    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      Download link is here:
      http://www.sketchucation.com/forums/scf/download/file.php?id=27660
        mics_54
        ๐Ÿ‘Ž
          Marinho
          Hi Thomthom, Hi TIG, tanks... but I am litle craze.... I have password
          for the two... forun and site Sketchucation, but when I see "FredoScale
          2.gf to download to unzip (via SELECT ALU in Sketchup Plugins folder
          (731.49 KB) and I click it, I receive the notice "you are not....." and
          in this page, there are not place to login. TIG, tanks you for the
          direct link to download, but the same things, I am going to a place
          where I dont can log me. I am completly lost. The same with the links of
          tutorials in home page of Sketchucation. Links where I dont have
          acess to login,even though, I have the passwords. Sorry, but I need nost help.
          Tanks
          Marinho.
          • GaieusG
            Hi Marinho,
            You need not register/log in on the main site of SketchUcation at all. All tutorials can be freely viewed without logging in.
            The only place you need to log in (to se and download attachments) is the forum.Please, let me know if you have problems with that.
              Marinho
              Hi every people, tanks a lot. Gaieus, for instance: now I clik in link above from TIG "download/file.php?id=27660";imediatyle I see a new page whit the message: " INFORMATION - you are not authorised to download this attachment" Way? I am loged at forum. Way I canot download the file?
              Tanks,
              Marinho ๐Ÿ˜ณ
                Marinho
                Hi all, sorry for my date system (mar 31 2001) my PC in home have a problem in bios batery...
                Marinho.
                • GaieusG
                  Can this be a problem? Can you fix it?
                  When you are logged in,you should definitely be able to see/download attachments from the forum.
                    Marinho
                    Halleluijah!!!!!!!!!!!!!!!!!!I use two pc's. One in home, another in my job. In my job I work with database, and, by many reasons, I need use a different data of the real and actual date. In home, my PC has a problem in CMOS battery, and, the date is always marc 31, 2001. Today, after send the first post, I am worry about date in my PC, only because in the forum it would be seen strange. only because thus I decide I date to bring up to date it, and SURPRISE!!!!!!! I am goig again to the TIG links and in two segunds... I have in my hands FredoScale 2.0g.Now I am to try on the plugin, but it is the lesson for others: if you intenciona to make download, make the PC's date actual.So long! tanks and tanks and I send news!!! ๐Ÿคฃ
                    Tanks a lot,
                    Marinho.
                      Delacro
                      this is amazing! Thankyou very much!
                        Jackson
                        It would make sense to upload it to Rapidshare or similar rather than as an SCF attachment and save the link in the first post embedded in the words
                        "DOWNLOAD HERE" in BIG letters!
                        Jackson
                          mpowell1234567890
                          I cannot get it to work, every time I try to use it, It causes a bugsplat and Sketchup terminates. Is there a way to fix it?
                          • jwlyon1J
                            jwlyon1
                            Wow. I've been using an older version for a month or so, but this one is amazing. Amazing...
                            Macbook Pro/ iMac
                            OSX 10.7.2 Sketchup 8
                            rogue-z is here!
                            • fredo6F
                              You need to be more accurate on how this happens.
                              Which tool? Which situation?
                                dondanev
                                  MrPlanet
                                  ๐Ÿ˜ฎ I think i've been using theone with just taper and FreeScale, but this is AMAZING! Thanks a lot, Fredo6, really helps in aircraft modelling ๐Ÿ˜„
                                  I reject your reality and substitute my own.
                                  • B
                                    bianhai
                                    amazing. Amazing... ๐Ÿ‘
                                    • fredo6F
                                      Thanks.
                                      If anyone of the bbs community wishes to give a try for the chinese translation....
                                      • szaniniS
                                        szanini
                                        Thank you, thank you, thank you!!! and again thank you...
                                        • C
                                          ccad
                                          A wonderful plugin... What else... ๐Ÿ˜‰
                                            RDailey
                                            Fredo,
                                            I can't seem to download your Fredoscale plugin in its' suppporting files. All I get where the plugin should be is:
                                            You do not have the required permissions to view the files attached to this post.
                                            Is there anywhere else I might be able to go to snag this plugin and its' supporting files.
                                            R Dailey
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 58
                                            • 59
                                            • 16 / 59
