    [Plugin] Q JS ALIGN TOOLBAR
    63 Posts 35 Posters 113.3k Views 35 Watching
    • CadFatherC
      CadFather
      Here is a tweaked version of Jan's Sandstrom (Pixero) script for aligning objects along the 3 main axis - it is useful for those pesky areas like lampshades or 3D text, or just when you feel lazy enough..
      it is mainly for groups (though it will align edges too) - also note that the script takes reference from the centre of the group bounding box and not necessarily the geometric one.
      i want to thank Jan for allowing me to tweak his script and come up with this toolbar version of it.
      the script doesn't really need a tutorial but it is in my to do list, together with other scripts which i will post on my website later on.
      cheers
      Max
      (tested only on PC - unzip the contents to your plugins folder)
      Q JS Align.zip
      • B
        blajnov
        Is it possible to make sure that the alignment occurred on the selected object?
        • CadFatherC
          CadFather
          i know what you mean, but i haven't been able to focus a selection as primary (the one that doesn't move)
          i plan more work on it (like geometric centre and spacing) but it may be beyond my coding (read tweaking) skills..
          • Bob JamesB
            Bob James
            Toolbar: Much appreciated!!
            • L
              leixing
              wow ,very nice work! i like it .
                Like this? πŸ˜‰
                  Can you show me an example where the center of the Group's bounding box is dissimilar from the geometric one?
                  Unless the content of the group/component is a box the boundingbox centre will never be the geometric centre of the content.
                  • CadFatherC
                    CadFather
                    Hi Coen - yes try with a grouped triangle, the centre differs from the bounding box
                    (thanks all for the feedback) πŸ‘
                    EDIT: Coen you got 3 answers in one go - watch your servers.. πŸ˜‰
                      Daniel S
                      Thankyou Cadfather!!!
                      Quick example:
                      (centroid is the geometric center)
                      Daniel S
                      Edit: another example:
                      • CadFatherC
                        CadFather
                        there are two issues i think merit attention: centroid reference and spacing/distribution of objects
                        actually i have looked at the centroid script by Alex Schreyer, but have not been able to implement it into the align script yet (it's going to take me some time)
                        in fact if any of the great masters can help, might be better! πŸ˜’ πŸ˜„
                        • Chris FullmerC
                          EDIT: THis is wrong, I was looking at his shape wrong.
                          Thom I think on yours the bounding box center is the geometric center or centroid. Your face runs the diagonal of the bounding box, so placing a centerpoint on that face is just like placing a centerpoint in the middle of a diagonal line of the bounding box.
                            The bounding box' centre point is not the centre of that extruded triangle.
                            • CadFatherC
                              CadFather
                              Chris, it's the background colour throwing you off.. (must have been on purpose!)
                              • Chris FullmerC
                                OOooohhh! I get it. Yes, Cadfather is right, I could not see a 3d object there at all. I just saw the front, bright face.
                                So yes thom, you're right. That construction point is not the center of the geometry. 😳
                                  thehe
                                  messing with your head! πŸ˜‰ πŸ˜„
                                  • I
                                    ideas_arte
                                    http://www.addemoticons.com/emoticon/animated/AddEmoticons0423.gif
                                    Nice...!
                                    Thank you very much...!
                                    • Bob JamesB
                                      Bob James
                                      Works on Mac except the toolbar doesn't "stick" - have to use View/Toolbars each time SU loads.
                                      • CadFatherC
                                        CadFather
                                        thanks Bob - i hope someone with a mac will be able to fix this πŸ˜’
                                        • B
                                          BTM
                                          Just add this:
                                          case gp_quarr_jsalign_tb.get_last_state when 1 gp_quarr_jsalign_tb.restore when -1 gp_quarr_jsalign_tb.show end
                                          • utilerU
                                            utiler
                                            Thanks Coen, good tip. Could have used it last week while trying to flatten some survey dwgs.... πŸ‘
                                            Just Curious...
                                            • 1 / 4
