    How can I make a letter rounded?
    31 Posts 6 Posters 7.6k Views 6 Watching
    • simon le bonS
      simon le bon
      @gaieus said:
      ../ So basically you need the
      • complex, rounded shape to start with
      • but then put some kind of "slight" irregularity into it like it is achieved with glass when being manufactured?
      You are right 😛 I hadn't thought things in these two steps but you are right. In fact, as Pilou said also in his way, i need a modeler!
      I was searching for a tool or a regular way to do the job without to much effort 😆
      I have tried to show what could SoapSkin&Bubble be if it was working with two different ringed curves. If it was the case a lot of new things could be done. 👍
      So i have used Skin.rb then a subdivide operation with Subdivide&Smooth and after what a "Bubble" operation whith SketchyFFD.
      Ok the result isn't very beautiful but we can see the idea, isn't it?
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_X_450.jpg
      As you can see with my "G" (from "Gaieus" as well as "Good Old Rum" 😆 ) after I smooth it, it still remains the presence of some hidden lines which are not very beautiful.. I don't know what to do with them.
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_O_450.jpg
      Dear Pilou! I admire the way you take things and work on them! Thanks for all those exemples. Unfortunatly, I havn't the first knowledge of even one modeler. My PC works hard to make SU running, and I can't even think to run a modeler on it 😠 (It is planned i get a war-machine nextly)
      **simon
      • simon le bonS
        simon le bon
        Cher Pilou,
        Are you joking? 😮
        unfortunately i am not. When the poly count increase, and we know how it goes up easily whith modeler tools, every operation begin to be painful. I also fight a lot to make screen casts at the same time. Perhaps have I too much rubys installed: i don't know technically the impact.
        I have just progs who don't ask too many things to the video card!
        Zbrusch, Moi, Su, Blender 😉
        PS SU is also a modeler! ☀
        To tell the truth i ever been so sure that my PC couldn't that I have never tried to install one of those modeler/renderer. In fact, it is possible i am wrong ! 😕 Perhaps i could try MOI which find your great approbation 😉
        PS2 What happen when a render is made with there "horrible lines"?
        I don't know how eliminate them in SU , and i don't know how a renderer treats them..
        **s
        • ely862meE
          ely862me
          Take the model as in image 3 or 4 and run Subdivide&Smooth on it..u ll get the desired result 😉(with some more tweaking)
          Elisei (sketchupper)
          Come and See EliseiDesign
          • GaieusG
            Simon,
            With those "horrible" lines there, isn't there a (maybe even hidden) face inside the model? (A follow me operation would cause a face/bent surface all along)
            • GaieusG
              OK, glad it worked. 👍 (it was just a shy guess actually because I was also suspecting you knew there should be a face)
              Anyway, There is a nicely rounded, beautifully smooth character/letter/font/police there now. It is however very high poly I think and even has many polygons here and there much denser than elsewhere so what we should do now is to make the mesh more "average" (and probably "less poly" where it's not needed) with Didier Bur's Terrain Reshaper plugin. You can experiment with it; how high or low poly you want it to appear. Maybe it won't work nicely on the vertical surfaces but will also triangulate the mesh (needed for the next step).
              Then comes Jim Foltz' Randomize TIN plugin with which you can easily give a bit of "irregularity" into the mesh - also, with the desired value.
              Note that I hevn't tried the method; just "thinking loud".
              • simon le bonS
                simon le bon
                I follow you dear Gaieus,
                I've tried Didier Bur's[Plugin]: Terrain Reshaper you advise to me. After a couple of tests the result promises to be encouraging.
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_U_450.jpg
                the begining of cleaning.
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_V_450.jpg
                I must stop here for the moment. I leave the place for a couple of days and be back soon for the continuation of your process.. 😉
                😎 **s
                • ely862meE
                  ely862me
                  may i have the letter..save it in skp 6 please
                  Elisei
                  • simon le bonS
                    simon le bon
                    Dear Elisei,
                    Here is my (SU6) Skp (I'm sorry not to much organized working one) DivShare File - RoundedLetter.skp
                    Please take your time because again, some few days not far from a couple of weeks are going to take me away from house (from my PC 😆 ). So I'm going to be not very active in this trhead until i'll be back .
                    ...// 😎 simon
                    • ely862meE
                      ely862me
                      sds is good but u need to know how to use it 😉
                      RoundedLettera.skp
                      • ely862meE
                        ely862me
                        😆 actually is very simple..
                        i ll give u 3 hints: offset tool,skin tool and scale tool
                          Are you joking? 😮
                          My Pc is a seven year old! And all works very fine on it! 😎
                          Zbrush, Moi, Su, Blender 😉
                          PS2 What happen when a render is made with these "horrible lines"?
                          • simon le bonS
                            simon le bon
                            Hey Hey Helisei,
                            You show too much or you explain not enough 😛
                            You are waiting I find by myself I suppose. Not a lot of time again for that these next days..
                            You are right. S&S works well on the letter shape you have redraw.
                            but:
                            1_ How did you do to make the base of the letter correctly flared ??
                            2_ How did you do to redraw all the lines of the letter shape: by hand??
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_W_450.jpg
                            I can see I have still a lot to learn on S&S. This another technic for exemple find me with the tong out of my mouth:Contest Winner: Modelling a Panton Chair with Subdivide and Smooth
                            Thanks to participate,
                            simon . . . . . .and theSlideshow(each link is the same updated one)
                            PS: Your cars are crazy beautiful man 👍
                            • simon le bonS
                              simon le bon
                              Hi ely862me
                              I'm afraid I don't understand the way you think about!
                              I've tried this time, not the subdivide+smooth operations like before but the modeler operation as i can think you are talking about, and the result is the following, after what i can't go further.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_P_450.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_Q_450.jpg
                              Dear Gaieus,
                              One more time you're right! I can't say I didn't know what you're talking, about cleaning unwanted geometry. But i thought in this case that it was not necessary to clean because there was no faces joining. As we can see, I was wrong 😄
                              Adendum about this subject:Creating a Hidden Seam in Google SketchUp by Eric Lay(Boofredlay).
                              After cleaning:
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_R_450.jpg
                              This time it looks ok 👍
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_S_450.jpg
                              and i'm afraid this is my ultimate best
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_T_450.jpg
                              Updated slideshow
                              simon
                              • simon le bonS
                                simon le bon
                                @ely862me said:
                                :lol: actually is very simple..
                                Very simple? No I wouldn't say that. In fact I haven't found how to make exactly the good flare I wanted (the same as yours). And I would have please (now I have searched 😉 ) more precisions from you on the way you've mastered it.
                                • A very important thing I have learned here is that: an offset doesn't give the same outer edge than a scale??(really a surprise to me) this is the reason why I was not able to do the right flare using scale tool and FredoScale!!
                                • No need to redraw all the lines, there is a cleaning module in Skin.rb
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WA_450.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WB_450.jpg
                                A check with S&S
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WC_450.jpg
                                "Very important"
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WD_450.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WE_450.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WF_450.jpg
                                (I have let down momentarily what I had begun whith Gaieus and I will retake it soon.)
                                simon
                                • simon le bonS
                                  simon le bon
                                  Ok Elisei, you seem to be occupied. I can't wait you to follow my idea. (It would be great and friendly if you would give us a little step by step further explanation)
                                  I start from your shape.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WFB_450.jpg
                                  I need to subdivide the top of the letter. I'm using SandBox tool: from contour.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WG_450.jpg
                                  Now using SkechyFFD to put some irregularity to the letter (I glue the bottom points)
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WH_450.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WI_450.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WJ_450.jpg
                                  (Note this other try with modeler from SandBox Tools.)
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WK_450.jpg
                                  Finally, with a ShapeBender treatment:
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WL_450.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WM_450.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_WN_450.jpg
                                  not to bad for me 😉
                                  Slideshow
                                  ___
                                  [Plugin] SketchyFFD by CPhillips
                                  [Plugin] Shape Bender by Chris Fullmer
                                  simon.
                                  • ely862meE
                                    ely862me
                                    after making the shape with offset and skin i scale it but not all, just the outer lower profile . When u scale all lower profile the inside part of the letter is scaled too, so ,u want it to be smaller but u get it bigger(so it becomes bigger than the up part of the letter), what u need is to scale just the outer lower part of the letter
                                    • simon le bonS
                                      simon le bon
                                      A last try for another method using Terrain Reshape and afterward Randomize TIN
                                      The idea: apply the process on a very low shape and scale it after. I'm starting from the offseted and skined shape from Elisei. The result is not bad but S&S do very better. Its job isn't really for that kind of thing.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XG_450.jpg
                                      I still follow what was Planned:
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XH_450.jpg
                                      The result is beautiful but far from what I expect. I keep it in mind... 😉
                                      Slideshow
                                      Re I shall update with a link as soon as I shall have made a tutorial with this 😉
                                      I think: End of the topic!!! Thanks to all
                                      😎 Simon
                                      • ely862meE
                                        ely862me
                                        yet, u didn t get all the point..u need to make scale from center and select more geometry from the letter
                                        Btw..i didn t subdivide the top and letter together because as u can see when u subdivide them together the top becomes messy ,if u look at it with hidden geometry off
                                        Elisei
                                        • simon le bonS
                                          simon le bon
                                          Hi Elisei,
                                          hey hey!! You don't give up so easily 👍
                                          -) Allright I was a bit modest with the lines I was scaling. What you do certainly works well.
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XJ_450.jpg
                                          I put at the end My last "R" (in french "l'air de la plage": a pretty bad wordgame hi!) in which I have hardly scale, redraw, modify the outlines.
                                          -) I prefer rather than you, doing all this job on the same plane before elevate and skin process.
                                          -)Messy, yes it is , but I don't understand you because:
                                          1-with hidden geometry off, the look is perfect without any seam line remaining.
                                          2-when I subdivide independantly the top, this one doesn't fit exactly well.
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XL_450.jpg
                                          3-I haven't found one method which give not a "messy result".
                                          4-the subivision is enough to use SketchyFFD pretty well.
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XK_450.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XM_450.jpg
                                          Enough of the "G" Here is the "R"
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XN_450.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XO_450.jpg
                                          ++simon
                                          • simon le bonS
                                            simon le bon
                                            Hi Elisei,
                                            I was not fool: Very simple but your hidden trick 😆
                                            At the end the entire solution is from you!! Thanks and bravo: I have learned. I'm going to make a tutorial to simplify the process; shared with your name.
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XA_450.jpg
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XB_450.jpg
                                            Partial Scale. Re: to simplify, I have removed the original letter's line
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XC_450.jpg
                                            three scales. The yellow and blue figure is the basic one. I put it just to consider the scales ❗
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XD_450.jpg
                                            And now I get it Myself
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XE_450.jpg
                                            I come back on my previous post. No need to subdivide independantly the top of the letter. Just integer it in S&S modeler's process 💭
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ThickLabel_XF_450.jpg
                                            simon
