    SU Start to Finish
    32 Posts 8 Posters 6.0k Views 8 Watching
    • troyhomeT
      troyhome
      Marcus,
      Thanks for the encouragement; sharing is what makes us all stronger as individuals... at least on this forum if not in life, eh.
      πŸ˜„ I've learned so much from people on this forum- it's like having a thousand people at your fingertips.
      IOviz.com
      SU Pro 2024 PC
        redinhawaii
        I would hope that we could do some practical "work thru's" and real life scenario's so that this application of SU/LO becomes truly productive.
        specifically, setting up a "working template, complete with all the orthographic scenes, set, layers (and their respective orders) organized, and the Outliner, don't get me started....Details, components libraries, a push from the group to get specific residential architectural suppliers, i.e. Simpson, Kohler, Anderson, .... into 3d models, not the typical 2d autocad files they have,
        then into the "how to's " of LayOut...
        ruby scripts for door and window schedules, interior finish schedules, electrical symbols / schedules, plumbing fixture, light fixture schedules...
        But first a "map of needs", a direction, a who can work on this issue or who understands how to work thru this issue....
        is this too much to ask from the "group"
        aloha
        red
        • troyhomeT
          troyhome
          Here's a comparison: Podium render next to a Podium render with Line work combined in Photoshop...straight Podium rendercomposite Podium and SU
          IOviz.com
          SU Pro 2024 PC
          • troyhomeT
            troyhome
            The client wanted a cream color scheme- here it is...Vray render
            IOviz.com
            SU Pro 2024 PC
              d12dozr
              How is the composite done, exactly? Do you export a wireframe the same size as the render and just overlay it in Photoshop?
              http://goo.gl/f7ooYh
              • DanielD
                Daniel
                Troy, beautifully modelled and presented project.
                My avatar is an anachronism.
                • pbacotP
                  Hello,
                  I think in regards to details, you may try to show the outlining skin of all parts to the correct thickness, then use section cuts to study and develop details.
                  In CAD for smaller custom complex projects, where the study of most section is useful, I have developed all the detail guts of a building section then excerpted parts for detail drawings. In the overall building section itself the "guts" are left as a light background. It is just not profitable on larger projects, especially when so much is a common or typical construction, and modeling or even doing 2d drawings of every member is a waste of time, especially at the scale of most drawings.
                  • troyhomeT
                    troyhome
                    Thanks, Man!
                    IOviz.com
                    SU Pro 2024 PC
                    • troyhomeT
                      troyhome
                      @pbacot said:
                      Hello,
                      Could you post some examples here? I'm really interested in your approach. By request I am also posting the cad file used to help me build the SU model. The work flow is this: I work with an architect who sends me his cad files and I model them so that we can refine the design together. It's a really fluid process really- i post my model renderings on Picasa or share them via Dropbox, and he and I get on the phone and talk through each image (we really should Skype to save my cell minutes). We sometimes email a sketch or two back and forth.
                      That's the process; the details are a whole other issue and that is what is coming up soon- so i would really love to see what you have to show.
                      Cad file used to help build the model
                      IOviz.com
                      SU Pro 2024 PC
                      • troyhomeT
                        troyhome
                        Okay- here is the .skp of the latest model. I actually did a really quickie job of this to accommodate the last-minute changes and not spend more time on it than necessary before the client even had a look at it.
                        I'm learning that pen and paper sketches over a massing model might have been more efficient. But nevertheless, it is what it is and it happens to be modeled. I eliminated the vegetation before uploading the .skppresentation model
                        IOviz.com
                        SU Pro 2024 PC
                        • StinkieS
                          Stinkie
                          Thank you!
                          • troyhomeT
                            troyhome
                            update:
                            nothing new- still waiting on the client. will post as soon as things begin to cook again.
                            enjoy the simmer.
                            IOviz.com
                            SU Pro 2024 PC
                            • pbacotP
                              Sorry it's been so long. Just saw your message. You asked for examples. Anyway, this is a CADD approach, so not sure where it applies for you. Here is an example of a section and a detail. The building structure was drawn in section then parts of the section were made into details. The detailed portions can still be seen in the section but they are not shown "hard". As I noted before, in larger projects I would not show the detailed portion inside the sections, as updating the whole building drawings for every change or showing all structure in the sections is not important or profitable (I am not using BIM where this supposedly is automatic). In this small project it helped where every portion of the work is custom. Similarly the SU model could just be the skin like you see here in heavy line in the section, and not every stick in the building.
                              The section and details are at different places and don't exactly relate but hey, I just grabbed what came to hand to attach.
                              Sorry I cannot open your SU model to comment. I guess I will be forced to upgrade before long.
                              Peter
                                redinhawaii
                                Yes,
                                this "when and where" to use SU work flow is the issue.
                                I am assuming that these drawings were NOT done in SU/LO
                                if so, this is what I would like to emulate, and do the detail key numbers "limk" to other locations on the model?
                                aloha
                                red
                                • 2 / 2
