    Materials Reappearing
    44 Posts 12 Posters 6.5k Views 12 Watching
    • boofredlayB Offline
      boofredlay
      Man, this really has me stumped. SU7 is retaining this information somehow. The only plugins I have installed recently have been cutlist and cleanup model but both of those were months ago and this problem just started a couple days ago. And yes, it is getting really annoying ๐Ÿ˜ž
        Are they always the same materials? Can you upload a model with them included? (Hope my machine doesn't get infected... ๐Ÿ˜„ )
          Jim
          You didn't happen to do anything with making it a Dynamic Component? I remember DC's have an odd way of handling materials.
            boofredlay
            Gai, yes they are always the same materials.
            Jim, I have done nothing with DC's.
              boofredlay
              In another file I imported a jpeg as an image (not a material) and then later deleted it. Then I purged as normal, saved and closed. When I opened the file that image was reloaded as a material. I never exploded the image, just used it as a reference then deleted it.
              • honoluludesktopH Offline
                honoluludesktop
                Couldn't be as simple as opening the backup file?-) For myself, been their done that ๐Ÿ˜‰
                  I've also thought about that but to tell the truth, I didn't dare to mention it to Eric. ๐Ÿ˜ณ
                  And then again, he uploaded the skp file here, too.
                    boofredlay
                    Nope, if I open the backup I get the same thing.
                    What is odd is that I uploaded a file and Gai is not getting the extra materials, only me. So something on my end is going loco.
                    I ran CCleaner and Defragler then restarted. Still not working right. ๐Ÿ˜
                    And again, it is happening on all the files I have tried, not just the one I uploaded here.
                    • jcdbJ Offline
                      jcdb
                      http://images.tvrage.com/shows/7/6487.jpg
                      http://www.acustombuilder.com
                        What is you temporarily disable all plugins? (Rename the plugins folder might work?)
                          boofredlay
                          And screw up all my toolbars.... last resort maybe ๐Ÿ˜ฎ
                          I am thinking a reinstall will do the trick.
                          I have to finish working on a few models first so I don't think I will do that for a few days.
                          Grrr, this is odd.
                            ๐Ÿคฃ
                            • Chris FullmerC Offline
                              You can fix your toolbars by un-maximizing SU. Then drag the edges of the window out so its as big as fully expanded window, then re-maximize it. You might have to fix your toolbars, but it should then stay good when you load new plugins in the future.
                              This is all in theory. I've seen it work on my machine, and others tried it and it worked for them, but i'd feel bad if it didn't work for you. But I'd love to know the results if you do test it.
                              PS I'm also going to play with the file and see if I see anythin (not likely).
                                yeah, I quicly found that I see nothing.
                                What happens if you download the model from here and open it?
                                  boofredlay
                                  Same thing. I have 8 non-used un-purged materials.
                                  You know that sound you hear when the hair on the back of your neck starts to stand on end... ๐Ÿ˜ฒ
                                    About this time we called Ghostbusters?
                                      remus
                                      My bets on a plugin adding the materials each time you open the model...
                                        What would happen, Eric, if you renamed the file before opening it again?
                                        • AnssiA Offline
                                          Anssi
                                          Boo,
                                          I don't think the SU materials (not on a SU machine right now) have those numbers in their names. Are you using (or recently added) a rendering plugin? I could imagine those messing around with materials as they have their own parameters to add. Don't they use some kind of "xdata" to store just things like that?
                                          Anssi
                                            driven
                                            May not be related, but I've found (although I can't find) a hidden section cut artifact in one drawing that always appears if I try to zoom in to edit, either component (which are on separate layers) and sometimes from particular point of view editing or not.
                                            On one occasion I managed to reveal the actual cut plane by drawing a cylinder up from origin and recognised the cut as a transitional view between two scenes in a recent, but completely unrelated drawing. I've been trying to replicate for a screen capture, but can't... yet.
                                            I have established it's only in this drawing, the components are fine if I put them in a new drawing. so I could just delete this one completely
                                            except, if it could be toggled it might be a handy editing tool... maybe
                                            I don't know where else to post this???
                                            when editing
                                            and veiwing
                                            • 2 / 3
