    Podium Photomatch (AGAIN!) [TUTORIAL]
    31 Posts 14 Posters 8.0k Views 14 Watching
    • olisheaO
      olishea
      Hi Dylan,
      I just used the automate function in Photoshop. (file>automate>photomerge)
      It will only work well if the original photographs run into each other nicely (and the daylight doesn't change between each photo you take, as with mine)
      It is worth playing around with the stitching modes (perspective, cylindrical etc.) to best suit your image. I then cropped it and blurred/clone stamped the stitches.
      There are other ways of doing this with perfect results but I find this method quickest.
      oli
      • olisheaO
        olishea
        Here is another version....nicer I think.
        marked.....I get you now, it can blend in while still having contrast.
        http://i654.photobucket.com/albums/uu269/olishea/panobluetest-4.jpg
        oli
        • GaieusG
          Thanks for the "originals". Indeed they were needed to make the whole situation clear. Really great work. And I don't mind the blending either. I guess that's also the goal (somewhat); to convince officials for instance that it won't be striking at all.
          • soloS
            Oli
            You seem to have made a point in mastering this whole photo-match thing...well done!
            I have never really had a need for this in the past, but recently I've had a call for a few of these, I use a whole different technique and software to achieve what I was asked for however you seem to have a very much easier and quicker solution (so it looks), do you think if and when you get a chance that you would be willing to throw a quick tutorial or even video together on the basics of your technique? It would certainly be something we would add to our growing anthology of tutorials and something that will benefit many users, myself included.
            • olisheaO
              olishea
              Solo.....of course I will. I've learnt a wealth of information from your works and tutorials so I'd be more than happy to return the favour! I'm kinda flattered that you, render god, can learn something from a mere mortal like me!
              (and yes the technique is easy)
              Watch this space.........
              oli
              • olisheaO
                olishea
                yessir......
                Here is the original photo before the building was applied: (I updated the first post too)
                http://i654.photobucket.com/albums/uu269/olishea/Picture19.png
                I would post an non-edited panoramic without the building but the image is flat now, sorry!
                [edit] Here is the original panoramic before I stitched it better, without the building. Do you get it now?
                http://i654.photobucket.com/albums/uu269/olishea/pano-original.jpg
                oli
                  dylan
                  I must admit I always use more complicated ways of doing this. Your way Oli using Photomatch makes far more sense, seems very accurate and will save time.
                  Look forward to your tutorial, although what you have already posted is a very big help πŸ‘
                  http://dmdarchitecture.co.uk/
                  • olisheaO
                    olishea
                    The results can be amazing if you start off with the right photos. When I took my pics the sun went in and out of cloud....you can see the change in tone between the 5 photos which make this image up. (I also didnt use a tripod haha) I'm really not that good at photoshop otherwise I would have tried to make it completely seamless, maybe next time!
                    oli
                    • RichardR
                      Richard
                      Mate awesome work again! I knew I was on to something when I said in another thread that I needed to watch your threads!!!!
                      BUILTBRAND.COM.AU
                      • olisheaO
                        olishea
                        I dont know why you are impressed Richard, your work infinitely cacks all over this!!
                        oli
                        • RichardR
                          Richard
                          Why????
                          Because you've shown some great artistic merit, true mastery over your applications and proof of simplicity in approach!!! All impress me mate!
                          BUILTBRAND.COM.AU
                          • majidM
                            majid
                            nice and mastee piece of work πŸ‘
                            • olisheaO
                              olishea
                              thanks guys! πŸ‘
                              oli
                              • holmes1977H
                                holmes1977
                                Well done
                                You have inspired me to give it a crack
                                Exaggeration makes a dull story better.
                                • olisheaO
                                  olishea
                                  good stuff, ill make a step by step tutorial for this next week
                                  oli
                                  • maxhouserocksM
                                    maxhouserocks
                                    This is an old post, but i am hoping one of you fine gents might be able to steer me in the right direction. I have been looking for a quick way of rendering SketchUp PhotoMatch views within Sketchup via a rendering plugin. I cant find any that will SEE the PHOTOMATCH background. Any ideas of a package that will render everything together?
                                    I have been using this compositing method above also but want to avoid photoshopping if necessary to save time. These photomatches are the only thing i cant take care of in Lumion(really needs a photomatch feature), so its usually a quick, down and dirty thing...but i would like to do better, faster.
                                    I used to use Kerykythea alot, which will import the PHOTOMATCH if i remember correctly... its been a long time and im not sure i want to get back into Kerykythea since it has not been moving forward at all in development.
                                    I usually just end up exporting directly from sketchup, like this, but i would really like to render it even if its a so-so render solution for Sketchup...just to be able to get light and shadows, etc on photomatches.
                                    any advice welcome.
                                    Thanks,
                                    Bob
                                    rachristman.blogspot.com
                                    Sketchup export of photomatch
                                    Robert A. Christman
                                    http://rachristman.blogspot.com/
                                    • emerald15E
                                      emerald15
                                      Oli, did you ever get a chance to make that tutorial - I'd be really interested. I've just recently started rendering my work (with Twilight Render) and need to fit models into photographic backgrounds quite often. I started with a similar technique of marking the model image & superimposing it into the background in photoshop. However, I couldn't get a good masked image (halo lines around objects).
                                      I then tried (now, my preferred method)- dropping the background image into SU as a watermark, positioning the models to fit into background, then setting the same background up in the Twilight environment setting. It hadn't occurred to me to match photo the background - good idea!
                                        seems you can also try the free Visualizer for obtain some transparent backgrounds ! ?
                                        • emerald15E
                                          emerald15
                                          Thanks Pilou. I'll definitely be trying that.
                                          • pbacotP
                                            With Twilight did you try an alpha mask?
