    [Plugin] Blackout
    23 Posts 15 Posters 25.8k Views 15 Watching
    • K
      kwistenbiebel
      Cool script thomthom! 👍
      Very useful. Thank you.
      • B
        bianhai
        Thank you thomthom.
        • GaieusG
          Tom,
          In SU you can undo an operation after saving, too. Does it not work in this case?
            I suppose so. But I make the warning just in case as there isn't any built in restore in the function. Also, with V-Ray for SketchUp I've experienced that it can some times interfere with the undo operations of scripts. Especially if it manipulates materials.
            It's a better safe than sorry warning. 😉
              sepo
              This is useful. Thanks.
              • JClementsJ
                JClements
                ThomThom:
                I think this might have been discussed a year or two ago.
                I make masks for postprocessing by turning all my layer colors to black and turn on Color By Layer in the Layer Manager. This eliminates messing with the material colors directly. I hardly ever organize my layers via a color scheme so this method is relatively fast to do and doesn't screw up the model. Also, SU shadows are exported with their greyscale value which can be interpreted in post processing as semi-transparent.
                I often create a style for Color by Layer in my model and assign it Scene named "MASK" which only remembers style parameters. I can then use this scene to on toggle Color by Layer for any of the other scenes.
                My workflow would be to click on any Camera view or Scene and select the "MASK" Scene, and export the current view as your mask for post processing.
                Now IF Ruby can remember and store a model's existing Layer Colors and later restore them, then a script to temporarily change the model's layer colors to black, turn on Color by Layer, queue the File > Export > 2D Graphic dialog and then restore the layer colors after printing, might be pretty quick and handy.
                  Interesting.
                  I made this script very very quickly. I might revise it and implement some more stuff suggested. Appears that there was more use for this than I thought. And there's some good ideas here.
                  • MALAISEM
                    MALAISE
                    THanks Thomthom
                    Back to the forum after a while and discovering new rubies 😄 😄
                    MALAISE
                      me3mar
                      can you please show some pics on how to use, and what for ?
                      that would be great
                      thanks in advance
                        sepo
                        Would it be possible to include transparency of .png . Give you an example. If you for instance have a .png tree in front of the material than tree should go black instead of rectangle. It would make life much easieer if possible.
                          Nope. Can't read transparency info. If I had access to the V-Ray maps I could have replaced the texture with the alpha texture - but I don't have access to that either.
                            sepo
                            Thanks for the reply.
                            • xiombargX
                              xiombarg
                              This is actually another really good plugin for character and product design and a standard feature of high end modelling programs. Animation modelling programs implement this feature to help the designer get a better idea of a characters posture and demeanor which subtly reflects their personality. Product designers also use it for similar purposes.
                              Probably is a good idea to do a quick save before using it though, just in case.
                              • onzkiO
                                onzki
                                Hi I know it's an old thread. Is there a way to customize the color, instead of black maybe something else, like red or any RBG code? Thanks!
                                [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                • Didier BurD
                                  Didier Bur
                                  Hi onzki,
                                  Go to your 'Plugins' folder and open 'blackout.rb' in a pure text editor (Notepad++ for instance).
                                  Search for lines like this one:
                                  material.color = 'Black'
                                  Replace 'Black' with the color you want, like 'red', 'green', 'blue' and so on.
                                  Lines to be modified are: 42, 69,91, if i'm not mistaken.
                                  The names of available colors can be found on this page:
                                  https://ruby.sketchup.com/Sketchup/Color.html
                                  To customize the color with RGB values will be a little longer to explain 😉
                                  Save the file blackout.rb, quit SketchUp and restart.
                                  Regards,
                                  DB
                                  • Didier BurD
                                    Didier Bur
                                    Hi, me again,
                                    Here is an enhanced version with which you can select your color in a list.
                                    Menu can still be found in the 'Extensions' menu but I've put the 3 options in a sub-menu to spare your menu space 😉
                                    Hope Thomthom won't mind if I modified his script.
                                    Regards,
                                    blackout.rb
                                    DB
                                    • onzkiO
                                      onzki
                                      @didier bur said:
                                      Hi, me again,
                                      Regards,
                                      Amazing! Big Thanks! 😄 👍
