    Vray Sketchup Bump/Displace Problem
    renderpluginsextensions
    19 Posts 5 Posters 18.5k Views 5 Watching
      First of; I'd recommend you look into updating your VfSU to the latest version. In the latest version all materials are automatically linked.
      Displacement:
      You have to isolate all geometry that you want to displace. If the group/component contains any other material other than the displacement material it won't displace.
      Controlling the depth of the displacement: You can't trust the material preview. It's UV mapping size doesn't relate to the one you have in SU.
      When you want to set the depth of the displacement use the multiplier control of the displacement map to set the depth. 1 unit = 1 inch (Always! Doesn't matter what you've set your model units to be, it'll always use inches. That goes for pretty much all the V-Ray scene units.)
        p.s. If you're using bumpmaps you do not need to isolate the geometry.
        • soloS Offline
          Ah yes, that's it. I should have picked it up from first image as the geometry is not isolated as a group.
          That's why Thomthom is the guru and I'm not. πŸ’š
            You give me all too much credit Solo. I'm hardly a guru. But I have picked up a couple of thing on the way.
              afrotekno
              ok great, ill give that a go, can it still be touching another surface as long as it is still in a group of its own?
              is v.1.00.74 the latest version?
              also, (i hope i'm not asking too much?!) I need to make some sea water for the same scene (i know it's a strange one!)
              this is the best I have achieved so far.
              i managed to find a fairly decent rough sea mesh which i put a water material i made myself onto. It is a fairly straight forward glass-like material with a water bump map.
              AS you can see, it is not very realistic; do you have any pointers?
              thanks
                Yes.
                The latest version is 1.05.30. Mind you, if you're in the middle of some projects you might want to hold of an upgrade until you're done. There is some changes made which requires you to make adjustments to your scenes.
                For sea river water like that I make a material with a very dark diffuse colour. (very dark blue/green - nearly black) Then I add a reflection layer and a bump map. I did that with one of my first renders I did; http://www.thomthom.net/gallery/visualisation/verftstomta-01/
                There is one thing though, the bump map needs UV mapping. If you don't have a SU texture to size it, V-Ray will assume it's 1"x1". So you might want to make it easier and make a texture with the dark diffuse colour so you can control the bump map.
                  Just to explain a bit further to why I use a dark diffuse colour; water should be like glass, fully transparent. But since you have a sea, then you don't want to model the sea bed. In any case there won't be much light going down there, so it'll look black anyway. That's why I take a shortcut and make a near black diffuse with no transparency. I add a slight green/blue to the black just to make a slight tint to it.
                    afrotekno
                    ok that makes sense, do you use a reflection map for the water?
                    i made a reflection map the stone wall to represent the glossiness of the cut flint. Its pretty much the bump map inverted with an increased contrast. to adjust the parameters of the relection map, do i add a reflection layer? will the reflection layer only adjust what the ref map dictates or will it adjust it for the whole material?
                    thanks
                      afrotekno
                      this is the latest version of the stone wall (not quite right) i am just playing around with the settings..
                        Yes. The reflection is pretty much the only thing you see. Usually it's the blue sky, which is why the sea is said to be blue, while it's really just transparent.
                        Yes. Put your reflection map in the Fresnel colour of the default Fresnel map.
                        Then you might want to reduce the Reflection and Highlight glossiness a little bit. (will make the render slower. try without first.)
                        Not quite sure what you mean by that.
                          Can you post the displacement map?
                          Might be worth slightly blurring the displacement map to avoid to jagged points in it.
                          • arail1A Offline
                            arail1
                            Just wanted to say -
                            Threads like this are more useful to many of us than anything in the users manual or the various video tutorials you can find on the net. It really helps.
                            So thanks to the gurus -
                            • E Offline
                              ebraahim
                              hi guys when u dont have a su texture to size it, how u guys add bump map to it? i use the bump map as my texture and reduce the color mutiplier to 0.01 becuz its not possible to change diffuse color seperately from its texture
                              how you do that?
                                how you do that?
                                Set a texture in your diffues, as you say you do, then add an white TexAColor map to the transparency slot. That will make that layer invisible when rendering, but still visible in SketchUp.
                                Then you add a second diffuse layer underneath with just a plain colour - this layer is what you'll see when you render.
                                (Note that you use a TexAColor map type in the transparancy slow - no just setting the colour.)
