    [Plugin] Selection Toys
    594 Posts 121 Posters 552.6k Views 121 Watching
      Added filters for Curves (Polylines)
      Before Arcs would select Curves and Arcs and Circles - Now they select Arcs and Circles
      Curves will select Curves, Arcs and Circles.
      Question:
      Currently, Curves selects Arcs and Circles are a subset of Curves.
      But is it preferred that Curves selects only Curves - Arcs only Arcs and Circles selects only Circles?
        ThomThom, takk for alt.
        Could you do a little favor? When you update a plugin, could you add the date of the update to the title line? I can't remember version numbers well enough to recognize and update has been issued. I usually can't remember the date ,either. But I know enough to hover the cursor over the clock on my computer screen to find out what the current date actually is.
        Thank you.
          Done!
            You're a champ!
            • mitcorbM
              mitcorb
              Thomthom:
              I would make a suggestion here.
              I think the title of this ruby should be Thomthom Selection Toys, in your own honor and ownership.
              You have advanced Sketchup to a new level here!
              Thank you.
              • mitcorbM
                mitcorb
                hmmm. perhaps my last post here was a bit effusive and over the top. excuse me.
                • Chris FullmerC
                  Too effusive? No such thing around here!
                    heh, no worries. I'm glad you liked it.
                    • mitcorbM
                      mitcorb
                      Well, then, you guys must have been napping. And I reinstate what I said about naming that plugin.
                      Best Regards,
                      mitcorb
                        I think I'll keep the name as it is. But I do accept donations in the shape of cookies*. 😉
                        *** Cookies can be replaced with beer. (Excluding white beer and Budweiser and Spitfire).**
                        • mitcorbM
                          mitcorb
                          Thomthom:
                          I do not know how to do the cookies thing in cyberspace. I am sure they would taste a little bit flat, and I'm not sure if you would want one of those giant cookies or just "byte" size.
                          It is ok with me if you want to keep the name as is.
                          Now to business. I tried to do a Select Loop on a roughly cylindrical model with a lot of triangular faces. The target loop was a fairly direct series of segments. I first set Edges only, then select loop. This portion of the model is contained inside a group.
                          What I got was the edge and the two adjacent triangular faces highlighted. I was obviously expecting a loop around the circumference to be highlighted. What did I do wrong?
                          mitcorb
                            It only deals with faces with four edges at the moment.
                            Loop is one of the functions I plan to improve at some point.
                            • EarthMoverE
                              EarthMover
                              Thanks so much Thomas!!! Any way to be able to create a shortcut for Select>Loop function? I use it a lot and would like to assign it to a key on my keyboard, but it doesn't show up as an option in preferences.
                              Content Creator at Skapeup
                                You have to select one edge first. You can only assign shortcut to menu items if they apper in the menu's at the time.
                                I use the loop function myself allot. I really wish it was smarter though.
                                And I want to make a function that select the next connected edges if they are under a given angle.
                                  alz
                                  Holy crap! Fantastic work -- thanks for sharing it 😄
                                  • simon le bonS
                                    simon le bon
                                    Dear thomthom,
                                    perhaps you should take a look at Matt plugin Selection Manager I think he had already well-done made the development you are thinking of 👍 😉
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_SelectionManager_Matt_2.jpg
                                    *simon
                                      Ah, I'll keep that in mind. Thanks for the heads up.
                                      • majidM
                                        majid
                                        Dear TOM....
                                        you have made a section (included in yr plugin ) that can find copies of the same group
                                        at the same time yr plugin is able to finde "same area"s.
                                        the question is: (for the next step) is it possible to find smae shapes--->convert them to copies of 1 component?
                                        if it is possible then SU would be really poweful , bkz then it could import from other application , with less polygon... and it would be great step ....
                                          I have considered this - as lately we've been using more and more Revit at work and when I import via DWG windows that should have been the same - isn't. It's certainly something I'd like to see myself.
                                            • Added filter support for 3D Polylines (Drawn with the freehand-tool)
                                            • Fixed a flaw in the .typename optimisation code to detect dimensions and 3D polylines
                                            • Fixed a flaw in the circle filter where arcs that made up a full circle wasn't recognised if the start_angle wasn't 0.
                                            • Worked around a SU bug where an extruded circle is reported as being 720 degrees. All arcs that report more than 360 degrees is considered a circle.
                                            • 29
                                            • 30
                                            • 4 / 30
