    Randomness
    94 Posts 33 Posters 37.6k Views 33 Watching
      dolphus
      Marion do you know where i could get plans for that loco? sorry to hijack the thread โ“
        bahri
        very impresive model man....
        and very detailed....
        • MarianM Offline
          Marian
          I googled a bit, but couldn't find blueprints for it, it's based on an older electric locomotive, LE 5100, which was built in Romania under an ASEA Sweden licence.
          http://cfr.stfp.net/Pic/41/_B41-0001-2;1.jpg
          http://cfr.stfp.net/?la=E
          i bet you can modify it to turn it into the Phoenix.
          http://trainz.uv.ro/draw/loco/images/le_5100_gab1_w.jpg
          The Phoenix is probably too new, the first two were completed in 2008-2009. Some pictures of lights and clips of it in action here:
          http://forum.lokomotiv.ro/modules.php?name=Forums&file=viewtopic&t=3539&postdays=0&postorder=asc&start=75
          • urgenU Offline
            urgen
            ....very good modeling and texturing ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ... thanks!
            --pupil forever...------
            • MarianM Offline
              Marian
              Before leaving trains behind you should try making this one too, seems very similar to the old locos, Phoenix by Softronic Craiova , so no major modelling headaches, maybe just texturing wise.
              Keep up the good work mate ๐Ÿ‘
              http://www.gds.ro/poze-gds/97187maxim.jpg
                raduteo
                Thank you all.
                Carnotaurus WIP (I guess I have to rename the thread now) - about 60% done, the claws/teeth/eyes are next to be finalized.
                http://img218.imageshack.us/img218/6000/92589210.jpg
                Texture:
                http://img218.imageshack.us/img218/2049/71428258.jpg
                As aways, C&C is more than welcome.
                Thanks.
                • stefanqS Offline
                  stefanq
                  WOW! It's more and more obvious that you really are an artist. Respect!
                  • F Offline
                    fymoro
                    your modelling is perfect ๐Ÿ‘
                    http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                    • MarianM Offline
                      Marian
                      Man can't believe that's sketchup... ๐Ÿ˜ฎ
                      How about some wireframe shot.
                      VERY GOOD WORK ๐Ÿ‘
                        Jackson
                        Get the heck outta here! You can't tell me that's been textured in SU?..... and if so, HOW?
                        SCF really needs a "we're not worthy" smiley.
                        You should start a new thread for this so more people see it.
                        Jackson
                          Yeah, those texture images make one suspect another application (also) involved. Like with this sphinx in the WH - that image is definitely not a "plain" texture applied in SU. So what was your workflow here?
                          I wish SU had better texturing tools - and even plugins are very scarce.
                          And yes, indeed, I think both the locomotives (great job, BTW) and the dragon deserve their own topic. If you want, I can split the topic.
                            OK, thanks, Radu for explaining. This makes sense (and me less jealous for something I thought didn't know about SU)
                            ๐Ÿ˜„
                              raduteo
                              The texture was made in photoshop (obviously), however, the texture UVW mapping was made in Blender (it's free), you export your SU model as .3ds or .obj, spend 5-10 minutes creating the layout, export it from Blender and import it in SU as .3ds and the UV coords get carried through. Apart from the texture the model has applied to it a displacement map and bumpmap.
                              This is one of probably three dinosaur models that will populate my paleoscene.
                              Thanks.
                                raduteo
                                Indeed, would be great if SU would possess such a tool/plugin, I just wish I knew about it before I started projecting plane textures on the locomotive, it would of spared me 8 hours.
                                Also, there be no dragons herehttp://en.wikipedia.org/wiki/Carnotaurus
                                  No matter what wikipedia says, these monsters are dragons to me.
                                  ๐Ÿ˜ฎ
                                    Jackson
                                    Raduteo,
                                    Thanks for explaining that workflow, I'll have to take another look at Blender if it has such good UV mapping tools.
                                    Is this still rendered in V-Ray for SU? If so I'm suprised the UV mapping from the imported Blender mesh renders properly in V-Ray- I was led to believe by one of the developers that distorted maps in SU couldn't be "read" properly by render plugins.
                                    Jackson
                                      raduteo
                                      I had no idea there was such a problem/speculation, it works fine for me. However, remember not to go over 2048x2048.
                                      http://img442.imageshack.us/img442/2004/55603228.jpg
                                        dolphus
                                        Call me biased but this is not as impressive as your locomotives, but i can understand wanting to change....maybe ? ๐Ÿ˜’
                                          Jackson
                                          V-Ray can read any size of diffuse bitmap, so there's no reason you can't load a huge bitmap into SU and although it will be downsampled to 2048 x 2048 in the SU viewport, V-Ray will render it at full resolution.
                                          I'm intrigued about the UV mapping, it may only be SU's in-built UV mapping tool which doesn't work properly with render plugins.
                                          However much you prefer locomotives, how you could find anything negative to say about such incredible modelling and texturing is beyond me. ๐Ÿ˜’
                                          Jackson
                                            raduteo
                                            I have no idea, I'm probably the least experienced guy when it comes to those things, so far I'm pleased I didn't run into any problems.
                                            From a modelling standpoint any organic form is much harder to do than a locomotive for example, nevermind studying theropod anatomy and all the recent papers to have in the end a correct model, I'm sorry if I failed to deliver in your eyes. I don't quite understand the last part of your sentence.
                                            • 4 / 5
