    Displacement Shapes
    renderpluginsextensions
    29 Posts 12 Posters 7.0k Views 12 Watching
    • soloS
      I used your map again this time with Vray, and an American flag as a diffuse map.
      It UV mapped it perfectly....hmmm.
      http://img20.imageshack.us/img20/9247/usflagdisp.png
      • N
        nomeradona
        excellent thread.
          AcesHigh
          Your image seens jagged... like if there was a small displacement map applied on top of the original displacement map. Look how much more "smooth" are the "turbine" images from TomTom.
          • N
            notareal
            I believe jaggin is result of ldr displacement map.
            • coulteriC
              coulteri
              Hey! That's great! 😄 Thom, could you tell me, how do you create displacement maps? Is it kind of software, that converts 3D object into the map?
              Thanks.
              Coulteri
                remus
                A displacement map is just a greyscale image (the sort of thing you can make in photoshop.) You then need a program which can use the displacement map, in thom's case, vray.
                • coulteriC
                  coulteri
                  Yes, I understand this. I just asked, if there is a method to create a displacement map from existing 3D object.... For example, if there is a ruby plugin, that is able to color the face according to its distance from zero position. Then it would be easy to export 2D raster and use it as a displacement map.
                    From Ruby it's not easy to read/write to image files. There seem to be a lack of code library to deal with the various formats.
                    Other 3D modelling packages have this kind of feature - though I think they mostly generate normal-maps instead of plain displacement maps. AFIK there isn't any tools like this for SU.
                    My experiment is pretty much the inverse of what you ask for - I just drew a grayscale shape in PS and experimented with what kind of shape it'd produce.
                      remus
                      I seem to remember reading it's because processing images is a relatively computationally intensive task, and ruby being relatively slow as it is isnt well suited to the task.
                        Well, that's one thing, it certainly won't be the quickest. But it doesn't has to be.
                        But the main issue is that file format other than the BMP format tends to be complex, especially when they compress the images. And if you don't find a good library that can read/write the formats that's supported on both platforms you have to do it yourself - learning the structure of the file format.
                        Speaking of this, I might see if I an make a class that handles the BMP format as it's one of the most straight forward formats out there.
                        • 2 / 2
