    [Plugin] Point Merger tools v1.2 UPDATED@ 23/06/09
    68 Posts 20 Posters 46.8k Views 20 Watching
    • kenK Offline
      ken
      BTM
      I have tried you script and find it useful. However, is it necessary to pick a distance? Why not, pick point A, a point B, and have point A move to point B.
      Thanks for all your work
      Ken
        BTM
        BTM
        Ken
        Well, as I see it, I'd usually use the move tool to move a single point to another single point. This script was made for those areas with a bunch of points, that are mostly unnecessary, and you just want to make them all into a single point.
        @mitcorb said:
        …you construct a line or curve, or loop along which you can snap nearby vertices to it?
        Not yet, sorry. 😞 maybe I'll add it as a feature eventually.
        Does it possible to make the same but collapse points on an axe (X,Y,Z) or on a straight line given?
        Pilou, je ne sais pas exactement ce que tu veux dire, mais je pense que tu demande si c’est possible de changer la code, pour qu’il puisse attacher des points proches à une ligne sélectionner. Sinon, peux-tu expliquer plus?
        @tig said:
        To keep 'max_weld_distance' set during a session call it @@max_weld_distance, on activate set it to 1" at the start if it's not set in the form
        @@max_weld_distance=1.to_l if not @@max_weld_distance
        and in the inputbox use
        defaults = [@@max_weld_distance]
        to use it...
        I've tried some similar things, but I always seem to get the error that @@max_weld_distance is an 'uninitialized class variable'.
        @jim said:
        …make it highlight each point within the weld distance so you know what is about to happen when you click.
        I'll try. 😄 Visualization isn't something I'm all that good with yet.
          Initially set
          inside the class BUT not inside a sub-definition...
            is that more clear? 😄
            • Chris FullmerC Offline
              Is there a practical application for that type of functionality? Seems faster to juist draw it.
                BTM
                @mitcorb said:
                BTM:
                I have not tried the ruby yet, but I have some questions.
                Is there an upper and lower limit to the selection radius?
                From the description, this could be used as a seam stitcher, maybe? In other words, you construct a line or curve, or loop along which you can snap nearby vertices to it?
                Today, I've made another script to do this… well, I think it does this.
                http://www.screencast.com/t/zIfDNh5jG
                You select a number of edges, and click the tool. It asks you for a radius, like in the other one. You select it, and any points within that distance from a selected line, are moved to the closest point on any of the lines selected. In the next release, most likely tonight, both of the scripts will be included in a submenu.
                  Very practical for flatten or deform (for any reason) an existing volume (or part of volume) on any orientation!
                  Normal way when that is collapsed on a plan 3D
                  Funny when that is collapsed on a line
                    BTM
                    OK, I have 2 issues, one with each script, that are holding me back from posting the next version. 😡
                    1. With the current 'Merge Points' script, the transformation isn't always 'perfect'. since SketchUp only allows vertices to be transformed by vectors, and not able to be given a specific point to move to, the points don't always end up exactly in the same place. Sometimes they are off by an amount SketchUp barely even recognizes. This causes them to not be attached, and thus are annoying. This doesn't always happen, but it does happen on occasion. Does Anyone know of a way to get the transformation to be perfect every time?
                    2. The next script moves points to the closest position on the lines of the selected edges. The annoying part is that lines are infinite. I could probably figure out how to get it working properly, with the edges and not lines by using if functions, but it wouldn't be ready by tonight.
                      #1 - yeah, the easiest way to do it is using the transform by vector method. But there is also Entities.transform_entities method which lets you apply a single transformation object to multiple objects simultaneously....but in your case you would only tansform a single entity at a time. Then, since you are using a transformation object, you can transform something to a given 3d point. So your code that looks like this:
                      dist = pos.distance @mouse_point
                      	if dist <= @max_weld_distance
                      	vec = p.position.vector_to @mouse_point
                      	@entities.transform_entities(vec,p)
                      could look like this:
                      	t = Geom;;Transformation.new(@mouse_point)
                      	@entities.transform_entities(t,p)
                      I have not tested that for syntax and I don't know if it will fix your #1 problem, but I think it might.
                        BTM
                        ...I figured out how to solve problem 2!!!
                        As for problem 1, Chris, the transform_entities works pretty much the same way whether you give it a transformation or a vector; the script you have down there moves the points by the vector @mouse_point, so they end up in a completely different spot. That's why I used vector_to. The only problem, is that SketchUp sees things like 3.999m as 4 meters ( Well, according to the VCB, it doesn't show up as ~4.00m, but as if it were just 4.00m), and I think it's inaccuracies like this that can mess it up sometimes. 😕 😞
                          BTM
                          I might not have the accuracy issue fixed, but I've updated the first post, now Merge Points to Lines is available, and Merge Points has been slightly updated. 😄
                          • EdsonE Offline
                            Edson
                            i still have no clue as to what this script is supposed to do. thus the following.
                            i know this is probably asking too much of guys who make their creative work available for free to all of us. however, i think it is in their own interest that their creations be understood and put to use to the full.
                            thus i respectfully suggest that all scripts should be accompanied with some kind of demonstration about what they are supposed to do: a guide, a tutorial or a short video (perhaps the easiest to do).
                            http://www.mahfuz.arq.br
                              BTM
                              OK, a video has been added for Merge Points. 👍
                              • mitcorbM Offline
                                mitcorb
                                BTM:
                                Wow! Congratulations. Excellent video.
                                A humble thank you.
                                mitcorb
                                edit: this appears to be able to close those tiny triangles-- is that correct?
                                  Seems another very cool plug! ☀
                                    BTM
                                    Yes, it can, but it depends on where you click, and the range of the tool.
                                      BTM
                                      UPDATED:
                                      The Merge Points to Lines tool now has a feature to allow you to pick between moving the points to the closest positions on selected lines, or moving the points to the closest endpoints of selected lines.
                                      • EdsonE Offline
                                        Edson
                                        thanks a lot! this is what i had in mind. 👍 👍
                                        • JClementsJ Offline
                                          JClements
                                          What a time saver this could turn out to be.
                                          This functionality should be a standard/built in tool of SketchUp pro.
                                          Thank you.
                                            Imagine you take a couple of neighbouring snapshots from GE and simply "stitch" them together with this tool in no time!
                                            Thanks BTM! 👍
                                            • 1 / 4
