    SU Start to Finish
    32 Posts 8 Posters 6.0k Views 8 Watching
    • troyhomeT
      troyhome
      smGronningV7 - Scene 5.jpgsmGronningV7 - Scene 4.jpgsmGronningV7 - Scene 1.jpgsmGronningV7 - Scene 2.jpgsmGronningV7 - Scene 3.jpgHere be some more views...
      IOviz.com
      SU Pro 2024 PC
      • troyhomeT
        troyhome
        And a couple more images: the plan is not in stone, nor is it complete... we just wanted to give them some ideas of where we're going with this design, and just talk through the plan a bit...smGronningV9sliced2 - Scene 17.jpgsmGronningV9sliced1 - Scene 15.jpg
        IOviz.com
        SU Pro 2024 PC
        • T
          tim
          See also this thread - http://forums.sketchucation.com/viewtopic.php?f=12&t=15911
            d12dozr
            @troyhome said:
            I hope to document my process and work flow as best as i can; in this way adding to the body of working techniques and general knowledge available in this community.
            Troy,
            Thanks for posting this. πŸ‘ I like to see how others use Sketchup, as well as get ideas and learn better ways to present my own projects. I'm looking forward to the rest of the documentation.
            http://goo.gl/f7ooYh
            • troyhomeT
              troyhome
              Thanks- this is the thread that started me thinking about doing this "start to finish" in the first place. Thanks for your contributions!
              IOviz.com
              SU Pro 2024 PC
              • troyhomeT
                troyhome
                Marcus,
                Thanks for the encouragement; sharing is what makes us all stronger as individuals... at least on this forum if not in life, eh.
                πŸ˜„ I've learned so much from people on this forum- it's like having a thousand people at your fingertips.
                IOviz.com
                SU Pro 2024 PC
                  redinhawaii
                  I would hope that we could do some practical "work thru's" and real life scenario's so that this application of SU/LO becomes truly productive.
                  specifically, setting up a "working template, complete with all the orthographic scenes, set, layers (and their respective orders) organized, and the Outliner, don't get me started....Details, components libraries, a push from the group to get specific residential architectural suppliers, i.e. Simpson, Kohler, Anderson, .... into 3d models, not the typical 2d autocad files they have,
                  then into the "how to's " of LayOut...
                  ruby scripts for door and window schedules, interior finish schedules, electrical symbols / schedules, plumbing fixture, light fixture schedules...
                  But first a "map of needs", a direction, a who can work on this issue or who understands how to work thru this issue....
                  is this too much to ask from the "group"
                  aloha
                  red
                  • troyhomeT
                    troyhome
                    Here's a comparison: Podium render next to a Podium render with Line work combined in Photoshop...straight Podium rendercomposite Podium and SU
                    IOviz.com
                    SU Pro 2024 PC
                    • troyhomeT
                      troyhome
                      The client wanted a cream color scheme- here it is...Vray render
                      IOviz.com
                      SU Pro 2024 PC
                        d12dozr
                        How is the composite done, exactly? Do you export a wireframe the same size as the render and just overlay it in Photoshop?
                        • DanielD
                          Daniel
                          Troy, beautifully modelled and presented project.
                          My avatar is an anachronism.
                          • pbacotP
                            Hello,
                            I think in regards to details, you may try to show the outlining skin of all parts to the correct thickness, then use section cuts to study and develop details.
                            In CAD for smaller custom complex projects, where the study of most section is useful, I have developed all the detail guts of a building section then excerpted parts for detail drawings. In the overall building section itself the "guts" are left as a light background. It is just not profitable on larger projects, especially when so much is a common or typical construction, and modeling or even doing 2d drawings of every member is a waste of time, especially at the scale of most drawings.
                            • troyhomeT
                              troyhome
                              Thanks, Man!
                              IOviz.com
                              SU Pro 2024 PC
                              • troyhomeT
                                troyhome
                                @pbacot said:
                                Hello,
                                Could you post some examples here? I'm really interested in your approach. By request I am also posting the cad file used to help me build the SU model. The work flow is this: I work with an architect who sends me his cad files and I model them so that we can refine the design together. It's a really fluid process really- i post my model renderings on Picasa or share them via Dropbox, and he and I get on the phone and talk through each image (we really should Skype to save my cell minutes). We sometimes email a sketch or two back and forth.
                                That's the process; the details are a whole other issue and that is what is coming up soon- so i would really love to see what you have to show.
                                Cad file used to help build the model
                                IOviz.com
                                SU Pro 2024 PC
                                • troyhomeT
                                  troyhome
                                  Okay- here is the .skp of the latest model. I actually did a really quickie job of this to accommodate the last-minute changes and not spend more time on it than necessary before the client even had a look at it.
                                  I'm learning that pen and paper sketches over a massing model might have been more efficient. But nevertheless, it is what it is and it happens to be modeled. I eliminated the vegetation before uploading the .skppresentation model
                                  IOviz.com
                                  SU Pro 2024 PC
                                  • StinkieS
                                    Stinkie
                                    Thank you!
                                    • troyhomeT
                                      troyhome
                                      update:
                                      nothing new- still waiting on the client. will post as soon as things begin to cook again.
                                      enjoy the simmer.
                                      IOviz.com
                                      SU Pro 2024 PC
                                      • pbacotP
                                        Sorry it's been so long. Just saw your message. You asked for examples. Anyway, this is a CADD approach, so not sure where it applies for you. Here is an example of a section and a detail. The building structure was drawn in section then parts of the section were made into details. The detailed portions can still be seen in the section but they are not shown "hard". As I noted before, in larger projects I would not show the detailed portion inside the sections, as updating the whole building drawings for every change or showing all structure in the sections is not important or profitable (I am not using BIM where this supposedly is automatic). In this small project it helped where every portion of the work is custom. Similarly the SU model could just be the skin like you see here in heavy line in the section, and not every stick in the building.
                                        The section and details are at different places and don't exactly relate but hey, I just grabbed what came to hand to attach.
                                        Sorry I cannot open your SU model to comment. I guess I will be forced to upgrade before long.
                                        Peter
                                          redinhawaii
                                          Yes,
                                          this "when and where" to use SU work flow is the issue.
                                          I am assuming that these drawings were NOT done in SU/LO
                                          if so, this is what I would like to emulate, and do the detail key numbers "limk" to other locations on the model?
                                          aloha
                                          red
                                          • 2 / 2
