    SketchyPhysics 4?
    18 Posts 7 Posters 13.6k Views 7 Watching
      phy
      CPhillips does not have "$curEvalGroup" quite embedded yet. At one point I got this working but I can't right now.
      Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
        Physicsguy1
        There is another problem with it also. It is vastly slower than the current version. So slow that I reverted back...
          phy
          I haven't had that much trouble with it being slow it acts just like the previous one.
            CPhillips
            I think I had the idea before but I am not sure. The hard part was the plumbing around it.
            $curEvalGroup isnt used anymore. Instead just use "group".
            The code in the old scripting thread is obsolete. Here is almost the same thing:
            onstart{
               group.hidden=true
               @unhideAtEnd=true
               solid=false
            ontouch{|toucher,speed,pos|
               if(toucher.name=="sphere")
                  group.hidden=false
                  solid=true
            I dont know any reason this version would be slower than the last.
            • W Offline
              Wacov
              Chris, shouldn't the scripting window have error checking? It lets me stick any old junk into it, tries to run it, and breaks the model forever. Basically, it's trial and error, making a new model every time my code's wrong 😞
                CPhillips
                It will eventually. Right now this is just a work in progress release.
                Unless you get into a loop you should be able to reset and get back to the start no matter what errors.
                If you do find a piece of script that permanently breaks a model post it here.
                  CPhillips
                  Ah, I think I see the problem with bad scripts "breaking" the model. I'll fix it.
                  Hitting reset or a bunch of undo's might allow you to get back to start.
                    Physicsguy1
                    Well, when it comes to big models where a line-less and shaded-only style has to be used, it is terrible compared to the current. I know for sure because I was playing with a fast battleship game, which slowed down to about a frame PER second once I downloaded the latest version.
                    • W Offline
                      Wacov
                      Thanks Chris 👍
                      It happens with anything except perfect script 😞
                      I don't have the slowdown problem, that's wierd...
                        Physicsguy1
                        I'll try again.
                          CPhillips
                          If you open the ruby console it will print performance statistics after each run. If you find a model that is much slower post a link and I'll take a looks.
                            JaViXP
                            I've downloaded the June 25 version and I noticed a little "error". When you hit the press button there's a quote ( " ) in the SketchyPhysics Control Panel 😉
                            "Giving up is way harder than trying"
                            JaViXP's Rendering
                              CPhillips
                              Thanks. I fixed it.
                                PituPhysics
                                Hello, when will the new version? which works in the SU Make 2013?
