Circle Becomes Arc When Reopened
Hi All,
Has anyone had this strange occurance with Circles. If I "push" a Circle, when I save and reopen the file the Circles (either side of the hole) have become an Arcs (see right side of attached pictures). The circle on the left stays a circle. I've had no problem with this yet, and only noticed it after my "Select Circle Entities" plugin didn't work!
I can verify this behaviour on XP Pro - SU7 Pro.
How? See my screenshot; I don't have it. I tried to make the hole two different ways;
- punching the hole on a flat face and then PP'ing the surrounding rectangle
- first making the box then drawing the circle and PP'ing it back to the bottom
Had the same result both times.
- I made a square.
- Drew a circle on the square - deleted the circle face
- Copied the square with hole in next to itself
- Push-Pulled Up (Entity is Circle at this point)
- Saved and closed the file
- Reopened the file (Entity was now an Arc - The circle that wasn't push-pulled remained a Circle though.)
I can reproduce it as well, SU7 vista 64.
Sorry guys,although it was written in the first post,I didn't save > close > reopen. True, I can also reproduce it this way (in fact,you don't even need to copy the whole thing just do the PP)
The copy was just to reference to see if it happened to all circles.
So is this likely to cause any problems? My only issue so far is my "select circles" plugin (just got to remember to "select arcs" instead).
Well that's strange:
Poking around with the API:
While the.start_angle
is 0 for both - but the.end_angle
is different:
Original CircleSketchup.active_model.selection[0].curve.end_angle.radians > 360.0
ArcCircle
Sketchup.active_model.selection[0].curve.end_angle.radians > 720.0
For some reason it loops around itself twice! o_O
Could be because an Arc is 12-sided by default and a circle is 24-sided?
Dunno. But it's odd that a Circle entity turns into an Arc. Or in reality according to the API - Circles are ArcCurves that's 360 degrees.
FYI: I added support for bugged circles in my Selection Toys plugin. http://forums.sketchucation.com/viewtopic.php?f=180&t=14975 If you select all entities and then
Right-click->Select Only->Circles
it'll select all the circles - even those that SU claims are arcs and incorrectly reports as 720 degrees.
