    [Plugin] Create 3d mesh from construction points... ver 1.0
    15 Posts 8 Posters 21.2k Views 8 Watching
    • I Offline
      ideas_arte
      This is very impressive, thank you very much! 😄
      • Chris FullmerC Offline
        Maybe a roadkill bunny that got squashed by a truck, so all its z values are the same? 😄
          kirill2008
          Well... Actually a rectangular (not necessary flat) bunny would be more suitable, I guess 😄.
          The initial 6000 points girl:
          http://pics.livejournal.com/lss2008/pic/0003htxh/s320x320
          Failed 'pnts2mesh.rb' test:
          http://pics.livejournal.com/lss2008/pic/0003gckr/s320x320
          Only rectangular hat is more or less succesful:
          http://pics.livejournal.com/lss2008/pic/0003f5eg/s320x320
          Well, the current algorithm is better when you've got few construction points and need to obtain a smooth rectangular piece of terrain (similar to the sandbox tool).
          http://pics.livejournal.com/lss2008/pic/0003k5dx/s320x320
          The plugin treats each construction point as a local extremum of the result surface.
          If the points cloud is quite dense, then Constrained Delaunay Triangulation (CDT) is more proper choice.
          • mitcorbM Offline
            mitcorb
            Hi, kirill2008:
            Thank you for this timely and very useful plugin.
            I am in the process of using it for a site topo.
            I hope you can refine the z precision. Currently, I am correcting z's by moving the geometry one by one. This probably affects the local surrounding slopes and elevations and produces a surface no more accurate than leaving the z's alone.
            You mentioned the Constrained Delaunay Triangulation. Is this available for use in Sketchup 6 or 7 through the User Interface?
            Thanks once again.
            mitcorb
              Hi Mitcorb,
              You could either use points_cloud_triangulation (if you already have the points imported) or Cloud_V6 (if you "only" have the xyz data). Practically, both use the same (Delaunay) triangulation method - at least as far as I know.
              • mitcorbM Offline
                mitcorb
                Thanks, Gaieus
                I will give these a look.
                I salute you for your tireless efforts.
                mitcorb
                  kirill2008
                  OMG, it's no good... I'll try to fix z calculation as soon as possible. But I guess you need to try alternative terrain generation tools also, because I doubt whether little (btw, experimental) plugin has enough power to perform complex topo site work.
                  Yes it is available. If you have terrain contours (horizontals), then you may try to generate triangulated surface from contours. It is one of "Sand box tool" (built-in) possibilities.
                  http://pics.livejournal.com/lss2008/pic/0003q03p
                    kirill2008
                    @jim said:
                    Need a test model?
                    I'm afraid 'pnts2mesh.rb' will fail in such test 😞
                    You see, plugin creates only rectangular 3d mesh and calculates only one z level for each x,y position. It has no enough power to process a bunny 😳
                    • mitcorbM Offline
                      mitcorb
                      OK, thanks.
                      I did not realize that Sketchup was already using these concepts in its standard tools.
                      That is what is so good about this forum.
                      By the way, I am merely experimenting with the plugin and I do realize that the original intention of Sketchup was to be a "quick" vizualization tool. Actually, doing the tedious knitting to tweak a model is a learning process in itself, and having gone through the process, I feel that my learning curve is beginning to level out a bit, as far as modeling goes. (still much to learn about ruby and rendering)
                      Thanks again, I am having fun.
                      mitcorb
                        kirill2008
                        I agreee. This forum keeps very friendly atmosphere as well and it's great 👍 and positive.
