    SU Start to Finish
    32 Posts 8 Posters 5.7k Views 8 Watching
      d12dozr
      How is the composite done, exactly? Do you export a wireframe the same size as the render and just overlay it in Photoshop?
      http://goo.gl/f7ooYh
      • DanielD
        Daniel
        Troy, beautifully modelled and presented project.
        My avatar is an anachronism.
        • pbacotP
          Hello,
          I think in regards to details, you may try to show the outlining skin of all parts to the correct thickness, then use section cuts to study and develop details.
          In CAD for smaller custom complex projects, where the study of most section is useful, I have developed all the detail guts of a building section then excerpted parts for detail drawings. In the overall building section itself the "guts" are left as a light background. It is just not profitable on larger projects, especially when so much is a common or typical construction, and modeling or even doing 2d drawings of every member is a waste of time, especially at the scale of most drawings.
          • troyhomeT
            troyhome
            Thanks, Man!
            IOviz.com
            SU Pro 2024 PC
            • troyhomeT
              troyhome
              @pbacot said:
              Hello,
              Could you post some examples here? I'm really interested in your approach. By request I am also posting the cad file used to help me build the SU model. The work flow is this: I work with an architect who sends me his cad files and I model them so that we can refine the design together. It's a really fluid process really- i post my model renderings on Picasa or share them via Dropbox, and he and I get on the phone and talk through each image (we really should Skype to save my cell minutes). We sometimes email a sketch or two back and forth.
              That's the process; the details are a whole other issue and that is what is coming up soon- so i would really love to see what you have to show.
              Cad file used to help build the model
              IOviz.com
              SU Pro 2024 PC
              • troyhomeT
                troyhome
                Okay- here is the .skp of the latest model. I actually did a really quickie job of this to accommodate the last-minute changes and not spend more time on it than necessary before the client even had a look at it.
                I'm learning that pen and paper sketches over a massing model might have been more efficient. But nevertheless, it is what it is and it happens to be modeled. I eliminated the vegetation before uploading the .skppresentation model
                IOviz.com
                SU Pro 2024 PC
                • StinkieS
                  Stinkie
                  Thank you!
                  • troyhomeT
                    troyhome
                    update:
                    nothing new- still waiting on the client. will post as soon as things begin to cook again.
                    enjoy the simmer.
                    IOviz.com
                    SU Pro 2024 PC
                    • pbacotP
                      Sorry it's been so long. Just saw your message. You asked for examples. Anyway, this is a CADD approach, so not sure where it applies for you. Here is an example of a section and a detail. The building structure was drawn in section then parts of the section were made into details. The detailed portions can still be seen in the section but they are not shown "hard". As I noted before, in larger projects I would not show the detailed portion inside the sections, as updating the whole building drawings for every change or showing all structure in the sections is not important or profitable (I am not using BIM where this supposedly is automatic). In this small project it helped where every portion of the work is custom. Similarly the SU model could just be the skin like you see here in heavy line in the section, and not every stick in the building.
                      The section and details are at different places and don't exactly relate but hey, I just grabbed what came to hand to attach.
                      Sorry I cannot open your SU model to comment. I guess I will be forced to upgrade before long.
                      Peter
                        redinhawaii
                        Yes,
                        this "when and where" to use SU work flow is the issue.
                        I am assuming that these drawings were NOT done in SU/LO
                        if so, this is what I would like to emulate, and do the detail key numbers "limk" to other locations on the model?
                        aloha
                        red
                        • 2 / 2
