24.5k Views 5 Watching
    • H Offline
      HPW
      I run into a problem when I use add_entities from a startup-ruby.
      The code line:
      @kombi_group_sel_def.instances[0].add_entities(@kombi_group_list)
      throws an error : undefined method `parent' for nil:NilClass
      My ruby (zAutostart.rb) loads after the ComponentInstance-add_entities.rb
      When I disable the call in my ruby and start the command from the console it runs without problems.
        Are you sure you have an instance of that definition in your model?
        • H Offline
          HPW
          Yes, because when I outcomment my call and type it in the console after start-complete it works.
          Therefor I build just a workaround:
           wsh = WIN32OLE.new('Wscript.Shell')
           if wsh.AppActivate(skpbasename+".skp - SketchUp")
            sleep(1)
            wsh.SendKeys('{F2}')
            sleep(1)
            wsh.SendKeys('convert_acad_import{ENTER}')
          Seems that ruby's on startup have problems to use other stuff from other startup-rubys.
            Hm.. maybe you're calling a ruby that isn't loaded. Have you added an require statement for all the rubys you depend on?
            • H Offline
              HPW
              Cannot be true, because the error come from inside the add_entities-code.
              Otherwise the error would tell about unknown method.
                Maybe things aren't ready immediately when SU loads the plugins...
                Have you tried using a timer to delay the execution of your script instead of having to send keystrokes`?
                • TIGT Online
                  require 'toggleWindows.rb' ?
                  • H Offline
                    HPW
                    I tried a 'sleep' with some diferent values without any success.
                    I had it yet for closing the outliner.
                    With my workaround it is working fine now.
                    (Automated DWG-Creation and SKP-Conversion(Acad-Blocks to SU-DC with non-editable prop) in a Batch process.)
                      sleep prevents everything else to process. If you use a timer you allow the rest to continue processing.
                      • TIGT Online
                        v1.7 is now available - now any Attribute Dictionaries the Definition might have are kept when the Definition is reworked with the new entities...
                        http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                        • H Offline
                          HPW
                          Using 1.7 instead of 1.6 gives me this error:
                          convert_acad_import
                          Error: #<NoMethodError: C:/Programme/Google/Google SketchUp 7/Plugins/ComponentInstance-add_entities17.rb:188:in add_entities': undefined method each' for nil:NilClass>
                          • TIGT Online
                            I've check it out...
                            School boy error ! Now fixed with v1.8...
                            • H Offline
                              HPW
                              Thanks for the quick fix.
                              Working correctly again!
                              • TIGT Online
                                Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=145009#p145009
                                Copies over Instance Attributes if copy making set...
                                • 2 / 2
