    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 126.1k Views 34 Watching
      Matt666
      Fredddooooo!! Mais comment fais-tu !!?? Impressionnant, je suis que je suis complètement fan de tes plugins !! Bravo...
      For those who didn't adopt this incredible new plugin:
      Frenglish at its best !
      My scripts
      • fredo6F Offline
        New version **HoverSelect 1.1d (23 May 09)**available. It fixes a bug in the 'All Connected' selection mode.
        see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18916#p155058
          [attachment=0:3frmu70t]<!-- ia0 -->Sans titre 2.jpg<!-- ia0 -->[/attachment:3frmu70t]
          Is that the UI? How on earth is that done??
            Matt666
            Yes 😲 😲 😲
            Awesome...
            My scripts
              How is it one? 😲 I'm really curious.
              • Chris FullmerC Offline
                Have you downloaded it and used it Thom? Its an awesome UI!
                I think that it is is done with the view.draw type methods. All the draw, draw2d, draw_points, draw_polyline, draw_text. That is my guess.
                • fredo6F Offline
                  Yes, this is actually pure drawing routines in the view. Which is somehow also an issue to capture events when you cascade tools.
                  So far, this is experimental, but I'll work on it to retrofit in other plugins.
                    I thought you could only draw lines and text. Not filled shapes. I need to look at the API again.
                    • massimoM Offline
                      massimo Moderator
                      Hi Fredo, i've not tried this plugin yet and maybe it works for my request. But it's possible to add a filter "by distance" to the selection via rectangle? I try to explain: actually when you select by a rectangle you select all edges and faces in the window even if they are very far and that is quite annoying. I have in mind an option with an input for maximum distance selection like, for example, "select all edges and faces in the window as far as 100 cm". Something like "Max Wall Thickness" in Windowizer 4 plugin.
                      Thank you and sorry if that is a nonsense...
                      Massimo.
                      • fredo6F Offline
                        Massimo,
                        This make perfect sense.
                        And after all, the tool is there to comply with requests from users.
                        I'll do something in a next version.
                        Thanks for the idea.
                        • mitcorbM Offline
                          mitcorb
                          Fredo:
                          This would be the variable falloff "brush" available in some other modelers.
                          Sure would be nice to have this capability.
                            pichuneke
                            Working on the spanish translation (very busy these days...)
                            Forgive my spanglish...
                            • EarthMoverE Offline
                              EarthMover
                              I've grown to use this plugin as much or more than any other. I've actually added it as the shortcut Shift + Spacebar and I'll use in place of the standard selection tool.
                              It is perfect except for one or two things.
                              Fredo,
                              In the next version can you change the way that hitting shift will toggle the "select all connected lines" on? Can it be set that when you let go of shift, the command goes back to standard selection mode? I often have to move and pan around the scene while selecting lines and anytime I pan using shift, it turns on the select all connected lines and I have to turn it back off to keep hover selecting the additional lines. A minor headache, but one nonetheless.
                              Also the select all connected lines is very inconsistent for me. A lot of times it will register that there are connected lines and the arrow will change color and the plus sign will appear, but it will not select anything at all. Then I go to a parallel set of lines that form the same structure and it has no problem. It is an issue with intersecting hidden or softened lines touch the line I want to select continuously?
                              Thanks again Fredo for all your great time saving tools!!!!
                              Content Creator at Skapeup
                                How do you actually draw filled shapes to the viewport?
                                • fredo6F Offline
                                  Actually Shift and Ctrl work in 2 modes:
                                  1. Toggle: quick press and release
                                  2. Keep down while selecting. Normally, when you release the key, it goes back to normal mode. Maybe this does not work very well?
                                    So far I have not found other ways for the modifiers (function keys do not work well on Mac and most other keys are taken by short cuts). This is why I added the button palette.
                                  There are bugs in this version and it may well be related to the soft / hideen lines, depending on how you configured the filter. I encapsulated a different implementation in LibFredo6 which I will retrofit in HoverSelect for a new release. You can see it for instance in RoundCorner 2.1.
                                  • fredo6F Offline
                                    just use view.draw or view.draw2d with GL_POLYGON, GL_QUADS codes.
                                    Note that there is a bug in SU API for the 3D drawing (i.e. view.draw), which does not take into account the color set by view.drawing_color and always draws in black. I have signaled it to the SU team.
                                      Ah, I was struggling with that. And drawing a polygon over a face causes z-fighting. 😕 Which there was a nice way to highlight faces...
                                      • wind-borneW Offline
                                        wind-borne
                                        Just joined recently to enter the wild, wacky world of ruby. Ran across this thread and realized this might be something i would use regularly, but only a couple of the functions work, no hovering, rectangle or lasso selecting. Clicking an edge, very difficult; clicking a face does select edges easily.
                                        Your other tools I downloaded work fantastic.😄
                                        Thanks in advance if you can steer me in right direction. 😆
                                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                                        %(#BF80BF)[SU 8 pro
                                        • fredo6F Offline
                                          The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
                                          see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=18916&hilit=plugin#p155058
                                          • U Offline
                                            unclex
                                            Where put the LANG?
                                            • 2 / 5
