    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      darkPhysics
      @chris fullmer said:
      The problem is with the compspray.rb
      Update it from here:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=11746
      Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
      Let me know if that does not help.
      It didn't work with new compspray, but I removed it and it worked!
      • Chris FullmerC Offline
        I see you are on Vista.
        There is a good chance that when you tried to install compospray, Vista played a dirty trick on you. It has a hidden file system called "Compatibility Files" where it puts things without telling you. So try this.
        • Delete the existing compospray.
        • In the Plugins folder, towards the top is a button called "Compatibility Files" (or maybe Folders). - Click it.
        • Now your in a new folder, probably with other scripts. Cut and paste them all back into your regular plugins folder manually.
        • If there is a compospray in there, delete it too.
        • Now reinstall compospray, and be forewarned that it might end up in compatibility files world, so go track it down, and cut and paste it back into the plugins folder.
        • now start SU again, see if shape bender works and if compo spray is installed and working.
        I know its lame and a bit of work. Vista just does it to keep us safe 🤢 👎 👿
        Hope that helps,
        • simon le bonS Offline
          simon le bon
          Hi Chris,
          Another thing i think it would be great to fix for a next update is that construction points and construction lines they follow the Bend processes.
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_ShapeBender_CP.jpg
          😉 simon
            Ahh, thats a good idea! I see if I can get that to work.
            • ToboboT Offline
              Tobobo
              Chris,
              I stripped all the rubies out and it worked. I know that I should add the others back in one at a time but I have soo many scripts with references i keep getting lost on which ones need each other. Can you take a look at the screen dump and see if anything jumps out at you.
              Here is the console text aswell
              Error; #<ArgumentError; comparison of Float with nil failed>
              (eval);44;in `>'
              (eval);44;in `update'
              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;533;in `exploder'
              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;526;in `each'
              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;526;in `exploder'
              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;244;in `onLButtonUp'
              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;671
              Error; #<NoMethodError; undefined method `/' for nil;NilClass>
              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;671;in `draw'
              Toby
              Philippians 4:13
                magpie
                many thanks for your plugin...brilliant!
                  lexmonteiro
                  Hi Chris, It is possible to the texture bend with the model?
                    Hi Lex, that is a good question. I think someone else had also asked about that previously. I'm not sure how easy or hard it will be to do. I pretty much never use textures and I've never touched them using Ruby yet, so its possible it might be pretty straightforward.
                    When I re-work this script, I'll see if I can get it to treat textures better.
                      lexmonteiro
                      Thanks for the quick answer, I was searching for some plugin that help me to create a road, and ajust the texture to fit in the curves. This could be a very good tool
                      Anyway, thank you very much for this plugin!
                      Cheers
                      Alexandre
                        Hi Lex, that is a good question. I think someone else had also asked about that previously...
                        That was me. And I'm still looking forward to that. 🎉
                        Did I say I'm looking forward to it? 😒
                        • SwissmountainS Offline
                          Swissmountain
                          Thanks for the Plugin, nice work! 👍
                          Cogito ergo dum-di-dum
                            simon le bon
                            Bonjour Chris,
                            What a plugin! I enjoy the originality of the approach, I am surprise by it great power, and I applaud to it accomplishment 👍 👍
                            I had made some studies with it and here are some of the results
                            ShapeBender Basics Studies:
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BasicStudies_640.jpg
                            Basic Studies SlideShow(Adobe PhotoExpress)
                            ShapeBender_Wrap Test
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/WrapTest_640.jpg
                            Wrap Test SlideShow >>or the album (Picasa Album/Slideshow)
                            (I noticed some difficulties, but I'll tell you later)
                            simon
                              does it possible to have the result with the same number of groups than the start?
                              see this post 😉
                                Coronel
                                It's working fine again after compspray removing too on Mac
                                  Oh good, glad its working Coronel. There is a new version of component spary that you can download and safely install. Didier fixed it up so it doesn't conflict with anything.
                                    rem_s
                                    I try to use the shape bender but nothing happen. When I open the ruby console I saw an error message :
                                    Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                                      Do you have an old version of Component Spray installed?
                                        rem_s
                                        Yes but it still not work
                                          Thom asked if you had an old version installed, because the old version causes my script to break. Try updating to the new component spray hee:
                                          Funny thing is, compspray causes ANY script that uses the progressbar to break (including MakeFaces!). But seems like people only notice it on my script 😞
                                          Anyhow, update it and see if that helps.
                                          • charly2008C Offline
                                            charly2008
                                            Hi Chris,
                                            i had the same problem. I installed the compo spray version you mentioned above. But the problem was not solved. i had to remove the compo spray from the plugins folder, than shape bender worked fine.
                                            Karlheinz
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 63
                                            • 64
                                            • 48 / 64
