    External renders
    24 Posts 13 Posters 2.9k Views 13 Watching
    • erikBE
      erikB
      davidh,
      great PP. The sence of reality from the entourage gets picted up by the mind and carried over to the rendered model.
      Nice work !
      erikB
      • olisheaO
        olishea
        great work, some useful advice too. well done
        oli
          steelers05
          When you look at the straight rendering output for some of these, Im not gonna lie, they just seem kind of ...ahhh. But when you see how you take the images and composite them into your scenes, they look really great and the renderings make more sense. I mean the buildings are fairly simple in design so I guess the straight outputed renderings really dont give you much room to impress, but you surely do impress with your final images. Keep up the good work.
          • broomstickB
            broomstick
            Yes, I still find PS is key in the reality of a render, especially if you want to keep rendering times low.
            I really like your shots, you have a nice eye to depth of field... I will try to add out of focus grass in my next works πŸ˜„ πŸ˜„
              davidh
              attached are some similar images but with different post processing.
                davidh
                attached is the foreground image for the first of the overcast images above.(normally i use the clone brush in photoshop to copy to the rendered vray image)
                • olisheaO
                  olishea
                  wow...that first image of this page looks real.
                  I honestly couldn't tell it was a render at first! nicely done.
                  I agree, if you want low render times....you gotta do a lot of PP like this. But the end result is astonishing so how you get there doesn't really matter πŸ‘
                  oli
                  • plot-parisP
                    plot-paris
                    great work, David. you are truely a master of photoshop! the first image of your last post is absolutely convincing (the second one isn't πŸ˜‰ ).
                    a slightly off topic question: how do you structure your reference image library? I am a very messy person and always had difficulties keeping things ordered... you could really help me there.
                      davidh
                      I have a considerable reference library(4.5GB!)and I have spent the last few years adding to it and revising the structure,moving images and creating new folders/directories.Attached is a screensnap showing the current setup.some of these folders have subfolders and I am sure I'll be adding new ones soon.
                        rcossoli
                        excellent work, and collection of textures
                        you've never worked with photomatch of skethchup your models to integrate the environment?
                        THREEDIMENSIONSWEB dot COM
                          davidh
                          the original render is no great shakes but these are just some exercises in playing with depth of field and photoshop
                          • P
                            Pg09
                            Thanks for sharing!
                              Rob D
                              David
                              These are fabulous examples. How long did it take you to clip round the leaves?
                              • 2 / 2
