    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
    • P
      Physicsguy1
      It won't bend the shapes. The progress bar will completely freeze well below 20%, and won't unfreeze. i don't know what happened.
        Cool trick & works fine!
        the funny thing is that the red blocks are false in the length! 😉
        circle explosed and arc curves were build with same length of their segments!
        • ToboboT
          Tobobo
          Try to follow what chris told me to solve my problem with the bar freezing.
          @chris fullmer said:
          My first guess would be to try component spray. Just unload that script and see if that does the trick. There was a problem with it and Didier uploaded a new version that fixes the problem. So remove it and that fixes the problem, download the newest update here
          404 Not Found
          (www.sketchucation.com)
          I really think that's it. Let me know if its not,
          Toby
          Philippians 4:13
          • Chris FullmerC
            I agree, update component spray. If thats not it, we'll start debugging!
            • C
              caramel1982
              The sketches that you have made are just simply amazing. I can't do it myself. I need more practice.
              Simulation pret immobilier
              -- caramel --
              • B
                bianhai
                Nice plugin, 👍 Thanks!
                  darkPhysics
                  Please help me! It just wont work. I have the progressbar.rb, but it wont show the preview of bend. Here is the image
                  http://img188.imageshack.us/img188/9918/problemfyj.png
                  . Can anyone help me? Here is my plugins folder:
                  http://img188.imageshack.us/img188/3189/pluginsfolder.png
                  • Chris FullmerC
                    The problem is with the compspray.rb
                    Update it from here:
                    404 Not Found
                    (forums.sketchucation.com)
                    Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
                    Let me know if that does not help.
                      darkPhysics
                      404 Not Found
                      It didn't work with new compspray, but I removed it and it worked!
                      • Chris FullmerC
                        I see you are on Vista.
                        There is a good chance that when you tried to install compospray, Vista played a dirty trick on you. It has a hidden file system called "Compatibility Files" where it puts things without telling you. So try this.
                        • Delete the existing compospray.
                        • In the Plugins folder, towards the top is a button called "Compatibility Files" (or maybe Folders). - Click it.
                        • Now your in a new folder, probably with other scripts. Cut and paste them all back into your regular plugins folder manually.
                        • If there is a compospray in there, delete it too.
                        • Now reinstall compospray, and be forewarned that it might end up in compatibility files world, so go track it down, and cut and paste it back into the plugins folder.
                        • now start SU again, see if shape bender works and if compo spray is installed and working.
                        I know its lame and a bit of work. Vista just does it to keep us safe 🤢 👎 👿
                        Hope that helps,
                        • simon le bonS
                          simon le bon
                          Hi Chris,
                          Another thing i think it would be great to fix for a next update is that construction points and construction lines they follow the Bend processes.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_ShapeBender_CP.jpg
                          😉 simon
                          • Chris FullmerC
                            Ahh, thats a good idea! I see if I can get that to work.
                            • ToboboT
                              Tobobo
                              Chris,
                              I stripped all the rubies out and it worked. I know that I should add the others back in one at a time but I have soo many scripts with references i keep getting lost on which ones need each other. Can you take a look at the screen dump and see if anything jumps out at you.
                              Here is the console text aswell
                              Error; #<ArgumentError; comparison of Float with nil failed>
                              (eval);44;in `>'
                              (eval);44;in `update'
                              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;533;in `exploder'
                              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;526;in `each'
                              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;526;in `exploder'
                              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;244;in `onLButtonUp'
                              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;671
                              Error; #<NoMethodError; undefined method `/' for nil;NilClass>
                              C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;671;in `draw'
                              Toby
                              Philippians 4:13
                                magpie
                                many thanks for your plugin...brilliant!
                                • L
                                  lexmonteiro
                                  Hi Chris, It is possible to the texture bend with the model?
                                  • Chris FullmerC
                                    Hi Lex, that is a good question. I think someone else had also asked about that previously. I'm not sure how easy or hard it will be to do. I pretty much never use textures and I've never touched them using Ruby yet, so its possible it might be pretty straightforward.
                                    When I re-work this script, I'll see if I can get it to treat textures better.
                                    • L
                                      lexmonteiro
                                      Thanks for the quick answer, I was searching for some plugin that help me to create a road, and ajust the texture to fit in the curves. This could be a very good tool
                                      Anyway, thank you very much for this plugin!
                                      Cheers
                                      Alexandre
                                      • GaieusG
                                        Hi Lex, that is a good question. I think someone else had also asked about that previously...
                                        That was me. And I'm still looking forward to that. 🎉
                                        Did I say I'm looking forward to it? 😒
                                        • SwissmountainS
                                          Swissmountain
                                          Thanks for the Plugin, nice work! 👍
                                          Cogito ergo dum-di-dum
                                          • simon le bonS
                                            simon le bon
                                            Bonjour Chris,
                                            What a plugin! I enjoy the originality of the approach, I am surprise by it great power, and I applaud to it accomplishment 👍 👍
                                            I had made some studies with it and here are some of the results
                                            ShapeBender Basics Studies:
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BasicStudies_640.jpg
                                            Basic Studies SlideShow(Adobe PhotoExpress)
                                            ShapeBender_Wrap Test
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/WrapTest_640.jpg
                                            Wrap Test SlideShow >>or the album (Picasa Album/Slideshow)
                                            (I noticed some difficulties, but I'll tell you later)
                                            simon
                                            • 11
                                            • 12
                                            • 63
                                            • 64
                                            • 10 / 64
