    Podium Photomatch (AGAIN!) [TUTORIAL]
    31 Posts 14 Posters 6.5k Views 14 Watching
    • olisheaO Offline
      olishea
      yessir......
      Here is the original photo before the building was applied: (I updated the first post too)
      http://i654.photobucket.com/albums/uu269/olishea/Picture19.png
      I would post an non-edited panoramic without the building but the image is flat now, sorry!
      [edit] Here is the original panoramic before I stitched it better, without the building. Do you get it now?
      http://i654.photobucket.com/albums/uu269/olishea/pano-original.jpg
      oli
        dylan
        I must admit I always use more complicated ways of doing this. Your way Oli using Photomatch makes far more sense, seems very accurate and will save time.
        Look forward to your tutorial, although what you have already posted is a very big help πŸ‘
        http://dmdarchitecture.co.uk/
        • olisheaO Offline
          olishea
          The results can be amazing if you start off with the right photos. When I took my pics the sun went in and out of cloud....you can see the change in tone between the 5 photos which make this image up. (I also didnt use a tripod haha) I'm really not that good at photoshop otherwise I would have tried to make it completely seamless, maybe next time!
          oli
          • RichardR Offline
            Richard
            Mate awesome work again! I knew I was on to something when I said in another thread that I needed to watch your threads!!!!
            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
            • olisheaO Offline
              olishea
              I dont know why you are impressed Richard, your work infinitely cacks all over this!!
              oli
              • RichardR Offline
                Richard
                Why????
                Because you've shown some great artistic merit, true mastery over your applications and proof of simplicity in approach!!! All impress me mate!
                • majidM Offline
                  majid
                  nice and mastee piece of work πŸ‘
                  • olisheaO Offline
                    olishea
                    thanks guys! πŸ‘
                    oli
                    • holmes1977H Offline
                      holmes1977
                      Well done
                      You have inspired me to give it a crack
                      Exaggeration makes a dull story better.
                      • olisheaO Offline
                        olishea
                        good stuff, ill make a step by step tutorial for this next week
                        oli
                        • maxhouserocksM Offline
                          maxhouserocks
                          This is an old post, but i am hoping one of you fine gents might be able to steer me in the right direction. I have been looking for a quick way of rendering SketchUp PhotoMatch views within Sketchup via a rendering plugin. I cant find any that will SEE the PHOTOMATCH background. Any ideas of a package that will render everything together?
                          I have been using this compositing method above also but want to avoid photoshopping if necessary to save time. These photomatches are the only thing i cant take care of in Lumion(really needs a photomatch feature), so its usually a quick, down and dirty thing...but i would like to do better, faster.
                          I used to use Kerykythea alot, which will import the PHOTOMATCH if i remember correctly... its been a long time and im not sure i want to get back into Kerykythea since it has not been moving forward at all in development.
                          I usually just end up exporting directly from sketchup, like this, but i would really like to render it even if its a so-so render solution for Sketchup...just to be able to get light and shadows, etc on photomatches.
                          any advice welcome.
                          Thanks,
                          Bob
                          rachristman.blogspot.com
                          Sketchup export of photomatch
                          Robert A. Christman
                          http://rachristman.blogspot.com/
                          • emerald15E Offline
                            emerald15
                            Oli, did you ever get a chance to make that tutorial - I'd be really interested. I've just recently started rendering my work (with Twilight Render) and need to fit models into photographic backgrounds quite often. I started with a similar technique of marking the model image & superimposing it into the background in photoshop. However, I couldn't get a good masked image (halo lines around objects).
                            I then tried (now, my preferred method)- dropping the background image into SU as a watermark, positioning the models to fit into background, then setting the same background up in the Twilight environment setting. It hadn't occurred to me to match photo the background - good idea!
                              seems you can also try the free Visualizer for obtain some transparent backgrounds ! ?
                                emerald15
                                Thanks Pilou. I'll definitely be trying that.
                                • pbacotP Offline
                                  With Twilight did you try an alpha mask?
                                  • olisheaO Offline
                                    olishea
                                    The tutorial is in the first post of this thread....I didn't show every photoshop method though.
                                    For masking you should really look at this tutorial. It really does make perfect masks. You can choose to mask more or less and completely eliminate halos. Don't be afraid to close stamp halos out either, there is nothing worse than white halos.
                                    Masking Hair in Photoshop CS3
                                    Masking hair is one of the harder challenges faced when you want to move a subject from one background to another. Here are two techniques for getting this done.
                                    Layers Magazine (layersmagazine.com)
                                    If you can mask hair you can mask anything.
                                    Don't forget you can always select your mask in photoshop, then Select>Modify>Expand (or Contract)....you can nudge the mask by a pixel or two to crop the edge of the mask.
                                    oli
                                    • HornOxxH Offline
                                      HornOxx
                                      Hi Oli
                                      Today I have seen your excellent example - a great and very accurate work and thank you for showing your "Making Of". The location of your building is great (the building itself as well of course!). This Medieval bridge (?) must be a great view for users of your building.
                                      Since this surrounding is so interesting, it is not only correct but even necessary to use Photo Match here!
                                      πŸ‘ πŸ‘ πŸ‘
                                      Since I've done a similar Making Of example a few days ago, I think your thread might be a good place for adding it here and I hope thatΒ΄s ok? (In my case I used Shaderlight for rendering but the working principle is the same as using Twilight or Podium etc.)
                                      Using a simple dummy scene, the attached pictures will show the steps which are necessary to make a simple interior exhibition simulation by using SketchUps β€œPhoto Match”.
                                      An added bonus of this example is, that the exhibition design should be reflected in the glossy reflecting floor of the exhibition hall.
                                      For the result shown here, I have only used SketchUp and Shaderlight, no postprocessing in Photoshop - but only because this scenario was so simple of course.
                                      I hope this Photo Match mini-tutorial is useful as well ...
                                      Adjusting of the Perspective in PhotoMatch
                                      ![Adding and "Photo Match"-Texturing of a Floor segment](/uploads/imported_attachments/tMkv_02.jpg "Adding and "Photo Match"-Texturing of a Floor segment")
                                      Model Overview
                                      Adjusting of the Material Properties within the used Render tool
                                      Adjusting of the Light Properties within the used Render tool and Final Render
                                      never trust a skinny cook
                                        maxhouserocks
                                        I think what i have been looking for is possible if a renderer allows the use of the custom background image, which most should. That way, the same image that was used for PHOTOMATCH can be used a background image and hopefully avoid the need for masking and comp'ing when doing quick photomatch exercises.
                                        i am still on the look out for a quick render package that will just render the model and the photomatch photo natively.
                                        Shaderlight looks interesting. Hope to test that out as a quick solution when not using Lumion.
                                        Thanks guys!
                                        Bob
                                        Robert A. Christman
                                        • olisheaO Offline
                                          olishea
                                          Nice tutorial and of course I do not mind HornOxx. πŸ˜„
                                          Max, unfortunately some PP is required. You can use custom background environments in most render apps now, so maybe that's the way to go. You also need to "tell" the render app which is foreground and which is background (sometimes your photograph overlaps the building i.e. lampposts, cars, people etc....)
                                          I don't think it will ever be as simple as "Match Photo, Project photo textures, Set materials, Render". There will always be a degree of photoshop to these types of images for the reasons mentioned above. Unless some render app introduces built-in custom masking which I doubt will happen.
                                          The only other way of producing these images is taking your own spherical panorama and then insert your building into the context; real light, real materials, real reflections, real scale....but again, some foreground elements may need to be photoshopped in front of your building/subject. You also need a nodal ninja tripod (or equivalent) and DSLR camera which cost $$$$. Or you could borrow mine!
                                          oli
                                            maxhouserocks
                                            Thanks Olishea. I always try to "draw over" when i can for things like foreground lamp posts, etc, as i did in the image posted at top (the outdoor seating area is new) but no matter what it seems you are correct... the better final product will always need to be rendered and comp'd in PS to get things just right. Excellent masking tutorial link, btw. thanks for sharing.
                                            Robert A. Christman
                                            • 2 / 2
