    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 186.3k Views 51 Watching
    • PixeroP Offline
      Pixero
      @chris fullmer said:
      I think it might exist already, so correct me if you are thinking something more.
      Do you have the name of that plugin? Or do you mean you think its already in your script?
      If you select "axis" it will scale and rotate on each component's local axis.
      Thats right but your script only rotates around the Z axis?
      I would like to be able to select x, y, z axis or any combination of them. Like three checkboxes one for each axis. Or a drop down menu.
      (It should still have Z axis as default.)
      And a checkbox for scale and one for rotation so you can have the script do just one of them or both in a easy to use way.
      If you want I could make a image explaining what I want.
      • Chris FullmerC Offline
        Ahh, yes. That makes sense now. Correct. the script only rotates on the z axis.
        Part of the problem with the checkboxes is that I would need to use web dialogs to make that work, and at this point, I have no clue how to do that. I could probably get all the options implemented using the default SU inputbox (expanding the current one), but that inputbox is very clunky and I don't love it. But I'll think about it and see if I can think of an easy way to get it all into the inputbox and not make it too overcrowded and difficult to understand.
        If you'd like to mock up an image, that would be fine with me too! Thanks Jan, you've been a great help on this script,
        • PixeroP Offline
          Pixero
          Here is a mockup of a possible interface without a fancy web dialog.
          "Scale about" is same as current version.
          Should maybe change name to something like: "Origin"
            jsrocha
            Hi! first of all, great plugin!!
            i have a suggestion: is it possible to have an "aplly" button in the plugin interface? i mean, sometimes is good to play around with the settings, and when you hit "ok", if you want to play a little more, you have to go all the way down again and set everything again.....so, i think an aplly button will help a lot, because it wont close the plugin window, so you can change the settings and aplly them again in the same window!
            anyway, this is a very useful script, thanks a lot!
            regards from brasil,
            Jsrocha
              accabrera
              Thanks a lot Chris, amazing plugin!!!
                Muito obrigado amigos!
                @jsrocha I am learning how to use web dialogs, so once I get that down, I would be interested in trying to update some of these scripts to use them. One of the biggest benefits is the abilty to have an easier ability to implement things like you requested. I suppose I could do it without a webdialog, but it seems like it would be easier to control in a web dialog.
                @accabrera - Thanks, glad you like it!
                • utilerU Offline
                  utiler
                  [attachment=0:1zxmxinr]<!-- ia0 -->MockUp.jpg<!-- ia0 -->[/attachment:1zxmxinr]
                  Great idea, Jan!!! Chris do you see this being implemented....?
                  Cheers,
                  Just Curious...
                  • plot-parisP Offline
                    plot-paris
                    great things to come then... I can't wait to see what you are going to come up with πŸŽ‰
                      That's some good pressure πŸ˜„
                      Andrew, yeah if I can ever get around to these updates I dream of, that is something I would like to add.
                      • utilerU Offline
                        utiler
                        Cool, appreciated all you have done for SU workflow.... πŸŽ‰
                        Just Curious...
                        • X Offline
                          xrok1
                          now where's that bump button ❓
                            MartinRinehart
                            Chris, is it HTML, JavaScript or the linkage between these and Ruby (or all three)? I'm planning a frontal assault on the latter (rewrite Lininger but going much slower) which I could kick up to the front of the line. I've done HTML (http://www.easyHTMLtutorial.com) and am mulling on JS.
                            Martin
                              Hi Martin, I'm not even sure what it is that is holding me up. I don't know HTML at all. I don't JS at all. And I have no clue how they interact. So reading through JS tutorials leaves me confused because I don't understand what its doing tot he HTML. Reading through HTML tutorials seems to help the most currently. So I will gladly look over your HTML tutorial.
                                plot-paris
                                just a big THANK YOU!!! again, Chris.
                                you saved me about 15 minutes rotating and scaling a whole bunch of trees... 😍
                                  DIEGO-RODRIGUEZ
                                  hi Chris
                                  I proposed an idea on the forum.
                                  viewtopic.php?f=180&t=22569
                                  If you have not seen her.
                                  I think your plugins, could adapt well to the idea
                                  interested? is possible?
                                  greetings
                                  • majidM Offline
                                    majid
                                    recently I saw this. thank you for generousity
                                      I just got a report that this might not be working right in 7.1!
                                      So if you use it and it moves components all over th place, instead of just scaling them, please let me know. I need to look into it.
                                      But otherwise I hope you find it useful πŸ˜„
                                        Can any Mac users verify if this script is working on SU 7.1? It appears to working great on Vista, SU 7.1 but I still have a report or two of it not working.
                                        Anyone have any example files where it is not working for them?
                                          SU 7.1M1, OSX10.4
                                          AΒ΄OK!
                                            Thanks Thom!
                                            I should mention what is not working for some, just in case you just verified it loaded.
                                            I have heard 2 or 3 reports of this plugin thoring components all over the place, instead of using their axes. It seems that for some, this plugin does not scale and rotate according to the specified axes.
                                            So if anyone still feels like testing further, awesome. Otherwise, I'll write a debugging version and give that to anyone who wants to test it out, see what is broken on their system.
                                            Thanks again,
                                            • 7 / 7
