    Materials Reappearing
    44 Posts 12 Posters 7.6k Views 12 Watching
    • boofredlayB
      boofredlay
      Gai, yes they are always the same materials.
      Jim, I have done nothing with DC's.
      • boofredlayB
        boofredlay
        In another file I imported a jpeg as an image (not a material) and then later deleted it. Then I purged as normal, saved and closed. When I opened the file that image was reloaded as a material. I never exploded the image, just used it as a reference then deleted it.
        • honoluludesktopH
          honoluludesktop
          Couldn't be as simple as opening the backup file?-) For myself, been their done that ๐Ÿ˜‰
          • GaieusG
            I've also thought about that but to tell the truth, I didn't dare to mention it to Eric. ๐Ÿ˜ณ
            And then again, he uploaded the skp file here, too.
            • boofredlayB
              boofredlay
              Nope, if I open the backup I get the same thing.
              What is odd is that I uploaded a file and Gai is not getting the extra materials, only me. So something on my end is going loco.
              I ran CCleaner and Defragler then restarted. Still not working right. ๐Ÿ˜
              And again, it is happening on all the files I have tried, not just the one I uploaded here.
              • jcdbJ
                jcdb
                http://images.tvrage.com/shows/7/6487.jpg
                http://www.acustombuilder.com
                  What is you temporarily disable all plugins? (Rename the plugins folder might work?)
                  • boofredlayB
                    boofredlay
                    And screw up all my toolbars.... last resort maybe ๐Ÿ˜ฎ
                    I am thinking a reinstall will do the trick.
                    I have to finish working on a few models first so I don't think I will do that for a few days.
                    Grrr, this is odd.
                    • GaieusG
                      ๐Ÿคฃ
                      • Chris FullmerC
                        You can fix your toolbars by un-maximizing SU. Then drag the edges of the window out so its as big as fully expanded window, then re-maximize it. You might have to fix your toolbars, but it should then stay good when you load new plugins in the future.
                        This is all in theory. I've seen it work on my machine, and others tried it and it worked for them, but i'd feel bad if it didn't work for you. But I'd love to know the results if you do test it.
                        PS I'm also going to play with the file and see if I see anythin (not likely).
                        • Chris FullmerC
                          yeah, I quicly found that I see nothing.
                          What happens if you download the model from here and open it?
                          • boofredlayB
                            boofredlay
                            Same thing. I have 8 non-used un-purged materials.
                            You know that sound you hear when the hair on the back of your neck starts to stand on end... ๐Ÿ˜ฒ
                              About this time we called Ghostbusters?
                                remus
                                My bets on a plugin adding the materials each time you open the model...
                                • GaieusG
                                  What would happen, Eric, if you renamed the file before opening it again?
                                  • AnssiA
                                    Anssi
                                    Boo,
                                    I don't think the SU materials (not on a SU machine right now) have those numbers in their names. Are you using (or recently added) a rendering plugin? I could imagine those messing around with materials as they have their own parameters to add. Don't they use some kind of "xdata" to store just things like that?
                                    Anssi
                                      driven
                                      May not be related, but I've found (although I can't find) a hidden section cut artifact in one drawing that always appears if I try to zoom in to edit, either component (which are on separate layers) and sometimes from particular point of view editing or not.
                                      On one occasion I managed to reveal the actual cut plane by drawing a cylinder up from origin and recognised the cut as a transitional view between two scenes in a recent, but completely unrelated drawing. I've been trying to replicate for a screen capture, but can't... yet.
                                      I have established it's only in this drawing, the components are fine if I put them in a new drawing. so I could just delete this one completely
                                      except, if it could be toggled it might be a handy editing tool... maybe
                                      I don't know where else to post this???
                                      when editing
                                      and veiwing
                                      • boofredlayB
                                        boofredlay
                                        John, that is a common occurrence called clipping plane.
                                        Read about troubleshooting here:
                                        http://sketchup.google.com/support/bin/answer.py?answer=36261&topic=9042
                                        And it would be best next time to start a new thread instead ๐Ÿ˜‰
                                        Nice thought but that did not work.
                                        @anssi said:
                                        Boo,
                                        Anssi
                                        Good thinking but I have had that set of colors for quite a while and they have always had the numbers next to them. They are named exactly the same in SU6 as well.
                                        The most recent rendering plugin I installed was Vray and that was months ago, this problem just started. And like I mentioned before I have not added any new plugins that correlate with the problem's time frame. I did remove the last few plugins I installed just to see and it still had no effect.
                                        And this is not localized to just this file, it seems to be happening on any file I purge materials in SU7.
                                        For example, if I purge 3 green materials in one file, save then re-open I get 3 green materials back. If I purge 10 brick materials in another file, save then re-open I get 10 brick materials again.
                                        • boofredlayB
                                          boofredlay
                                          Well snot, I just did a test with a file I created back in 08 and did not get this problem.
                                          It may be that while I had a session of SU7 open it was corrupting files as I opened them???
                                          I will have to do some more investigation...
                                            alpro
                                            Just a shot in the dark, I don't use SU7 but I know you can link to a photo editor, did you make any recent changes there, maybe some paths got crossed or corrupted and its actually your photo editor thats reloading your textures, nevermind I dont think that would affect standard SU materials.
                                            Mike
                                            • 2 / 3
