    How can I make a letter rounded?
    31 Posts 6 Posters 7.6k Views 6 Watching
    • ely862meE
      ely862me
      😆 actually is very simple..
      i ll give u 3 hints: offset tool,skin tool and scale tool
      Elisei (sketchupper)
      Come and See EliseiDesign
        My PC works hard to make SU running, and I can't even think to run a modeler on it
        Are you joking? 😮
        My Pc is a seven year old! And all works very fine on it! 😎
        I have just progs who don't ask too many things to the video card!
        Zbrush, Moi, Su, Blender 😉
        PS SU is also a modeler! ☀
        PS2 What happen when a render is made with these "horrible lines"?
        • simon le bonS
          simon le bon
          Hey Hey Helisei,
          You show too much or you explain not enough 😛
          You are waiting I find by myself I suppose. Not a lot of time again for that these next days..
          You are right. S&S works well on the letter shape you have redraw.
          but:
          1_ How did you do to make the base of the letter correctly flared ??
          2_ How did you do to redraw all the lines of the letter shape: by hand??
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_W_450.jpg
          I can see I have still a lot to learn on S&S. This another technic for exemple find me with the tong out of my mouth:Contest Winner: Modelling a Panton Chair with Subdivide and Smooth
          Thanks to participate,
          simon . . . . . .and theSlideshow(each link is the same updated one)
          PS: Your cars are crazy beautiful man 👍
          • simon le bonS
            simon le bon
            Hi ely862me
            Take the model as in image 3 or 4 and run Subdivide&Smooth on it..u ll get the desired result
            I'm afraid I don't understand the way you think about!
            I've tried this time, not the subdivide+smooth operations like before but the modeler operation as i can think you are talking about, and the result is the following, after what i can't go further.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_P_450.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_Q_450.jpg
            Dear Gaieus,
            One more time you're right! I can't say I didn't know what you're talking, about cleaning unwanted geometry. But i thought in this case that it was not necessary to clean because there was no faces joining. As we can see, I was wrong 😄
            Adendum about this subject:Creating a Hidden Seam in Google SketchUp by Eric Lay(Boofredlay).
            After cleaning:
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_R_450.jpg
            This time it looks ok 👍
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_S_450.jpg
            and i'm afraid this is my ultimate best
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_T_450.jpg
            Updated slideshow
            simon
            • simon le bonS
              simon le bon
              @ely862me said:
              :lol: actually is very simple..
              Very simple? No I wouldn't say that. In fact I haven't found how to make exactly the good flare I wanted (the same as yours). And I would have please (now I have searched 😉 ) more precisions from you on the way you've mastered it.
              • A very important thing I have learned here is that: an offset doesn't give the same outer edge than a scale??(really a surprise to me) this is the reason why I was not able to do the right flare using scale tool and FredoScale!!
              • No need to redraw all the lines, there is a cleaning module in Skin.rb
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WA_450.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WB_450.jpg
              A check with S&S
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WC_450.jpg
              "Very important"
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WD_450.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WE_450.jpg
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WF_450.jpg
              (I have let down momentarily what I had begun whith Gaieus and I will retake it soon.)
              simon
              • simon le bonS
                simon le bon
                Ok Elisei, you seem to be occupied. I can't wait you to follow my idea. (It would be great and friendly if you would give us a little step by step further explanation)
                I start from your shape.
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WFB_450.jpg
                I need to subdivide the top of the letter. I'm using SandBox tool: from contour.
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WG_450.jpg
                Now using SkechyFFD to put some irregularity to the letter (I glue the bottom points)
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WH_450.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WI_450.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WJ_450.jpg
                (Note this other try with modeler from SandBox Tools.)
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WK_450.jpg
                Finally, with a ShapeBender treatment:
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WL_450.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WM_450.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WN_450.jpg
                not to bad for me 😉
                Slideshow
                ___
                [Plugin] SketchyFFD by CPhillips
                [Plugin] Shape Bender by Chris Fullmer
                simon.
                • ely862meE
                  ely862me
                  after making the shape with offset and skin i scale it but not all, just the outer lower profile . When u scale all lower profile the inside part of the letter is scaled too, so ,u want it to be smaller but u get it bigger(so it becomes bigger than the up part of the letter), what u need is to scale just the outer lower part of the letter
                  • simon le bonS
                    simon le bon
                    A last try for another method using Terrain Reshape and afterward Randomize TIN
                    The idea: apply the process on a very low shape and scale it after. I'm starting from the offseted and skined shape from Elisei. The result is not bad but S&S do very better. Its job isn't really for that kind of thing.
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XG_450.jpg
                    I still follow what was Planned:
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XH_450.jpg
                    The result is beautiful but far from what I expect. I keep it in mind... 😉
                    Slideshow
                    Re I shall update with a link as soon as I shall have made a tutorial with this 😉
                    I think: End of the topic!!! Thanks to all
                    😎 Simon
                    • ely862meE
                      ely862me
                      yet, u didn t get all the point..u need to make scale from center and select more geometry from the letter
                      Btw..i didn t subdivide the top and letter together because as u can see when u subdivide them together the top becomes messy ,if u look at it with hidden geometry off
                      Elisei
                      • simon le bonS
                        simon le bon
                        Hi Elisei,
                        hey hey!! You don't give up so easily 👍
                        -) Allright I was a bit modest with the lines I was scaling. What you do certainly works well.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XJ_450.jpg
                        I put at the end My last "R" (in french "l'air de la plage": a pretty bad wordgame hi!) in which I have hardly scale, redraw, modify the outlines.
                        -) I prefer rather than you, doing all this job on the same plane before elevate and skin process.
                        -)Messy, yes it is , but I don't understand you because:
                        1-with hidden geometry off, the look is perfect without any seam line remaining.
                        2-when I subdivide independantly the top, this one doesn't fit exactly well.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XL_450.jpg
                        3-I haven't found one method which give not a "messy result".
                        4-the subivision is enough to use SketchyFFD pretty well.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XK_450.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XM_450.jpg
                        Enough of the "G" Here is the "R"
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XN_450.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XO_450.jpg
                        ++simon
                        • simon le bonS
                          simon le bon
                          Hi Elisei,
                          I was not fool: Very simple but your hidden trick 😆
                          At the end the entire solution is from you!! Thanks and bravo: I have learned. I'm going to make a tutorial to simplify the process; shared with your name.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XA_450.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XB_450.jpg
                          Partial Scale. Re: to simplify, I have removed the original letter's line
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XC_450.jpg
                          three scales. The yellow and blue figure is the basic one. I put it just to consider the scales ❗
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XD_450.jpg
                          And now I get it Myself
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XE_450.jpg
                          I come back on my previous post. No need to subdivide independantly the top of the letter. Just integer it in S&S modeler's process 💭
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XF_450.jpg
                          simon
                          • simon le bonS
                            simon le bon
                            @alan fraser said:
                            I know that SU now has its own 3D text tool, but that tool is fairly basic. Don't forget the solution of choice before the built-in option (or the Smustard Ruby)
                            Elefont will automatically add a variety of bevels and chamfers that can be exported in dxf and brought into SU.
                            http://www.armanisoft.ch/webdesign/elefont/Elefont.html
                            Dear Alan,
                            I have found time to test this "Elefont" from "Ingenieurbüro" Armin Müller you were talking about.
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Elephantroselunette.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Elefont_001_550.jpg
                            This last 1.4 version dated from 7July 1998 begin to be may be a little outdated 😕 . It is not too much handy because its display is very small and the previsu doesn't give a great control.
                            But in making small tries, we can do number of interesting variations. At the end the saving format in DXF is perfect to import in SketchUp. 👍
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Elefont_002_550.jpg
                            These subdivided letter shapes are perfect to use directly with S&S , avoiding the previous Offset, Scale and Skin stages 👍
                            I have tried to reach my goal: the molted letter.
                            In taking the letter at this stage, making a real flare isn't possible (?) anymore. So if we satisfied with the approximative Scaled flare, it is OK.
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Elefont_003_550.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Elefont_004_550.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Elefont_005_550.jpg
                            😉simon
                            • 2 / 2
