    Move groups with different measures?
    55 Posts 4 Posters 33.5k Views 4 Watching
      @Tig
      I have the "Web console" so no problem for copy/ past and launch it
      Seems your plug move all selection of groups, but not each by each ๐Ÿ˜„
      Result stay grouped without interval
      What is precisely this "14" value?
      ( i have just 5 group and one component (Bryce) for the moment and just 3 selected for the test ๐Ÿ˜‰
      Why not take the first value of the array?
      The ThomThom method works except that woks for the 5 groups and not only for the selection ๐Ÿ˜„
        SU always uses inches internally.
        If you want 100mm type 100.mm . See http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/numeric.html for more units.
          model = Sketchup.active_model
          entities = model.entities
          selection = model.selection
          groups = []
          z=0
          selection.each do |e| # update!
            # Skip all entities that aren't groups
            next unless e.is_a? Sketchup;;Group
            # Now we process the groups
               point = Geom;;Point3d.new 0,0,z
            t = Geom;;Transformation.new point
            # Apply the transformation
            e.transform!(t)
            z = z*2 + 100
          Perfect ๐Ÿ‘ (I put the z=z*2+100 at the end for have the first group of selection with no move)
          Last thing I obtain 254 cm ( I suppose that is a conversion between inch/cm ?)
          My first volume is at level z = 0 and I work in cm
            Pilou
            Do you want to move each of the selected groups by the same amount (my code - e.g. 100.mm) or by an ever changing amount ?
            If you want it to change then you need to define how, and add this into the loop - e.g. z=1..... then loop... z += 2*z
            exponential type increase !
            If you are applying different offsets, and you have made the groups in order, then the increments will apply in that way; but it would be possible to 'stack' groups made at different times and the loop would process then in their made order, but not the 'stacked' order you want ! Perhaps you need to add in another test... for each of the group.bounds.min.z. which sorts them by their relative heights, so at least the groups array would be in the height order you expect...
              Yes! Works like a charm! โ˜€
              For my first one that was not like a true romance but with your help, ThomThom, Tig (yet a lot of cryptic for me ๐Ÿ˜„, and the Chris tutorial and a dash of milk of Tod Burch
              Many thx for the helps ๐Ÿ˜Ž
              Next will maybe an "explode view" of several groups ๐Ÿ˜„
              Just need to know position of a group ๐Ÿ˜„
              PS @ Tig Sorry but I had no chance with yours! (see previous page) ๐Ÿ˜ฒ
              And yes I want any sort of increments so now I can have any sort of it! Thx! โ˜€
              Just play with parameters ๐Ÿ˜„
              I keep your group.bounds.min.z. trick in my mind!
                for a completely random offset try
                    ###point = Geom;;Point3d.new 0,0,(1000.mm * rand)
                    ### offset in Z somewhere between 0m and 1m - 'rand' makes a random number 0><1
                    point = Geom;;Point3d.new (1000.mm * rand),(1000.mm * rand),(1000.mm * rand)
                    ### offset in all XYZ axes by 0 to 1m
                    e.transform!(t)
                Swap the ### between the different points = to see the effect
                  The entities are not returned in their order in z height. You would need to sort the objects by their Z position before applying the transformations.
                    Before testing your new randomizer plug ๐Ÿ˜„
                    I have a little problem ๐Ÿ˜„
                    I have used "Grow" by Tig for make the "volume" on the left (50 groups), then my "Plug" Thomthomised ๐Ÿ˜’
                    with a normal interval of course!
                    Seems there is something wrong somewhere ๐Ÿ˜ฎ
                    Groups are not recorded following the "grow" generation?
                      So i must use the Tig Advertissement more soon than I have expected ๐Ÿ’š
                        This group.bounds.min.z. can be found somewhere or the sorting of Groups must be forged again?
                        (nothing about sort, sorting in the API helping) ๐Ÿ˜ฎ
                          Build a hash with the entities as the key and their Z posiiton as value and then sort the hash by the values.
                            Each groups has not a "time creation" trace board? So no need to remake a sorting ?
                            Seems I have re-open a new nightmare door ๐Ÿ’š
                            • Chris FullmerC
                              Awesome Pilou! Keep it up, its looking great. You've got lots of good help around here.
                                Try something like...
                                zeds=[]
                                index=0
                                groups.each{|group|
                                   zeds.push(group.bounds.min.z, index)
                                   index+=1
                                zeds.sort!
                                sorted_groups=[]
                                zeds.each{|z|sorted_groups.push(groups[z[1]]) }
                                ### sorted_groups is now groups sorted by Z
                                  Does the group.bounds.min.z only valuable in SU 7?
                                  Edit seems not ๐Ÿ˜„
                                  little try but seems I miss something ๐Ÿ˜„ (any doubt selection but the sorted_groups gives nothing on the screen)
                                  groups = []
                                  z=0
                                  zeds=[]
                                  index=0
                                  groups.each{|group|
                                     index+=1
                                  zeds.sort!
                                  sorted_groups=[]
                                  sorted_groups.each do |e|
                                    e.transform!(t)
                                    z =  z + 1000.mm
                                    it's like a snowball on the top of the mountain ๐Ÿ˜„
                                    http://www.id2sorties.com/id2photos/5907205456neig.jpg
                                      groups = [] then nothing set !!!
                                      You emptied the groups array...
                                      You need to fill it from the selection... ๐Ÿค“
                                      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                                        another try found: undefined method โ€˜[]โ€™ ๐Ÿ˜•
                                        z=0
                                        zeds=[]
                                        index=0
                                        sorted_groups=[]
                                        groups.each{|group|zeds.push(group.bounds.min.z, index)
                                           index+=1
                                        zeds.sort!
                                        sorted_groups.each do |e| # update!
                                          e.transform!(t)
                                          z = z + 100.cm
                                          Is that the only error message you get?
                                          You're hooked now! No way back! ๐Ÿ˜‰ ๐Ÿ˜„
                                            Here's some tweaked code
                                            def test()
                                              model.start_operation("Move in Z")
                                                zeds=[]
                                                index=0
                                                sorted_groups=[]
                                                groups.each{|group|zeds.push([group.bounds.min.z, index])
                                                   index+=1
                                                zeds.sort!
                                                z = 0.0
                                                  t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                                                  e.transform!(t)
                                                  z = z + 100.cm
                                              model.commit_operation
                                              return nil
                                            end#def
                                            Runs as ' test'.
                                            I made a typo - it needed an array [] of two items adding to zeds: zeds.push([group.bounds.min.z, index]) not two 'loose' items as in zeds.push(group.bounds.min.z, index).
                                            I made your z = 0 into z = 0.0 as it needs the number as a float, not an integer...
                                            Removed 'point' variable and set the point definition directly inside the transformation - not necessary but fewer variables...
                                            I added a model.start_operation("")...model.commit_operation so it becomes a one step undo.
                                            I added return nil at end so the Ruby-Console doesn't get clogged with info...
                                            Tested it - it works...
                                            • 2 / 3
