    External renders
    24 Posts 13 Posters 2.9k Views 13 Watching
      Sir
      wicked, the overall image seems... right πŸ‘
        davidh
        hi dylan
        ther are 3 images involved in post processing.
        1.a background with sky and mountains
        2.a main grass/field foreground
        3.misc grass elements in the foreground,blurred to give depth.
        I have collected a lot of images over the years which I use as a library - skies,grass,trees etc and I like to experiment with different ones.I have found that the same model with the same vray lighting can look completely different depending on the surroundings.
        • daleD
          dale
          Thanks for this post. I have been getting more frustrated with the look renderings using textures particularly on large expanses of ground. This is a very nice solution, and frankly one that I was working with a while back but let it go to try and resolve texture issues, which I never have. Thanks for the reminder.
            davidh
            hi dale,
            I was doing the exact same thing for a long time,trying to render out large expanses of foreground,particularly vegetation and usually found the time taken for rendering frustrating compared to the result.most of my renders now take about 15-20 mins on an Acer laptop 1.66GHz with 1GB of RAM.
            If I have an object intersecting with a large piece of foreground,I will normally just model the local area around the object to get context and post process the remainder ie. photoshopping grass trees etc.
            • EarthMoverE
              EarthMover
              Looks good. Why not post these all in one thread? It seems you have 4 threads all of the same model.
              Content Creator at Skapeup
              • daleD
                dale
                davidh
                Another thing you are doing that will make life easy in photoshop is giving those modeled definition colors that are stark monochrome, and easily identifiable in photoshop.
                  davidh
                  Im sorry for not posting all in one thread,this was my first post and was trying to find my feet.
                  apologies
                    davidh
                    Again apologies for posting in different threads,
                    What i am trying to do is show the difference between basic vray output and post processing.
                    Certain models lend themselves to basic modeling but sometimes extra processing
                    lends itself to a particular project.
                    some of my images have disappeared,I hope I am not overstepping the mark by attaching them here?
                    comparison 01
                    comparison 02
                    comparison 03
                      davidh
                      some additional external renders with a different building,modeled in sketchup and rendered in vray
                      • erikBE
                        erikB
                        davidh,
                        great PP. The sence of reality from the entourage gets picted up by the mind and carried over to the rendered model.
                        Nice work !
                        erikB
                        • olisheaO
                          olishea
                          great work, some useful advice too. well done
                          oli
                            steelers05
                            When you look at the straight rendering output for some of these, Im not gonna lie, they just seem kind of ...ahhh. But when you see how you take the images and composite them into your scenes, they look really great and the renderings make more sense. I mean the buildings are fairly simple in design so I guess the straight outputed renderings really dont give you much room to impress, but you surely do impress with your final images. Keep up the good work.
                            • broomstickB
                              broomstick
                              Yes, I still find PS is key in the reality of a render, especially if you want to keep rendering times low.
                              I really like your shots, you have a nice eye to depth of field... I will try to add out of focus grass in my next works πŸ˜„ πŸ˜„
                                davidh
                                attached are some similar images but with different post processing.
                                  davidh
                                  attached is the foreground image for the first of the overcast images above.(normally i use the clone brush in photoshop to copy to the rendered vray image)
                                  • olisheaO
                                    olishea
                                    wow...that first image of this page looks real.
                                    I honestly couldn't tell it was a render at first! nicely done.
                                    I agree, if you want low render times....you gotta do a lot of PP like this. But the end result is astonishing so how you get there doesn't really matter πŸ‘
                                    oli
                                    • plot-parisP
                                      plot-paris
                                      great work, David. you are truely a master of photoshop! the first image of your last post is absolutely convincing (the second one isn't πŸ˜‰ ).
                                      a slightly off topic question: how do you structure your reference image library? I am a very messy person and always had difficulties keeping things ordered... you could really help me there.
                                        davidh
                                        I have a considerable reference library(4.5GB!)and I have spent the last few years adding to it and revising the structure,moving images and creating new folders/directories.Attached is a screensnap showing the current setup.some of these folders have subfolders and I am sure I'll be adding new ones soon.
                                          rcossoli
                                          excellent work, and collection of textures
                                          you've never worked with photomatch of skethchup your models to integrate the environment?
                                          THREEDIMENSIONSWEB dot COM
                                            davidh
                                            the original render is no great shakes but these are just some exercises in playing with depth of field and photoshop
