    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 121.7k Views 48 Watching
    • EarthMoverE
      EarthMover
      BTM,
      One of the things I like about Modo's sculpting tools is that when you have a tool selected, let's say the push tool, when you hold shift and use the tool it then becomes a smooth tool.......when you hold CTRL and use it, it becomes the tool opposite of it, in the case of the push tool, the opposite is the carve tool. It allows for quick sculpting without constantly selecting different tools to make minor adjustments to the mesh. Thought that would be a good idea for you plugin.
      Content Creator at Skapeup
      • urgenU
        urgen
        .... ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฎ ......๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
        --pupil forever...------
        • B
          BTM
          @earthmover said:
          BTM,
          Yeah, I've been thinking about having Shift or another key make the tool into the opposite. As for a smooth too, I've been thinking about how to make one, but it seems pretty hard to come up with something that might work.
          Also, I'm planning on having the settings, which are used by all the tools, be in a webdialog; then you could change the settings while using any of the tools ( Think of the sketchyphysics UI). My problem is that I have no clue how to make a webdialog. ๐Ÿ˜’
          โ€ฆ Right now, I'm thinking of ways to make the tools run faster when dealing with lots of geometry. They still work fairly well, but definitely not as smooth as in the video, if the polycount is really high. For instance, this model has just over 9000 faces, and the tools worked fairly well on it, but as the framerate drops, the rate of onMouseMove does too.
          • B
            BTM
            Okay, I've sorta got the Shift-to-reverse-tool working. It makes sculpting a lot easier; either that, or I've just gotten a lot better ๐Ÿคฃ
            Another face, over 9000 polys. I think about a half hour to an hour's worth of work.
            โ€ฆ This might turn out to be a pretty good free plugin! ๐Ÿ’š
            • K
              kwistenbiebel
              Looks promising....I think we are going to need a UV-unwrapper for texturing stuff like that.
              The down side to all this, as BTM states himself, will be the inability of Sketchup to handle a medium high poly count .
              • EarthMoverE
                EarthMover
                Are you using another plugin to subdivide the mesh that you are sculpting?
                It's good to hear you say FREE plugin.....as I thought for sure you were going to go commercial with it.
                  Dan
                  Nice and useful future plugin!
                  You and all the other ruby masters here, you have all my consideration for your hard work and the willing to share it with others ๐Ÿ‘
                  I just imagine the Google people's satisfaction with every new plugin which add more value to SU, brings more SU buyers and more and more $ in their pockets. ๐Ÿ‘ฟ
                  And a totally newbie question: is there any possibility to add a sort of "clone" tool to your ruby? Something like PS has? I think that it would be very handy for symmetrical geometry like human faces, etc. to work on only one half of the model and then to use it to "clone" the result to the other half. Just a thought...
                  Or a new ruby to make this?
                  What do you, guys, think?
                  Regards!
                  Dan
                  • CadFatherC
                    CadFather
                    if you made the face a component, and mirrored the other half, you could work one half of the face..
                    the way rubies are going, sketchup 8 will have to deliver..
                      Dan
                      Hey, you're right!
                      I totally forgot this... ๐Ÿ˜ณ
                      I still wonder this is a native SU feature ๐Ÿ‘ฟ
                      • N
                        notareal
                        Sure it will help. Looks great so far!
                        • B
                          BTM
                          โ€ฆ The plugin can handle moving over 4000 points at a time, although that's with a fair amount of lag, but still not too bad.
                          I don't know exactly what you mean, but I used 'add detail' to subdivide the sphere, mostly around the face, before sculpting.
                          โ€ฆ Also, i've added the ability to pick between an S-curve ( http://en.wikipedia.org/wiki/S_curve ) , or just a linear smoothness for the transformation. the S-curve is the kind of smoothing that seems to be used by the smoove tool, and makes the sculpting a bit smoother, although the math does make it a bit slower than the basic smoothing ability, which, when brushed on like it would be, smooths quite well anyways ( all the videos and pictures so far were made with the linear smoothing).
                          • T
                            Tekelwriter
                            drooling WOW! I love messing with Blender's sculpting tools. It includes: Draw, Smooth, Pinch, and Inflate (each of these, except Smooth, with an option for additive or subtractive). I am very eagerly anticipating the release of this plugin.
                            • B
                              BTM
                              of those tools, bulge would be draw, carve would be draw + shift, pull would be pinch, and push would be pinch + shift. ๐Ÿ˜„
                              I'm still thinking of a way to do smooth, and a kind of inflate tool. ๐Ÿ˜‰ I'm going to try my idea of a smooth tool soon.
                              • mitcorbM
                                mitcorb
                                -BTM:
                                In one of your previous responses you said you used "add detail" to the sphere to subdivide it. Is this an available plugin?
                                • EarthMoverE
                                  EarthMover
                                  "Add Detail" is one of the sandbox tools.
                                    remus
                                    Is 'Wow' any good? ๐Ÿ˜„
                                    • B
                                      BTM
                                      New Tool Added: Smooth ๐Ÿ˜„
                                      one half of face smoothed
                                      (unfortunately, it's slower than the other tools, because it has to find the mean of all the other ends of the lines the point being transformed is part of. That takes a little while)
                                      โ€ฆ Any opinions? โ˜€
                                      • soloS
                                        Looks fantastic!
                                        so when do I get to play with it? ๐Ÿ’š
                                        • B
                                          BTM
                                          @solo said:
                                          Looks fantastic!
                                          ๐Ÿ‘ I don't know yet ๐Ÿ˜„
                                          I'm thinking it has enough tools for a first release now, mostly to test and play with, but there's no visual help, and the settings dialog used by all the tools is still just an inputbox (maybe I could convince someone to make a webdialogโ€ฆ). there is a toolbar now, but the icons aren't that great. Also, some of the controls in the dialog don't make that much sense; strength is a divider, which should usually be at around 10-40 for most tools, but for smooth, it should be 2-10. Because it's a division, Lower numbers are stronger.I can change that really easily, but it might take a bit of time.
                                          โ€ฆ Anyways, out of those things there are only a few I have to fix/ do before I put out a first release, but when I do, I'll also need someone to make a proper ZIP file of the tools. My mac tends to make ZIPs that aren't very Windows friendly, and to find the files in them involve deleting files, and searching for the files I put in the ZIP. ๐Ÿ˜ณ
                                          โ€ฆ As for a specific day / time: I'd guess between today and thursday, possibly friday.
                                          Hopefully today.
                                          • Chris FullmerC
                                            Sounds good to me ๐Ÿ˜„
                                            • 11
                                            • 2 / 11
