    [Plugin] Selection Toys
    594 Posts 121 Posters 565.5k Views 121 Watching
      su30
      I have the same problem as CADfather had...
      I only use SU6, checked every plugins and found the problem in this script (Version1.12.0), It didn't happen before in lower versions.
      just after some open&close group action, the bug occurs, right-click menu Grey-out...
      so if you have any thing need me feedback, don't hesitate to tell me!
      su30
        Here's a debug version with the layer filters removed. Can the people that has experienced problems with the menu's try this and see if that solves the matter.
        Debug Version
        • CadFatherC
          CadFather
          Right on! ๐Ÿ˜„
          EDIT: seems to be working now.. i need to spend more time with it but the early signs are good.. Thanks Thom! (now you can go..) ๐Ÿ˜‰ ๐Ÿ‘
            su30
            I will try this version, if I have a problem I will feedback!
            su30
            • CadFatherC
              CadFather
              Hi Thom, wherever you are i confirm that it's working now - played for about an hour with a complex model and had no problems!!
              Thanks ๐Ÿ˜„
                Ok. It must be the number of dynamically created menus per layer that causes some kind of issue. I'll disable that feature and try to report it as a SU issue/bug.
                  Updated the plugin - an update that actually removes the layer filter features added in previous versions.
                  Seems that there might be issues with SU and too many menu items. The layer filters added two menu items per layer - something which quickly adds up. Not sure if it's an SU issue or Windows limitation, but removing this feature seem to clear up the reported issues.
                  Sorry for the inconvenience.
                  • CadFatherC
                    CadFather
                    Thank you Thom - this is one fine plugin..
                      Cheers.
                      I hope that I get the time at some point to rewrite it so the selections can also work as tools where you add/remove to the current selection. Letting you combine selection filters better. Though I'm not sure yet what the interface would be. I'm quite tempted to draw my own toolbar/menu/icons on the screen - inspired by Fredo's tools.
                      But at the same time I want to keep the plugin's current ability that you assign hot-keys to various filters. ...maybe some kind of macro system... Not really sure. It's a thinker.
                      • P
                        publied
                        what i can saying? thanks!
                        hire me@ http://www.publied.it !
                        • K
                          kwistenbiebel
                          Great work Tom!
                          I didn't have time to read through all the 9 pages of this thread ( ๐Ÿ˜ณ )....so I'll bluntly post my question: Does the plugin work in SU6?
                          I ask this because 'dynamic components',a typical SU7 feature, is part of the selection toys plugin...
                            It should work, yes. The DC filters simply checks the DC meta data stored in components, and that can be read in SU6.
                            • K
                              kwistenbiebel
                              Thanks Thomas!
                                su30
                                Yes it works well this version, I used it for a few days, and the grey out problem never happens again!
                                Thanks, Thomas
                                su30
                                  accabrera
                                  cool plugin!
                                    New selection tool to select a face's loops.
                                      Big speed improvement for most selection functions. Noticeable when dealing with large selections.
                                      Some functions are yet not optimized. I need some more time to ensure they work as they should. These are mostly functions related to connected geometry.
                                        Quad-face Loop works as expected. I tried to illustrate it with that gif animation. It selects connected faces and edges in a row.
                                        Can you illustrate your expected result?
                                        (You're not confusing it with the new Face Loop feature I just added? The new feature is accessed from the Tools menu. See comment over the first illustration.)
                                        • N
                                          NewOne
                                          Yes I did confused that two features! ๐Ÿ˜„ sorry. I like that feature. It saves me lots of clicks - and therefore it saves my mouse! ๐Ÿคฃ
                                            Got any suggestions for better names?
                                            They do have all too similar names - no wonder it leads to confusion.
                                            Maybe the new one should be named Select Edge Loops ?
                                            • 29
                                            • 30
                                            • 6 / 30
