    Move groups with different measures?
    55 Posts 4 Posters 29.4k Views 4 Watching
      @thomthom said:
      e.is_a(Sketchup::Group) is much faster then e.typename=="Group"
      I think that e.kind_of?(Sketchup::Group) has also just
      beaten e.is_a(Sketchup::Group) in some intensive testing ???
      We are only talking of perhaps a fraction of a second more for moving several groups... however, if you are applying this to a large model with hundreds/thousands then obviously the quicker methods will reduce the processing by quite appreciable times...
      There's a typo in your code too groups.each do |e|...
      should be entities.each do |e|... as you have and empty array 'groups'...
        On average testing the .class come out similar, which I think might be due to the types of things we test. It'll usually short-circut returning true on the first iteration of the loop. So there probably has to be a much great number of iterations of the methods to see a real difference.
          You don't have to do one loop to filter out the groups and then one to process them. That isn't too efficient.
          model = Sketchup.active_model
          entities = model.entities
          selection = model.selection
          groups = []
          z=0
            # Skip all entities that aren't groups
            next unless e.is_a? Sketchup;;Group
            # Now we process the groups
            z += 100 # self increments can be written shorter like this
            point = Geom;;Point3d.new 0,0,z
            t = Geom;;Transformation.new point
            # Apply the transformation
            e.transform!(t)
            Ooops! Corrected. ๐Ÿ‘
              Just to find now apply that just only for a selection! ๐Ÿ˜„
                ร  Tig Some cryptic but I will see that ๐Ÿ˜‰
                Joint an image for no ambiguities
                So here the increment is 300 cm
                My method adds '100mm' to each group's Z and moves then to suit: the other way with 'z+=100.mm' increments z by 100mm each step through the loop so then the groups get progressively further apart !
                If you want to move all groups a certain amount use my way, if [for some unfathomable reason] you want to do a pseudo-grow then increment the offset each time...
                My method finds each group's transformation [as an array], changes just its Z value and then resets it: the other way invents a new transformation and applies it to the group...
                  def movegallgroupsup100mm()
                      entities = model.active_entities
                      ###groups = [];entities.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}###
                      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                      groups.each{|group|
                        transformation_as_array = group.transformation.to_a
                        # Z value is at position 14 ###...
                        transformation_as_array[14] = transformation_as_array[14] + 100.mm
                        ### or whatever increment is desired
                        ### they each move up by 100mm from where they are currently...
                        group.transformation = transformation_as_array
                  end#def
                  Note that I've keep making the array of groups separate from the loop though the selection - changing them - since this way allows you to do other things to that array later if desired... e.g. groups[0].material="Red"###colours the first group red !
                  PS: The test definition 'movegallgroupsup100mm' is optional !!! ๐Ÿ˜‰
                  To test your code I suggest you type this in the Ruby-Console [assuming the file is called "tester.rb"]
                  load"tester.rb";movegallgroupsup100mm
                  this will load and run the script... if it's not doing what you expect then change the script and copy+paste the line back into the console and it will load/run repeat... etc etc
                    groups = []
                    z=0
                    selection.each do |e| # update!
                      e.transform!(t)
                      @Tig
                      I have the "Web console" so no problem for copy/ past and launch it
                      Seems your plug move all selection of groups, but not each by each ๐Ÿ˜„
                      Result stay grouped without interval
                      What is precisely this "14" value?
                      ( i have just 5 group and one component (Bryce) for the moment and just 3 selected for the test ๐Ÿ˜‰
                      Why not take the first value of the array?
                      The ThomThom method works except that woks for the 5 groups and not only for the selection ๐Ÿ˜„
                        SU always uses inches internally.
                        If you want 100mm type 100.mm . See http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/numeric.html for more units.
                          groups = []
                          z=0
                            e.transform!(t)
                            z = z*2 + 100
                          Perfect ๐Ÿ‘ (I put the z=z*2+100 at the end for have the first group of selection with no move)
                          Last thing I obtain 254 cm ( I suppose that is a conversion between inch/cm ?)
                          My first volume is at level z = 0 and I work in cm
                            Pilou
                            Do you want to move each of the selected groups by the same amount (my code - e.g. 100.mm) or by an ever changing amount ?
                            If you want it to change then you need to define how, and add this into the loop - e.g. z=1..... then loop... z += 2*z
                            exponential type increase !
                            If you are applying different offsets, and you have made the groups in order, then the increments will apply in that way; but it would be possible to 'stack' groups made at different times and the loop would process then in their made order, but not the 'stacked' order you want ! Perhaps you need to add in another test... for each of the group.bounds.min.z. which sorts them by their relative heights, so at least the groups array would be in the height order you expect...
                              Yes! Works like a charm! โ˜€
                              For my first one that was not like a true romance but with your help, ThomThom, Tig (yet a lot of cryptic for me ๐Ÿ˜„, and the Chris tutorial and a dash of milk of Tod Burch
                              Many thx for the helps ๐Ÿ˜Ž
                              Next will maybe an "explode view" of several groups ๐Ÿ˜„
                              Just need to know position of a group ๐Ÿ˜„
                              PS @ Tig Sorry but I had no chance with yours! (see previous page) ๐Ÿ˜ฒ
                              And yes I want any sort of increments so now I can have any sort of it! Thx! โ˜€
                              Just play with parameters ๐Ÿ˜„
                              I keep your group.bounds.min.z. trick in my mind!
                                for a completely random offset try
                                    ###point = Geom;;Point3d.new 0,0,(1000.mm * rand)
                                    ### offset in Z somewhere between 0m and 1m - 'rand' makes a random number 0><1
                                    point = Geom;;Point3d.new (1000.mm * rand),(1000.mm * rand),(1000.mm * rand)
                                    ### offset in all XYZ axes by 0 to 1m
                                    e.transform!(t)
                                Swap the ### between the different points = to see the effect
                                  The entities are not returned in their order in z height. You would need to sort the objects by their Z position before applying the transformations.
                                    Before testing your new randomizer plug ๐Ÿ˜„
                                    I have a little problem ๐Ÿ˜„
                                    I have used "Grow" by Tig for make the "volume" on the left (50 groups), then my "Plug" Thomthomised ๐Ÿ˜’
                                    with a normal interval of course!
                                    Seems there is something wrong somewhere ๐Ÿ˜ฎ
                                    Groups are not recorded following the "grow" generation?
                                      So i must use the Tig Advertissement more soon than I have expected ๐Ÿ’š
                                        This group.bounds.min.z. can be found somewhere or the sorting of Groups must be forged again?
                                        (nothing about sort, sorting in the API helping) ๐Ÿ˜ฎ
                                          Build a hash with the entities as the key and their Z posiiton as value and then sort the hash by the values.
                                            Each groups has not a "time creation" trace board? So no need to remake a sorting ?
                                            Seems I have re-open a new nightmare door ๐Ÿ’š
                                            • 1 / 3
