    Rounded Cubes
    12 Posts 8 Posters 5.8k Views 8 Watching
    • pcberdwinP Offline
      pcberdwin
      Here's a video tutorial I made that shows a way to make rounded cubes:
        Cool tutorial and obviously you are along the right ideas. 👍
        Certainly however, a couple of steps could be made easier. Just a tip (as an example); you seem to have problems with aligning things when moving them around the place (you also "mentioned" this in the video). When starting to move something, hit the left/right/up(or down) arrow keys on your keypad to lock the movement along a specific axis.
        OR when you finally succeed to get the movement along any desired direction (this doesn't have to be an axis), use the Shift key to lock the movement.
        • simon le bonS Offline
          simon le bon
          Hi pcberdwin,
          As usual with SketchUp, plenty of different solutions. (Dave one is really cool!!)
          This one, but i can tell others:
          (Re the Center square is for nothing here. It was for another purpose when I made those screenshots)
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_01_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_02_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_03_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_04_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_05_400x257.png
          Rotate+Copy(Ctrl) x3
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_06_400x257.png
          Select, Move a Copy (Ctrl)
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_07_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_08_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_09_400x257.png
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarSoapA_10_400x257.png
          😉 simon
          PS: and just like this to take a look: [Tutorial] Rounded Rectangle
            Interesting method. As Gai mentions, locking Move and Line directions will make things much easier.
            It does seem like a hard way to achieve a simple cube with rounded edges. You might also find the copy function of the Move tool interesting. It makes it easier to accurately place copies of a selection.
            Here's an alternative way.
            http://farm3.static.flickr.com/2482/3720053691_799cf0538b.jpg
            Draw a square to the finished size of the cube. Add a guideline (or even a guide point) to help set the corner radii.
            http://farm3.static.flickr.com/2537/3720053739_aafa4fedf2.jpg
            Use the Arc tool to draw the rounded corners. Start at the intersection of the guideline and the edge. Drag along the adjoing edge until the line turns magenta. Click and drag back along the edge toward the corner until the arc turns magenta. Click.
            http://farm4.static.flickr.com/3494/3720866048_4a55aacff5.jpg
            The other two corners can be done by inferencing off the first. Hover over the end point of the arc and slide the tool to the opposite side. Note the black dot at the end of the arc on the upper left corner.
            http://farm3.static.flickr.com/2630/3720866082_52e25cd701.jpg
            After completing the corner arcs, delete the unwanted part and the guideline.
            http://farm4.static.flickr.com/3453/3720866118_f0fed63143.jpg
            Select the rounded square and its edges (double click of selection tool) and get the Move tool. Hit Ctrl (Option on Mac) and copy the rounded square straight up.
            http://farm3.static.flickr.com/2618/3720866148_8d23c528e3.jpg
            Get the Rotate tool and rotate the copy into the vertical position. Orbit low if needed to get the required orientation. Note the red protractor color.
            http://farm4.static.flickr.com/3049/3720053903_631198df5c.jpg
            Make sure the rotated shape doesn't intersect with the original. Get the Move tool.
            http://farm3.static.flickr.com/2475/3720053939_dce6aba189.jpg
            Move the vertical face and its edges to the center of the horizontal face's edge. Once you start the move, in the green direction in this example, hold the Shift key to lock the direction. Or use the cursor keys to do that.
            Note: If I had moved the copy far enough up, I could have rotated it to the vertical position about the center of the edge. This would have eliminated the need to Move the face after rotating it.
            http://farm4.static.flickr.com/3274/3720054001_1a25cd3f58.jpg
            Get the selection tool and double click on the horizontal face. then get the Follow Me tool and click on the vertical face.
            http://farm3.static.flickr.com/2456/3720054025_a57ff16377.jpg
            Correct the face orientation if needed and delete the horizontal face. Done!
            With this method there are no edges to soften because the arcs were never exploded nor are there extraneous lines to remove.
            Of course now there's a plugin that can do this automatically after you've made a simple cube.
              simon le bon
              Well!!
              If you don't need a remaining square geometry , Dave's solution is very much faster and easy (and clever 😆 ). Because in mine you have to do cleaning work for unwanted inside faces and hide unwanted rounded square lines!!
              In case, I end the job like this: 😄
              http://lh3.ggpht.com/_ZMwXIS0611s/Sl2sb9UOMgI/AAAAAAAAA2k/r2PJ17YsxiU/s800/Square_Ending_550.jpg
              simon
              • david_hD Offline
                david_h
                There's a ruby that does all of this automatically. you can get it here.
                fillet 3d blocks
                Hope this helps.
                  I also alluded to a plugin that does it. You can get it here on SCF.
                  • Y Offline
                    Yanman
                    Good tips. Thank you. 👍 👍
                      Starling75
                      There is Fredos RoundCorner universal plugin for filleting edges...
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a&hilit=roundcorner
                      http://www.starlingarch.cz
                        Thanks Starling. It's the same as my link a couple of posts up. Very handy plugin, isn't it?
                          Starling75
                          Yes, very handy indeed. Fredos plugins are jewels.
                            mambo.harts.u
                            wow! very helpful!
