    SketchyPhysics 4?
    18 Posts 7 Posters 13.7k Views 7 Watching
    • P
      Physicsguy1
      There is another problem with it also. It is vastly slower than the current version. So slow that I reverted back...
      • P
        phy
        I haven't had that much trouble with it being slow it acts just like the previous one.
        Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
        • C
          CPhillips
          I think I had the idea before but I am not sure. The hard part was the plumbing around it.
          $curEvalGroup isnt used anymore. Instead just use "group".
          The code in the old scripting thread is obsolete. Here is almost the same thing:
          onstart{
             group.hidden=true
             @unhideAtEnd=true
             solid=false
          ontouch{|toucher,speed,pos|
             if(toucher.name=="sphere")
                group.hidden=false
                solid=true
          I dont know any reason this version would be slower than the last.
          • W
            Wacov
            Chris, shouldn't the scripting window have error checking? It lets me stick any old junk into it, tries to run it, and breaks the model forever. Basically, it's trial and error, making a new model every time my code's wrong ๐Ÿ˜ž
            • C
              CPhillips
              It will eventually. Right now this is just a work in progress release.
              Unless you get into a loop you should be able to reset and get back to the start no matter what errors.
              If you do find a piece of script that permanently breaks a model post it here.
              • C
                CPhillips
                Ah, I think I see the problem with bad scripts "breaking" the model. I'll fix it.
                Hitting reset or a bunch of undo's might allow you to get back to start.
                • P
                  Physicsguy1
                  Well, when it comes to big models where a line-less and shaded-only style has to be used, it is terrible compared to the current. I know for sure because I was playing with a fast battleship game, which slowed down to about a frame PER second once I downloaded the latest version.
                  • W
                    Wacov
                    Thanks Chris ๐Ÿ‘
                    It happens with anything except perfect script ๐Ÿ˜ž
                    I don't have the slowdown problem, that's wierd...
                    • P
                      Physicsguy1
                      I'll try again.
                      • C
                        CPhillips
                        If you open the ruby console it will print performance statistics after each run. If you find a model that is much slower post a link and I'll take a looks.
                          JaViXP
                          I've downloaded the June 25 version and I noticed a little "error". When you hit the press button there's a quote ( " ) in the SketchyPhysics Control Panel ๐Ÿ˜‰
                          "Giving up is way harder than trying"
                          JaViXP's Rendering
                          • C
                            CPhillips
                            Thanks. I fixed it.
                            • P
                              PituPhysics
                              Hello, when will the new version? which works in the SU Make 2013?
