    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
    • mitcorbM
      mitcorb
      Thomthom:
      I do not know how to do the cookies thing in cyberspace. I am sure they would taste a little bit flat, and I'm not sure if you would want one of those giant cookies or just "byte" size.
      It is ok with me if you want to keep the name as is.
      Now to business. I tried to do a Select Loop on a roughly cylindrical model with a lot of triangular faces. The target loop was a fairly direct series of segments. I first set Edges only, then select loop. This portion of the model is contained inside a group.
      What I got was the edge and the two adjacent triangular faces highlighted. I was obviously expecting a loop around the circumference to be highlighted. What did I do wrong?
      mitcorb
        It only deals with faces with four edges at the moment.
        Loop is one of the functions I plan to improve at some point.
        • EarthMoverE
          EarthMover
          Thanks so much Thomas!!! Any way to be able to create a shortcut for Select>Loop function? I use it a lot and would like to assign it to a key on my keyboard, but it doesn't show up as an option in preferences.
          Content Creator at Skapeup
            You have to select one edge first. You can only assign shortcut to menu items if they apper in the menu's at the time.
            I use the loop function myself allot. I really wish it was smarter though.
            And I want to make a function that select the next connected edges if they are under a given angle.
              alz
              Holy crap! Fantastic work -- thanks for sharing it 😄
              • simon le bonS
                simon le bon
                Dear thomthom,
                perhaps you should take a look at Matt plugin Selection Manager I think he had already well-done made the development you are thinking of 👍 😉
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_SelectionManager_Matt_2.jpg
                *simon
                  Ah, I'll keep that in mind. Thanks for the heads up.
                  • majidM
                    majid
                    Dear TOM....
                    you have made a section (included in yr plugin ) that can find copies of the same group
                    at the same time yr plugin is able to finde "same area"s.
                    the question is: (for the next step) is it possible to find smae shapes--->convert them to copies of 1 component?
                    if it is possible then SU would be really poweful , bkz then it could import from other application , with less polygon... and it would be great step ....
                      I have considered this - as lately we've been using more and more Revit at work and when I import via DWG windows that should have been the same - isn't. It's certainly something I'd like to see myself.
                        • Added filter support for 3D Polylines (Drawn with the freehand-tool)
                        • Fixed a flaw in the .typename optimisation code to detect dimensions and 3D polylines
                        • Fixed a flaw in the circle filter where arcs that made up a full circle wasn't recognised if the start_angle wasn't 0.
                        • Worked around a SU bug where an extruded circle is reported as being 720 degrees. All arcs that report more than 360 degrees is considered a circle.
                          • Added the menu elements for 3D Polyline filtering
                          • Fixed a bug in two of the filter methods for Drawingelement based entitites.
                          • EarthMoverE
                            EarthMover
                            Thom,
                            Anyway to have the selection tools work with multiple selections or by adding to a selection? Let's say I select two faces with two different materials and I want to extend the selection to connected by material for both faces, is this possible?
                            Same with Select Loop. It would be nice to select a line, run select loop, then while holding shift select another line and get to run select loop to add to selection. Don't know if this is possible though.
                              In it's current state: no.
                              But it's something I wish for myself. But it requires complete rewrite of all the functions - making them into tools. It's something I'd like to add to version 2.
                              • mitcorbM
                                mitcorb
                                @Thomthom:
                                I seem to be having a problem with Selection Toys.
                                I see it in plugins and I see Selection in drop down menu with a flyout trigger to the right, but nothing flies out. So I am unable to use the various selection tools.
                                In case it is a conflict or interoperability issue, I will mention that I have downloaded in the last few days updates of Extrude edges, Grow, Projections v2 and I am experimenting with Sculpt. I have also, Hoverselect.
                                I just thought you would want to know about this.
                                Of course, the possibility exists that it has nothing to do with the plugins mentioned and I am just not activating Selection in the proper way.
                                Nonetheless, thank you for the opportunity to use the plugin.
                                mitcorb
                                  Can you open the Console and see if there's any error messages that appear there?
                                  • mitcorbM
                                    mitcorb
                                    I will give that a try, and post back. Thanks
                                    • mitcorbM
                                      mitcorb
                                      Thomthom:
                                      My apologies, it is not your plugin, but Matt Extend Tool that has the Selection with the fly out trigger. This time the fly out did happen and it says Extend edges. However, at this time, the Extend Edges is not working, and it may have to do with interoperability with other tools.
                                      Sculpt is currently not working, though I understand that it is still in development.
                                      By the way, at first I could get no activity in the Ruby Console with the dead end menu with "Selection >". Then, for some reason the fly out trigger '>' worked and Extend Edges flew out, and the console displayed that action, but no results from the selection. I will stop here, before it gets confusing.
                                        That's odd... Can't say I can provide any explanation to that. Poke Matt and let him know.
                                          • Added Layer filters
                                          • Added function to select all entities on selected layers
                                            • Added function to select all active entities on selected layers
                                            • 29
                                            • 30
                                            • 4 / 30
