    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
    • fredo6F
      @pico said:
      Has the pointy corner problem been solved?
      Thanx 😄
      Do you mean this?
        This plugin has that ability Fredo? 😲
        Or is this something you got in the making?
          Daniel S
          I don´t know if Fredo put that image too see what Pico mean or if he is showing the next version of round edge????
          Daniel S
          • GaieusG
            I'd also be interested... 😒
            • fredo6F
              Daniel S
              This is in the making, but I hardly find time to progress.
                I'll be looking forwards to this. Rounding the edges in that manner is a must to model and render a realistic product model.
                • P
                  Pico
                  Thanx 😄
                  Do you mean this?
                  [attachment=0:ktbcwyt8]<!-- ia0 -->RoudnCorner.jpg<!-- ia0 -->[/attachment:ktbcwyt8]
                  Yes!
                  How much longer?
                  • GaieusG
                    It's a great plugin even with the pointy edges but this would definitely take it to a "next level". 👍
                    Just take your time, Fredo, we are not impatient
                    (not impatient... not impatient 🎉 )
                      Daniel S
                      Just to know that you´re behind a new version makes me happy 😍 😍
                      I´m not impatient too.. but I just make alternative icons for the future plugin 🎉
                      Daniel S 🎉
                      alternative icons.zip
                      • fredo6F
                        Daniel,
                        Thanks very much for the icons.
                        If you don't mind, I will make them the primary icons, because mine were really ugly.
                        • C
                          craigslist.men
                          is there any way i can round the edge only bit like a 1/16 or even less?
                            Daniel S
                            Daniel,
                            Of course you can, and thanks again for working in this plugin.
                            A workaround is to scale the model. For example with my units you can´t round less than 0,5 cm. So if you need to round 0,4 cm you can scale up the model 10 times and round 4 cm. Then you scale down (0,1) and you have the rounded edges in 0,4 cm.
                            If you need less you can scale 100 times larger or even more, and scale down when done.
                            Daniel S
                            • plot-parisP
                              plot-paris
                              oooh, I am so looking forward to this new version! I guess there is a whole community eagerly awaiting your next breakthrough.
                              so no pressure there, fredo 😄
                              • T
                                TeamSDA
                                We also want to Chime in and agree that a professional grade tool for bullnosing and filletting is much needed.
                                Team SDA
                                  magpie
                                  Many thanks Fredo for your elegant plugin.
                                  As a new user to all this, it has worked like a dream! Very useful and easy to incorporate into sketchup...thanks too to the icon-maker! Looks good!
                                  • CarrozzaC
                                    Carrozza
                                    Go Fredo Go!!!
                                    • N
                                      NawaGK
                                      Thank +++
                                        Jebimasta
                                        Thanks, Fredo, for your brilliant plugin!
                                        unfortunatly the model I needed to use it on includes instances where concave meets convex.
                                        Obviously this is a problem 😛 Any headway on solving this issue?
                                        Thanks again 😄
                                        • fredo6F
                                          Jebimasta,
                                          Then you should look at a more recent plugin, RoundCorner 2.0
                                          Download, doc and video is at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485#p171721
                                          • N
                                            novice
                                            Cool Fredo!
                                            Thank you!
                                            • 7 / 9
