    [Plugin] Selection Toys
    594 Posts 121 Posters 552.6k Views 121 Watching
      CadFather: do your model often have a high number of layers?
      • CadFatherC
        CadFather
        not that many - say 6 to 8 for a fairly complex model - i use groups/comps more
        (i'm still looking...no luck so far)
          You running many other applications?
          I'm wondering if this post has any clues to the menu issues: http://forums.sketchucation.com/viewtopic.php?f=180&t=20791#p175253
          • Bob JamesB
            Bob James
            @cadfather said:
            with all the gems in the folders we're in need of the 'new-spot-the-clash-finder-ruby-please'
            Amen, I'll definitely second that suggestion!!
            • CadFatherC
              CadFather
              i see, interesting.. though i never experienced Rick's behaviour (i don't usually have many apps running in the background)
              certainly i never saw an item re-appear.. would be nice to have a confirmation from google about ruby limits..
              seems to mean that if selection toys (for example) had less items the problem might temporarily disappear..
              i think the 'new-spot-the-clash-finder-ruby-please', if at all possible, would have to come from google.
                I'll make a deubg version for you, though, it'll have to be next week. I'm going away for a small trip.
                it's rather an impossible task. first you have to know what the "clash" is. Meaning you have to know exactly how everything is expected to work. can't see you can program that...
                • CadFatherC
                  CadFather
                  no hurry, enjoy your trip Thom..
                    su30
                    I have the same problem as CADfather had...
                    I only use SU6, checked every plugins and found the problem in this script (Version1.12.0), It didn't happen before in lower versions.
                    just after some open&close group action, the bug occurs, right-click menu Grey-out...
                    so if you have any thing need me feedback, don't hesitate to tell me!
                    su30
                      Here's a debug version with the layer filters removed. Can the people that has experienced problems with the menu's try this and see if that solves the matter.
                      Debug Version
                      • CadFatherC
                        CadFather
                        Right on! 😄
                        EDIT: seems to be working now.. i need to spend more time with it but the early signs are good.. Thanks Thom! (now you can go..) 😉 👍
                          su30
                          I will try this version, if I have a problem I will feedback!
                          su30
                          • CadFatherC
                            CadFather
                            Hi Thom, wherever you are i confirm that it's working now - played for about an hour with a complex model and had no problems!!
                            Thanks 😄
                              Ok. It must be the number of dynamically created menus per layer that causes some kind of issue. I'll disable that feature and try to report it as a SU issue/bug.
                                Updated the plugin - an update that actually removes the layer filter features added in previous versions.
                                Seems that there might be issues with SU and too many menu items. The layer filters added two menu items per layer - something which quickly adds up. Not sure if it's an SU issue or Windows limitation, but removing this feature seem to clear up the reported issues.
                                Sorry for the inconvenience.
                                • CadFatherC
                                  CadFather
                                  Thank you Thom - this is one fine plugin..
                                    Cheers.
                                    I hope that I get the time at some point to rewrite it so the selections can also work as tools where you add/remove to the current selection. Letting you combine selection filters better. Though I'm not sure yet what the interface would be. I'm quite tempted to draw my own toolbar/menu/icons on the screen - inspired by Fredo's tools.
                                    But at the same time I want to keep the plugin's current ability that you assign hot-keys to various filters. ...maybe some kind of macro system... Not really sure. It's a thinker.
                                    • P
                                      publied
                                      what i can saying? thanks!
                                      hire me@ http://www.publied.it !
                                      • K
                                        kwistenbiebel
                                        Great work Tom!
                                        I didn't have time to read through all the 9 pages of this thread ( 😳 )....so I'll bluntly post my question: Does the plugin work in SU6?
                                        I ask this because 'dynamic components',a typical SU7 feature, is part of the selection toys plugin...
                                          It should work, yes. The DC filters simply checks the DC meta data stored in components, and that can be read in SU6.
                                          • K
                                            kwistenbiebel
                                            Thanks Thomas!
                                            • 29
                                            • 30
                                            • 6 / 30
