    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • H Offline
      haynesc
      thanks
      • BepB Offline
        Bep
        I have a question regarding joint push pull.
        It is illustated by the skp file.
        example.skp
        I hope that i am doing something wrong, or that some of my settings are wrong.
        It would be great if the desired outcome whould be possible
        greetings ,
        Bep van Malde
        "History is written by the winners"
        • fredo6F Offline
          [attachment=0:1jxqs3h2]<!-- ia0 -->example.skp<!-- ia0 -->[/attachment:1jxqs3h2]
          greetings ,
          Bep van Malde
          Bep,
          I think you simply touch some of the limitations of JPP. I am afraid this is a pure geometrical problem.
          Try to Push pull individually the faces by 2 cm, and then see how they can be connected 'jointly'. You'll see that there is no good solution.
            mpowell1234567890
            Hi, every time I try to use joint push-pull in sketchup, it creates a bugsplat and terminates sketchup 7. Is there a way to fix it?
            • BepB Offline
              Bep
              [attachment=0:2u6jklv3]<!-- ia0 -->example.skp<!-- ia0 -->[/attachment:2u6jklv3]
              greetings ,
              Bep van Malde
              Bep,
              Thanks for answering ,its a pitty this dos not work 😢 (yet)
              Bep
                pr0
                I know that this question doesn't concern the joint push pull plugin - however i've noticed that certain geometry can be push - pulled in a very visual and intuitive way when concerning pure geometry. Is it possible to do the same with 3d splines? Except instead of push - pulling them you would offset them? Fredo and Chris Fullmer are probably the masters concerning sketchup plugins - so i was wondering Fredo, do you think it would be possible to create? here's the link to the forum where there are visual examples. Thanks in advance.
                301 Moved Permanently
                (www.sketchucation.com)
                -Sam
                  dondanev
                  hvala puno ako ko razume thanx
                    rv1974
                    Hi Fredo!
                    I thought about some enhacement of the single face JPP. It should respect the adjacent faces (AB and CD keep their directions while BC is moving forward (example 2)). It works in revit and I think it would be great especially in architectiral practice.
                    P.S. Basicly instead of single BC face there could be any number of faces- it's all about vicinity treatment.
                    Thanks in advance
                      JaViXP
                      I have translated this plugin into Spanish, how can I change the default language?
                      "Giving up is way harder than trying"
                      JaViXP's Rendering
                      • fredo6F Offline
                        Normally you'll get the spanish version if your Windows or Mac system is in spanish.
                        To force the language, just create a file LibTraductor.def(or edit it if it already exists), and make sure the one line code is:
                        TRADUCTOR_DEFAULT = "ES"
                          JaViXP
                          It displays an error for me, could you please do it? (JPP text is below)
                          Thanks 😄
                          JPP Text.txt
                          JaViXP's Rendering
                            magpie
                            many thanks again fredo!
                              Patrickpr
                              Hy
                              What is this?
                              LibTraductor.def, an optional configuration file allowing override of language
                              i Have the german version
                              I can that not install 😢 😢 😢
                              • fredo6F Offline
                                @patrickpr said:
                                Hy
                                What is this?
                                Patrick,
                                Unfortunately, JointPushPull is an old script and the translation must be done in the code of the script itself (line 29 to 168 of jointpushpull.rb).
                                The convention is to add the strings in the existing lists as "|DE| the text", being careful to put a \ before any accentuated or special character (and also careful with the Ruby syntax). Usually, I do it myself, based on translation provided by contributors in text files.
                                PS: I plan a refresh of JPP one of these days, based on LibFredo6. Then the translation can be done in an easier way, like in FredoScale or HoverSelect, and in much more languages.
                                  JaViXP
                                  That sounds cool 👍
                                  I'll try to translate it into Spanish 😄
                                  JaViXP's Rendering
                                  • simon le bonS Offline
                                    simon le bon
                                    Bonjour Fredo,
                                    "Please help!"
                                    I don't know why, JointPushPull doesn't close the borders anymore!!"Snarrgg" - - Even if I indicate in configuration menu "borders on external faces" (traduction~!). But it continues to close the sides when I indicate "Borders on all the faces"...
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_001.jpg
                                    I don't think so because I had already made some tries but may be the version of LibTraductor.rb plays in this fail?
                                    The one given in the zip package is 13 732 bytes 20/01/2008
                                    and I use the recent one given with BezierSpline v121 : 19 331 bytes 07/07/2008
                                    Or may be it is a cause from one of the plugins I have recently installed ❓
                                    Please Fredo, what can you advise me. (I don't know nothing with ruby console, code etc..)
                                    --simon.
                                    • fredo6F Offline
                                      Simon,
                                      I don't think this is related to LibTraductor.
                                      Normally, when you start up Sketchup, the default option is always to create the border faces.
                                      Is this what you observe ?
                                        simon le bon
                                        Dear Fredo,
                                        Thanks for replying.
                                        JointPushPull is now a basic tool for me. To see it not working makes me nervous 💚
                                        Here is a more complete report:
                                        ( it is more easy to me to explain in pictures )
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_002.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_003.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_004.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_005.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_006.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_007.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_008.jpg
                                        What more test can I do?
                                        --simon
                                        • fredo6F Offline
                                          Simon,
                                          Thanks.
                                          Although this seems strange, I'll check where the conflict could be.
                                          By the way, did you install LibFredo6 3.2a yet, or are you still running an earlier version?
                                          • fredo6F Offline
                                            Simon,
                                            This has nothing to do with HoverSelect, but with LibFredo. The bug is more subtle than that: it is actually related to how SU and dialog boxes handle accentued characters in drop down controls.
                                            It only exists in the French version of JPP, because of the text "Bordures sur les faces extérieures", which contains an accent.
                                            As a result, any call to the dialog box via TAB would make the Border option void.
                                            In any case, you can change all options using Function keys (F5 to toggle for Thickening, keep face, erase face) for instance, or via the Contextual menu. This works regardless of the above bug.
                                            Attached is a quick fix to JPP (just removed the accent), but the real fix is in LibFredo. I simply need more time to make it and validate, as this is now shared in all my plugins.
                                            PS: Thanks to advise is OK
                                            jointpushpull.rb
                                            • 18
                                            • 19
                                            • 6 / 19
